Old 08-07-2017, 03:25 PM   #3931
R3b
R3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond repute
This is my fitment with almost -3 camber and yoko s drive 225/40
This is of it moving around, this was with caster forward and it would rub the well on a bad bump or turning on a incline up/downward
http://www.thepicta.com/media/152866...6142_197398495
R3b is offline   Reply With Quote
Old 08-07-2017, 03:30 PM   #3932
R3b
double post
Old 08-08-2017, 08:53 PM   #3933
drfftn
drfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond repute
Originally Posted by theStig880 View Post
Blitz 03's ftw. The 17x9's are sweet but the 17x8's will need a spacer for sure. This is my car on 17x8.5 +25 with 205/40s and 18x10 +22 with 225-40s:
Granted I have 50mm overfenders in the rear but I'm fairly confident you could squeeze them on a pulled stock body. I had a 25mm spacer on the 10's with no camber and a 20mm spacer on the 8.5s with maxed camber plates. Your 8's will be about 26mm more sunk even with a 20mm spacer. But put it at zero camber and it would fit alright.
Personally, I'd run the 9's up front with a 215-40 and a small spacer. My LMGT4's are the same size and I needed a 5mm spacer to clear the coilovers, which are also PBM. Then either get the 10s on YAJ and sell the 8's or just rebuild the 8's. Those are welded so you would need to cut the welds if you go that route. You could rebuild to 9.5j +26 or 10j +20 for instance.
Also, so you can approximate tire size, I run 17x9 all around and have 205-40s up front (which I want to switch to 215-40s) and 225-45s in the rear.
+repped thanks for your advice! I've gone ahead and contacted threepiece and they've quoted me 200 per rim to rebuild the 8's. I'd love to pick up the 18x10, but can't spend that much cash on goodies right now.
drfftn is offline   Reply With Quote
Old 08-11-2017, 01:30 PM   #3934
R_Rod_s13
R_Rod_s13's Avatar
R_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really niceR_Rod_s13 is just really nice
Hello zilvia i have done a lot of searching through google and ziliva and I just had some final questions before buying tires .
I have a s13 hatch with no fender modifications . I just bought a set of rays gram lights in 17x9 +22 . I have Fortune auto 500 coilovers. I can't decide which size tire I should run . I really want to run federal 595- RS- RR . The thing is I know that they run a bit wider and that's where I need help . I'm going back and forth on running 235/40r17 all around or 215/40r17 all around or 215/40r17 in the front and 235/40r17 in the back . I'm fine with a light roll and camber but I don't wanna pull my fenders . Can I get alway with running 235s in the front or should I be on the safe side and run 215 in the front .
fuck i hate zilvia
R_Rod_s13 is offline   Reply With Quote
Old 08-11-2017, 04:27 PM   #3935
marveluz
marveluz will become famous soon enoughmarveluz will become famous soon enoughmarveluz will become famous soon enoughmarveluz will become famous soon enoughmarveluz will become famous soon enough
Wheel Fitment Question Thread
Originally Posted by R_Rod_s13 View Post
215/40/17 or 235/40/17 up front?
Do you want more mechanical grip? 235
Do you want more low? 215
*edit: 235/40 has been known to work well with what you want.
marveluz is offline   Reply With Quote
Old 08-11-2017, 05:43 PM   #3936
derass
^^ What he said.
I would not run staggered tire sizes on those wheel. I prefer a square setup as I find that it maintains the car's neutral balance. I found that staggered tires induce understeer.
I ran 235/40R17 all around on my 17x9 +20 with just rolled fenders and -3* camber all around. I did fit 245/40 in the rear on those same wheels too. That size would have probably fit on the front as well. With your +22 offset you could definitely run 245/40R17 all around.
Old 08-11-2017, 06:19 PM   #3937
R_Rod_s13
R_Rod_s13's Avatar
Originally Posted by derass View Post
^^ What he said.
Yea I thought it over and I'm definitely going with the 235/40R17 all around . I could deal with an 1 inch gap between the fender and tire and camber . I just thought 235 would require more fender work . But thanks again guys !
fuck i hate zilvia
Old 08-20-2017, 05:55 AM   #3938
GibsonS
GibsonS is an unknown quantity at this point
I own a 1991 s13 240sx and I would like to ask about wheel fitment. I want to get cosmic mr7 18x9 +25 but I don't know what size tire I should get to make the wheels fit I was think a 235/40/18 all around I've searched all around but not a lot of People run 18s in 240sx please help. I'm okay with rolling or pulling fenders and I have Bc br racing coilovers for suspension.
GibsonS is offline   Reply With Quote
Old 08-22-2017, 11:14 AM   #3939
marveluz
235/40/18 is tall for fronts.
I would go with 225/40 or 245/35 if you want a square setup.
Some even run 215/35f 225/40r if you need more clearance to go low
Old 08-22-2017, 12:22 PM   #3940
R3b
If you scroll up on my post, i've got 225/40 on 9.5 Even though offset is a little higer and smaller wheel it should be sorta the same fitment. My issue is having the front semi low and it rubs the well when cast is too forward and when its back it rubs the fire wall.
Still trying to see my options. Im stuck at running spacers and more camber.
Old 08-22-2017, 12:23 PM   #3941
R3b
double post
Old 08-22-2017, 04:30 PM   #3942
derass
Not entirely true. I ran that size on 18x8.5 +30 on the front of my S13.
Old 08-23-2017, 01:50 PM   #3943
marveluz
I had 235/45s put on 17x9s and had to keep them in rear on my s13. It rubbed everywhere up front.
I just recently switched from 225/40/18f 235/4018r to 235/40/17 square on the s14 and I'm liking all the room in the wheel well. Lol
Old 08-25-2017, 11:51 PM   #3944
Sidney_223
Sidney_223 is an unknown quantity at this point
Hey I have a 1998 s14, and was wondering if the 18x9.5 +10 cosmis xt206r's would fit without rolling or pulling the fenders? Not really going for a slammed look either. Also suggested tire size?
Sidney_223 is offline   Reply With Quote
Old 09-04-2017, 04:18 AM   #3945
Ryan_1
Ryan_1 is an unknown quantity at this point
I currently running 18x10.5 plus 1 at the rear and i am goin to get new wheels and thibking about gettin 18x11 neg 5 and looked upthey have goin to have 12mm more poke. How much xamber would 12mm if i just increased the neg camber?
Ryan_1 is offline   Reply With Quote
Old 09-08-2017, 04:20 PM   #3946
DriftDamage
DriftDamage's Avatar
DriftDamage is an unknown quantity at this point
Does the search not work?
I'm trying to figure out what size spacer I will need to have the XXR 968 17x10 +20 clear my front coilovers and 300zx brakes.
I have an s13,steering angle kit, and +20mm fenders installed.
Just trying to get -3 camber all around.
DriftDamage is offline   Reply With Quote
Old 09-15-2017, 01:01 PM   #3947
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
^run a 15mm spacer.
Anyone have any luck stretching nankang ns-20s 245/40/18 on a 18x12? Pic would help!
instagram
1on1 is offline   Reply With Quote
Old 09-18-2017, 12:47 AM   #3948
drfftn
Received my blitz back from threepiece. They're now 17x9.5 +26 and 17x10.5 +26, one of the issues I'm running into is I have Z32 brakes, which cause the fronts not to clear the calipers. Any suggestions on what size spacer to run? I would be running stock front fenders, but I have no issues with rolling/pulling or even running larger fenders.
As for the rears they fit with no issues really, but the lip of the inner barrel is very very very close to rubbing the inner fender well. I'm sure I'll need to run a rear spacer also, but still don't know what size either.
Pics for the people!
Old 09-18-2017, 10:58 AM   #3949
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
I run 225/35 on my 9.5. not what you are after, but NS20s stretch very well. the local tire guy is always surprised he doesn't have to use a cheetah.
if you are seeing others stretch that same size, but different tire, id think you would be okay.
also, these pix don't help much, but atleast you know someone is doing it with conti tires:
https://tyrestretch.com/12.0-245-40-R18/
jumpman2334 is offline   Reply With Quote
Old 09-18-2017, 01:59 PM   #3950
1on1
1on1's Avatar
I will be downsizing from 255/35 to 245/40 (slightly cheaper and common sizing) since I just received my new lips for my wheels. I'll have 3 pairs of 18x12.
instagram
Old 09-22-2017, 08:28 PM   #3951
sickmade
sickmade's Avatar
sickmade is an unknown quantity at this point
Have a question for you guys.could i get away with 18×10 +10 (225/40) 18×11 +5 (255/35) in a s13 no over fenders. Just roll and pull the fenders.
Sent from my SM-G935V using Tapatalk
Sickmade's_LS14
sickmade is offline   Reply With Quote
Old 09-22-2017, 09:40 PM   #3952
d9m13n
d9m13n's Avatar
d9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really nice
Youll have issues with the wheels hitting suspension components.
That wing looks as effective as the electoral college.
d9m13n is offline   Reply With Quote
Old 09-24-2017, 02:54 PM   #3953
speedfiend
Trader Rating: (68)
speedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to all
Feedback Score: 68 reviews
Send a message via AIM to speedfiend
Hey guys, I just recently got all of my front suspension installed on my s14. I am running z32 30mm Al front calipers and have a pair of SSR Minerva's in 18X10 +9 Lo Disk. Tried testing fitting them and unfortunately they don't clear the brake caliper. It looks to me like a 10mm spacer should get the clearance needed but Im not 100% sure. Can anyone make a suggestion as to what size spacer I should get to clear? I want the smallest spacer possible as I really dont like running spacers at all. Also, I was planning to just get the Z1motorsports hub centric spacers with ARP extended studs. Are those decent spacers or has anyone run into problems with them? Let me know what you guys think.
Thanx, Cameron
speedfiend is offline   Reply With Quote
Old 10-05-2017, 12:39 AM   #3954
Nubs
Nubs is an unknown quantity at this point
Alright. Second go round, a little more decisive on my build this time.
Need to know what offset and tire sizes I should aim for.
S13 Coupe
Front:
Around 3° camber
18 x 9 to 11
40 or 55mm fenders
Z32 Brakes
Rear:
As close to 0° camber
18 x 10 to 12
55mm Overfenders
Dual Caliper Z32 Brakes
I know theres a lot of variation in the widths but I want to keep an open mind. I apologize if I forgot anything, it's been one of those days lol.
Sent from my LG-M327 using Tapatalk
Nubs is offline   Reply With Quote
Old 10-05-2017, 12:50 AM   #3955
SlmdCpe
SlmdCpe's Avatar
SlmdCpe will become famous soon enoughSlmdCpe will become famous soon enoughSlmdCpe will become famous soon enoughSlmdCpe will become famous soon enoughSlmdCpe will become famous soon enough
S13 Coupe
Front:
Around 3° camber
18 x 9 to 11
40 or 55mm fenders
Z32 Brakes
Rear:
18 x 10 to 12
55mm Overfenders
You need to decide on widths before anyone can suggest any tires for you. ET is also going to help determine the tire size factor as well.
Buy a set of wheels, then figure out tire sizes.
SlmdCpe is offline   Reply With Quote
Old 10-05-2017, 12:51 AM   #3956
Nubs
Buy a set of wheels, then ask for tire sizes.
Alright, will do. Thanks
Old 11-01-2017, 12:03 PM   #3957
Gomes
Gomes is an unknown quantity at this point
Hey guys was wondering if you could help me. I am trying to get wheels for my car but not sure what size and offset to go with. Here are some pictures: (fenders are +60mm and +40mm, I believe)
Gomes is offline   Reply With Quote
Old 11-06-2017, 01:02 AM   #3958
haulksmash
haulksmash is an unknown quantity at this point
just picked up a set of 17x9 +22 squared TE37
can i run 245 40 17 all around with coilovers with a mild drop?
Thanks
haulksmash is offline   Reply With Quote
Old 11-20-2017, 09:39 PM   #3959
JPhamily
JPhamily is an unknown quantity at this point
Hey guys, Im new to this forum. Just picked up a 97 and would like to slam the thing. Im interested in some wheels that vrwheels.com have. Was hoping you guys can help me out on wether or not they will fit under stock rolled fenders. Wheel specs are 18x10 +3 18x11 -9
I want to rim to fender, possibly tuck in the rear but do not want to pull at all. Thanks in advance!
JPhamily is offline   Reply With Quote
Old 11-20-2017, 09:57 PM   #3960
derass
Thanks
Yup! Just takes rolled fenders and -3 deg camber (front top hats and RUCA's). You can get away with less camber if you start pulling the fenders.
edit: this info is for S13. S14 has even more room under the fenders.
