Old 04-21-2008, 05:25 PM   #361
a_ahmed
a_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfectiona_ahmed is close to perfection
both cars are AWESOME! Make more pictures.
Also s14s are much easier on clearance especially in the front.. rear is not too much of an issue... There have been many 275/40/17 front s14s out there
None the less EXCELLENT cars
a_ahmed is offline   Reply With Quote
Old 04-21-2008, 05:32 PM   #362
driftyour40
driftyour40's Avatar
driftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the rough
Originally Posted by 240 OR DIE View Post
well I found out it doesnt take much to fit 275s on 17x10s up front. To get them to fit I had to do a little pull on the fenders, raised her right at an inch, also did a little bangin on the fire wall. I used a +25 offset to match rears so I can rotate tires as well as get away from staggered setups. So to clear the coilover I used a 15mm kics spacer, which left me maybe 3-5 mm clearance.....can you say tight. Heres the results
yo shit is siiiiick. Whats the camber up front?
I think my car is a little higher then yours sits right now. mine hit the inside a bit, do you have a picture of the firewall "banging", lol thanks.
Now that I think about it... are you running stock caster?
driftyour40 is offline   Reply With Quote
Old 04-21-2008, 07:48 PM   #363
DRFT180
DRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud of
edit, yeah I didn't look at the page before this
S14 Build
DRFT180 is offline   Reply With Quote
Old 04-21-2008, 08:00 PM   #364
a_ahmed
am i seeing things or did this just not get posted lol
Old 04-21-2008, 08:49 PM   #365
240 OR DIE
240 OR DIE's Avatar
240 OR DIE is making his/her stupidity well-known240 OR DIE is making his/her stupidity well-known240 OR DIE is making his/her stupidity well-known240 OR DIE is making his/her stupidity well-known
I guess he didnt see the other page lol
beat ya
Signature Exceeds 400x200 Maximum Limits set by the User Agreement!!
240 OR DIE is offline   Reply With Quote
Old 04-27-2008, 09:49 PM   #366
FusionR240sx
FusionR240sx's Avatar
FusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond repute
Send a message via AIM to FusionR240sx
i just got some 17x10.5 +24's in.
think i can fit 285/35 in the back easily?
Originally Posted by Wreckless35 View Post
still be flush dropped on KYB AGX struts & s-tech springs
WUT?
FusionR240sx is offline   Reply With Quote
Old 04-27-2008, 10:16 PM   #367
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
yes
mdhdhdhdf
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 04-27-2008, 11:22 PM   #368
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
Originally Posted by gsracer View Post
yes
mdhdhdhdf
17x10 +18 up front without spacers?
I tried pming you a few times, since you have 18x10 +18's.. to ask if you ran spacers up front, but I never got a reply.
JRas is offline   Reply With Quote
Old 04-27-2008, 11:42 PM   #369
gotta240
Will need a spacer unless your coilovers are slotted or you are stretching.. At least from my experience. I am within 5mm of coilover on a 18x9.5+17 w/ 255/35 tire
Old 04-27-2008, 11:43 PM   #370
gotta240
most likely will need a slight pull or too much camber
Old 04-28-2008, 07:30 AM   #371
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
Sounds doable, but does that tire size exist? I've seen 273/35 Hoosiers, but everything else comes in only 275/40, or sometimes 285/40 or 295/40.
Were you at the meet at Saturday?
turtl631 is offline   Reply With Quote
Old 04-28-2008, 11:33 AM   #372
FusionR240sx
yea actually i meant 275/40 and 285/40.
typo my bad.
naw i didn't go. i went to isu for "mayday"
it was pretty gay.
i woulda rather gone to the meet.
how about 265's on a 10.5"?
i don't really want a stretch at all.
but also don't wana get over fenders or anything.
couldn't afford them anyway
WUT?
Old 04-28-2008, 10:23 PM   #373
turtl631
I think 275/40 on 10.5 +24 should be okay if you have rolled or perhaps slightly pulled fenders, depending on your camber and ride height. With around -1.8* camber and 17x9 +17 with 245/40 on my S14, the tires are pretty close to the (rolled) fender lips. My car is too low in back though for my tastes- if you're the drifter type, it's probably average or a bit high, but for a track or street car, I think it's about 1/2" lower than it should be.
Old 04-28-2008, 11:16 PM   #374
hustlervibes
Banned from the Marketplace
hustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfection
Send a message via AIM to hustlervibes
Gonna need some pull.
I'm running 18x9.5 +25 with a 275 with rolled fenders. With that I'm about 5mm from the fender (lowered on springs at the moment)
It should fit fairly easily if you don't have a problem pulling them out a bit or running some negative camber.
hustlervibes is offline   Reply With Quote
Old 04-29-2008, 05:31 AM   #375
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
Do you guys think I can stuff some 255/40's on my 17 x 9 +0 offset wheel in the front of my s13? I am running 20mm Origin Front Fenders. I currently have 215/40's with some room to play still. I can still add camber and I still have some fender clearance. But if I have to run added camber just to fit a wider tire does it not make it worth my time? I want the most contact patch possible now. But unfortunately I have 0 offset wheels.
SuicidnS13 is offline   Reply With Quote
Old 04-29-2008, 05:53 AM   #376
a_ahmed
why +0, im gona be running +17 and ill still need to pull front and rear, wtf?
Old 04-29-2008, 07:22 AM   #377
bloodangels13
bloodangels13's Avatar
bloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of lightbloodangels13 is a glorious beacon of light
Send a message via AIM to bloodangels13
I finally bought the wheel/offset guage i found on summit racing so this past weekend i expiremented with wheel size in the rear on my car.
(a lil info) s13 coupe with 20mm front fender and origin 30mm rear widebody
i still need to measure the guage to determine tru offset but I was able to simulate a 18x11 with what im guessing is about a +18 thru 22 offset with a 315/30/r18 will clear. Thats with sus under full and partial compersion with the closest thing to the wheel is a small spot on the forward section on the lower control arm. About 5mm clearance. If it causes any issues I will jus notch it and weld in a reinforcement .
Ill take pics in the next day or two with the gauge on the car to show clearance. The tire ill poke out a bit, probly only like 10mm at the most but o well. Ive yet to try the front but i will more then likely eventually run a 17x9 +18 and continue to run a 255/40
now the main thing is what wheel options do i have that offer custom sizeing upon request? so far there is only a few that i even like but nothing that really does for me. Any help is greatly appreciated
pics of my car to help with suggestions
almost forgot to mention (already posted but o well)
current setup
fr 18x8.5 +35 with 15mm H&R spacer 255/40/r18 falken RT615
rear 18x9.5 +22 275/35/218 falken RT615
---R.I.P. David Mario Brandt ----
Originally Posted by ThatGuy View Post
This post was brought to you by the number: Rum
And by the letter: Go Fuck Yourself
And also by viewers like you.
Last edited by bloodangels13; 04-29-2008 at 08:29 AM.. Reason: tire size correction
bloodangels13 is offline   Reply With Quote
Old 04-29-2008, 08:07 AM   #378
a_ahmed
^17x9 +18 and continue to run a 255/35 ??
There are no 255/35/17 that I know of.. maybe some R Comps but not regular tires like falkens.... I love your car btw. Very cool.
Old 04-29-2008, 08:27 AM   #379
bloodangels13
oops i ment 255/40/17
Old 04-29-2008, 09:47 AM   #380
a_ahmed
ah okay, thats cool. 255/40/17 is perfect for our cars UFFF I should have mine God willing hopefully by the Saturday... so long of a wait lol...
Old 04-29-2008, 01:43 PM   #381
LS240
LS240 is just really niceLS240 is just really niceLS240 is just really niceLS240 is just really niceLS240 is just really niceLS240 is just really niceLS240 is just really niceLS240 is just really niceLS240 is just really nice
BloodangelS13, check out CCW wheels. They'll pretty much make any size with any offset with any of the available bolt patterns. Sexy wheels too, especially the Classic.
http://www.ccwheel.com/files/home.php
LS240 is offline   Reply With Quote
Old 04-29-2008, 01:47 PM   #382
a_ahmed
Yeah but they are also 2200$ not bad kind of considering the quality and almost unlimited choice of sizings and offsets...
J-rho ran them on his s13 (pictures in my first post) and aceinhole runs them on the rears of his car.
There was even one guy in here with a 16" ccw classics set of wheels in this thread if i recall
Old 04-29-2008, 02:10 PM   #383
bloodangels13
im ganna do some diggin around performance shops while im in Thialand in June to see if i can find some wheels the sizes i want. i have a few connections where i can get em shipped over without tires for decent price.... hopefully i find something sexy
Old 04-29-2008, 05:50 PM   #384
FusionR240sx
thanks man. yea i can deal with SOME negative camber. don't wana pass -2 really tho.
yea it's pulled and rolled a lil bit already.
i used to have 17x10+12 fn's with 255/40's tucked under the rear pretty good.
thanks guys. maybe i'll just go with a 275. would a 265 look stretched on a 10.5" wheel?
maybe i could do 225 or 235 fronts and 265 rears?
idkkkkkkkkkk
guhh
WUT?
Old 04-29-2008, 06:40 PM   #385
SuicidnS13
SuicidnS13's Avatar
LOL I allready own the wheels(Hotwheels 68's). I allready have the rears pulled to clear with no worries at all. +17 is only a little more than half an inch difference in spacing. My question is the front. I know 245's would not be a problem but what about taller 255/40's?
Old 04-29-2008, 09:07 PM   #386
turtl631
Fusion, if 17x10+12 cleared fine, 17x10.5 +24 is going to be 6mm further inboard. With the 275, you'll be perhaps 15mm further out than you were with the 255s. I think it should be doable. 265 doesnt really exist in 17s, there are only a few offered.
Old 04-29-2008, 11:06 PM   #387
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Anything wider than a 10" wheel in a 17 is useless anyways as I have not come across any tires worth running wider that 275 in 17".
Old 04-30-2008, 01:10 AM   #388
LS240
It'll be 12mm further inboard, not 6.
Old 04-30-2008, 01:46 AM   #389
ayuaddict
ayuaddict's Avatar
17x10 +12
17x10.5 +24
difference in offset 12mm
difference in width ~6mm
the 17x10.5s would stick out 6mm further not accounting for offset, but however because the offset is 12mm higher on the 17x10.5s and -6+12=6 the 17x10.5s would be 6mm further inboard.
Old 04-30-2008, 02:06 AM   #390
gotta240
Yes, listen to the man above. He is 100percent correct.
Don't believe it? Search for wheel offset calculator.
