03-18-2012, 12:03 PM | #3781 |
wheel and tyre clearance yo!! haha not the sump and yeah iam using that crappy old ruckus racing shizzle. tbh though i sits the engine nice and low and hasnt broken yet, going strong since 09
[SIGPIC][/SIGPIC] |
03-18-2012, 12:07 PM | #3782 | |
Haha to be honest it still looks fairly ok in pics when its squating lol
[SIGPIC][/SIGPIC] |
03-18-2012, 02:10 PM | #3783 |
That's a neat front wishbone there Swiftmini, here is what I am working on:
Only the lower control arm is correct in that picture, wheel is at 64 degrees compared to control arm so clearence with control arm is good, however I have no way to measure clearence with the body. Wisefab arm is super wide to compensate, mine isn't because I don't intend to have that much steering lock in the first place. There is also a lot of work to be done on reducing the mass of the it. I am thinking of making it thinner and 3 dimensional with tall edges like this arm: |
03-19-2012, 08:36 AM | #3784 |
Thanks man, iam happy with them. They do exactly what i want
Thats a neat design of lca but 64* is insane for trailing wheel!! I haven't a clue how much angle my setup achieves! It's more than enough. Too be honest over the last 2 years i have tweaked abit here and there, I have managed to get considerable more lock BUT its barely noticeable imo. I think going as extreme as wisefab isn't really needed. I think once you get to a certain point the steering becomes less important than other things, like front to rear grip differential, and I believe that i want excessive camber increase on full lock so the front slides better. Just my opinion based on my driving style lol
[SIGPIC][/SIGPIC] |
03-19-2012, 11:50 PM | #3786 |
I got my hands on the Newest Drift works knuckles with their Black Zinc coating!! and it looks like the fixed the issue using a drum e brake(no more cable issues)
I got them from Brad at GroundWerks Garage |
03-20-2012, 10:03 AM | #3787 |
how long did it take for you to get them?
and that new coating looks so much better than the old. i may have missed it but does anyone know if they have a version or are planning a version with a bracket for a second rear break caliper? |
03-20-2012, 11:09 AM | #3788 | |
is there room now for the axle seals? they look a lot better but too bad they're using off the shelf tubing and those gross bushings |
03-20-2012, 03:38 PM | #3789 |
i doubt they will add the extra tabs for 2nd calipers! On Powers car they used a plate between the hub and knuckle, 10mm plate i think.
Dunno about drum brake, i have read it doesnt work so good upside down! maybe look on the driftworks forum, i dont really go there any more
[SIGPIC][/SIGPIC] |
03-21-2012, 09:26 AM | #3791 |
03-21-2012, 02:23 PM | #3792 |
is there a general amount to add to the LCA to get certain amount of camber?
i think my chassis needs to be straightened out but i have -2.5 on driver side and -3.5 pass side. But im looking to redo my front end for knuckles/rack move, etc and would like 4-5 degrees. |
03-21-2012, 04:52 PM | #3793 |
If anyone happens to know, can you please tell me what the ratio is for an S13 steering rack, normal and HICAS, how many turns lock-to-lock, and what the rack travel distance is?
Possibly pinion angle and spline specifics, and inner tie rod bolt size and thread. I want to have a quick ratio & longer travel manual rack made, and it would be nice to at least have specific numbers to go off of. Cheers. |
03-22-2012, 12:27 PM | #3795 | |
HICAS - 2.6 Non-HICAS - 3.1 Ratio HICAS Steering Rack Ratio: 14.9:1 Non-HICAS Steering Rack Ratio: 17.0:1 |
03-22-2012, 05:22 PM | #3796 |
I should probably take pics later to help with this but. I have PBM tie rod spacers on both sides and George's rack spacer on the passenger side. To the left at lock the tie rod hits the bump stop on the control arm, so it's getting great angle. But to the right, it hardly gets any more than stock and that doesn't make sense since that's where the big spacer is located?
03-23-2012, 02:39 AM | #3798 |
I decided to start working on some old prototype rlcas. Iam gonna make these work for testing purposes and then make some fresh ones with some changes.
I will be ditching the outer rose joints and replace with sphericals and cups. Inboard I can't decide whether to use rosejoints or make them non adjustable and use sphericals! Next ones will be lighter materials
[SIGPIC][/SIGPIC] |
03-23-2012, 04:09 AM | #3800 |
Yeah man they are really hench, far too over built lol.
Yeah sphericals to remove rosejoints in bending and add some stiffness. I might just start from scratch right away
[SIGPIC][/SIGPIC] |
03-24-2012, 11:39 AM | #3804 | |
Sorry that I haven't updated the main post guys, it's beginning to look REALLY old now. I'll try and get on that this week.
03-24-2012, 04:20 PM | #3805 |
It's smart SPAM. I've been reporting them like crazy.
S12 || KN13 || S13 || B16 |
03-24-2012, 07:25 PM | #3806 |
Along with the above:
This image shows the back side of the support structure for the arm mounting points. This image gives you a perspective on just how far in and how long the lower arm is: Pretty interesting stuff.
My Website | Unfriendly Garage | Endurance Motorsports | FitMyWheels - Fitment Calculator |
03-24-2012, 07:26 PM | #3807 |
Can anyone identify those front knuckles?
03-24-2012, 11:22 PM | #3809 |
Nope :/
