#3901 |
![]() Join Date: Jun 2004
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
Anyone make and sell a weld in bearing cup with a machined shank for the lca ball joint? I was going to put something together but if someone is already machining the parts no reason for me to go through the trouble.
#3902 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
First post should have the UB Machine solution.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
#3906 |
![]() Join Date: Nov 2005
I was just about to post that. So TDP front kit + Cor integration sway bar = winning?
#3907 |
![]() Join Date: Apr 2010
The only problem with the TDP kit is they don't look like they planned on running sway bar. The sway bar might hit the front section of there tension rod area.
#3908 |
Hmmm indeed it does... Although the stock stuff is really close together too, and with rca and sway bars your front end shouldn't move much hahah.
I guess wisefab is coming out with LCA's with a provision for sways.
#3909 |
TDP S-Body Suspension Kit
Hi I am Robbie for www.TDP.ie - Championship Winning Mapping the designer of the KIT. To answer the question on the front sway bar we have provision for running in and will test it soon. For drifting we dont see it as an advantage at all so far.
Thanks for all the positive comments and the suggestions. I know you are all shocked by the lover outer rod end in bending. But we have done test that prove the coil over will bend before the rod end get to 50% of its designed shear load. We feel that a captive rod end will limit the kits design and setup. Note to admin. If you feel that me posting here is against trading rules please remover my post and accept my most sincerer apologies. If you have question I will try and answer them during the week as we are just heading to BDC Day 2. Regards Robbie Thornton www.TDP.ie - Championship Winning Mapping |
#3911 |
I am new to the forum, but i read it from long time ... i registered to ask few questions in this thread ...
1. I sow wisefab kit ... i understand most of the differences from the oem knuckle, except one ... on the oem knuckle the pivot hole is inclined, but on the wisefab kit there is no inclination of that point ... the question is, why the oem is inclined, and what i lose when made straight ... as in wisefab kit? 2. Where can i buy front spindle? i see wisefab, driftworks and all other making front knuckles put new spindles, so they buy it from somewhere or make it ... if i have to make it, what material is it from ... i want to make some experiments making own knuckles, because all my car is custom, all suspension is made by us, i can shave the spindle off the oem knuckle, but i want to buy new if possible ... 3. For s14 rear subframe, do i need to make some changes( i mean the pickup points ) to improve the traction? like the s13 frame? |
#3912 | |
2. I've never seen just the spindle for sale, I'm pretty positive that all the companies have them machined new. As far as material goes, I'm not sure what would be best. 3. No, S14 subframes already have the better geometry, no changes need to be made.
#3914 | ||
A better way to approach it would be to design a front knuckle to take a bolt on hub. something like this: ![]() ![]() |
#3915 |
there is some serious stuff in this thread. super cool to read and learn. so what is the consensus of what people are concerned with when buying a kit? I've heard the term roll center thrown around. I know what bump steer is from my background in offroad, and center of gravity is a given. anyone care to enlighten me?
#3916 |
Did a little more investigating. If you go to Megan Racing's website and read the description of each control arm for the S-chassis, at the bottom there are my exact descriptions, hahahahhaa! Each and every one. They even include my tip about extending the traction rod on an aggressively lowered car.
#3917 | |
#3919 | |
Some good info on why you don't use a rod end in bending (like a ball joint replacement)
#3921 | |
![]() Join Date: Apr 2004
#3922 | |
![]() Join Date: Sep 2008
WTB: 1(one) battle version toe rod
-Mike |
#3923 |
![]() Join Date: Oct 2002
I was actually looking into doing that exact thing, but the only 2wd hubs I was finding were the GM hubs with the 5 x 4.75 bolt pattern and the larger center bore, which starts to limit wheel options.
#3925 |
Grip, that got me searching again, it looks like 350z would be a good hub to use. Anyone have some front spindle geometry they wanna share?
#3926 | |
modifying the hub to a 114.3 pattern should be easy |
#3927 |
#3929 |
And yes, I have access to all of the above, asking for dimensions was more of a joke because as nice as it would be, I really don't expect anyone to just give me that for free since it would be somewhat time consuming to collect the data then put it into cad, cam or something useable.
