06-22-2017, 09:05 PM | #3902 |
Trader Rating: (77)
Feedback Score: 77 reviews
Only if you want your car to look like a sunken battleship. That offset will probably not even clear your coilovers to begin with. Sent from my iPhone using Tapatalk
06-22-2017, 09:10 PM | #3903 |
That's what I was afraid of. Someone local has a set of racing hart cr for next to nothing so I was gonna pic them up but was afraid of how they would look and fit.
06-22-2017, 09:31 PM | #3904 | |
Trader Rating: (77)
You can have the wheels resized/rebuilt if they're 3-pc modular and cheap enough. People do that all the time. Sent from my iPhone using Tapatalk
06-26-2017, 04:33 AM | #3906 |
My car is an S13 Hatch with no fender modifications. I would like to stay away from fender mods as much as possible.
So I'm looking to run 17 inch wheels around 9-9.5 inches with a mild stretch, good for a daily. I'm wanting to get a relatively thin sidewall. I'm getting either Fortune Auto 500 Coilovers or BC Racing BR Coilovers soon. I'm not going for tucked rim, I just want to have a small wheel gap. What tire size should I go for? I want to avoid fender mods, while having a pretty mild stretch. I was thinking 225/45/17, but the sidewall is a little thick for my taste. I was also thinking 215/40/17, but the stretch is harsh for me. Any suggestions for tire size and offset? |
06-26-2017, 10:50 AM | #3907 | |
Trader Rating: (77)
I would do 215/40 or 215/45 on 9" wide with the offset in the high 20's if you don't want to roll the fenders. Don't forget to check the clearance for the new coils as well. Any offsets over 30 may rub though. Sent from my iPhone using Tapatalk
06-26-2017, 01:24 PM | #3908 | |
My worry is the 215 on a 9J. Is it too harsh? This will be my daily driver, and there are some potholes around, just like there is anywhere. |
06-27-2017, 12:26 AM | #3909 | |
Trader Rating: (77)
With that said, 215/45 tires on 9" wide wheels with offsets between 25-30 mm.
06-27-2017, 10:48 AM | #3910 |
If you want the stretched look go with 215/40R17.
I've tried both 215/45R17 and 225/45R17 on my 17x9's and while there is a bit of stretch, it looks stupid, like you're not quite there. IMO, the tire should either be stretched or not. Somewhere in between looks like crap. I also think that stretched tires with wheel gap will look bad too. Stretched tires are only a good look if the wheel and tires are right up against the fenders. If you don't want to roll your fenders, you're not going to be able to pull off that look. |
06-29-2017, 02:44 PM | #3911 | |
06-29-2017, 03:36 PM | #3912 |
Trader Rating: (77)
Try this.... Maximum TIRE(Rubber) fitment thread https://r.tapatalk.com/shareLink?sha...3&share_type=t
07-02-2017, 02:25 PM | #3913 |
Hey had a question about fitment on a s13 coupe,
will 18x9.5 +15f and 18x10.5 +15r fit on a stock body? Fenders are rolled, and the rears are pulled slightly as well. Car is sitting on Blitz coilovers if that makes a difference. |
07-02-2017, 02:28 PM | #3914 |
wheel / tire question
I have a hatch with full kouki 180sx aero and stock f/r fenders. I bought g33 17x9 +15 wheels and am looking for advice on what tire size to run. I am not looking to slam the piss out of the car; It will be driven a few times per week to class and work. This size combo: http://zilvia.net/f/showthread.php?t=546035 seems to be perfect for dailying. Would I have to roll my fenders to an extreme to pull off that tire size with these wheels?
Thx |
07-02-2017, 07:10 PM | #3916 |
Will F:18x9.5 +15, and R:18x10.5 +15 fit on a S13 coupe w/ stock body?? I have blitz coilovers if that makes any sort of difference. Fenders are rolled, and rears are slightly pulled
I tried searching, but only found a few pictures, but nothing discussing if I'd run into any rubbing or wheels/tires hitting coils and what not. |
07-03-2017, 12:26 AM | #3918 |
Trader Rating: (77)
That's a perfect fitment for S13 stock body IMO. You will also need some camber to help the fitment besides the already rolled and pulled fenders. That's plenty of coils clearance as well.
07-04-2017, 06:52 PM | #3920 | ||
But recommended tire size for this setup? I was maybe thinking, f: 225/40/18, r: 245/40/18?? Would this tire size cause any rubbing issues? |
07-04-2017, 07:22 PM | #3921 | |
Trader Rating: (77)
You can also do 255/35 in the rear, which I will be making a switch as the next setup.
07-16-2017, 11:47 PM | #3923 | |
Trader Rating: (77)
I'd say 15mm just to be safe. I run R32 non-brembo calipers which are slightly larger than the Z32 ones and they barely clear my LO disk vs-KF's. Sent from my iPhone using Tapatalk
07-24-2017, 06:54 AM | #3925 | |
Trader Rating: (77)
Not exactly Meister but I've test fitted my VS-KF O-Disk and I needed 15mm to barely clear my R32 GTR Sumitomo. I'll try to post pics later on when I have access to them. Hope that helps.
08-03-2017, 11:40 PM | #3926 | |
Finally had time to cut the dust shields and test fit the R33 GTST calipers. Meister S13P O-disks will clear with a 3mm spacer (barely) w/c is good news for my fenders. Sent from my iPhone using Tapatalk |
08-04-2017, 11:12 AM | #3927 | |
Trader Rating: (77)
08-06-2017, 09:05 PM | #3928 |
Hey guys,
First time getting to truly ask this question on a serious side. Just purchased a set of blitz 03 off of yaj they're 17x8 +45 and 17x9 +22 that will be an on a stock body s13 w/pbm coils. Do ya'll have any suggestions on what tires to run? Based off what I'ved read on this thread I will need spacers to bring the fronts out more? Found 2 different sets of 03's that are 18x10 +22 that I thought would look nice on the rear and use the 17x 9 for the front. |
08-07-2017, 10:10 AM | #3929 | |
Granted I have 50mm overfenders in the rear but I'm fairly confident you could squeeze them on a pulled stock body. I had a 25mm spacer on the 10's with no camber and a 20mm spacer on the 8.5s with maxed camber plates. Your 8's will be about 26mm more sunk even with a 20mm spacer. But put it at zero camber and it would fit alright. Personally, I'd run the 9's up front with a 215-40 and a small spacer. My LMGT4's are the same size and I needed a 5mm spacer to clear the coilovers, which are also PBM. Then either get the 10s on YAJ and sell the 8's or just rebuild the 8's. Those are welded so you would need to cut the welds if you go that route. You could rebuild to 9.5j +26 or 10j +20 for instance. Also, so you can approximate tire size, I run 17x9 all around and have 205-40s up front (which I want to switch to 215-40s) and 225-45s in the rear.
Follow me on Instagram or don't @cason880 |
08-07-2017, 03:23 PM | #3930 | |
Talking about this If I move my cast closer to the fire wall then this starts to rub I cant find a happy balance. I doubt camber or a spacer will fix this and im not about to hammer my well because I just shaved it and its perfectly smoothed. When I move it back it doesnt hit any of the body tabs just basically the top of the firewall here |
