12-17-2010, 04:19 PM | #3693 |
this is the write up to install a walboro...but i'm sure you can find the tank from here. Driftopia Tech Blog » Blog Archive » Walbro 255lph Fuel Pump Install (s13 240sx) google my friend....google. then images. |
12-17-2010, 04:33 PM | #3695 | |
just saying.....you might want to use that search feature in the top right....people don't like spoon feeding on here, and you my friend, are asking questions that google can answer. just search. this website has everything....and the more you ask, the more people are gonna tell you to fuck off and search yourself. just a heads up. |
12-17-2010, 04:55 PM | #3697 | |
for your fuel tank i googled :s13 fuel pump install to see what goes into a fresh rebuild i would google : step by step fresh rebuild and i'm sure they would talk about gas in one or another builds...doesn't have to be a 240....all rebuilds should be done relatively the same way. (in the idea of new rings/pistons ect...don't need part numbers for this) and regarding your 2000 other poeple...yes, that could be said as well...but you have asked what....three questions now...and each of them "I" searched less than 30 seconds for. not trying to be a dick....but if you had 1000 posts on here...it assumes credibility that you know how to work the site. and I'm going to assume that you don't. So instead of give you the link...i'm teaching you how to search. Kinda like paying someone to make a cage....when I'm teaching you how to bend pipes and use a welder...now you know how to make a tube chassis.......;D |
12-17-2010, 06:23 PM | #3700 |
12-17-2010, 06:29 PM | #3701 |
Trader Rating: (22)
Feedback Score: 22 reviews
If you boost at 20psi normally in an SR per say and your IACV gets clogged up and after a little bit you notice a huge drop in boost to maybe like 3-5, can just your IACV clogged alone cause this or do you have a boost leak as well? This happened to me a couple days from deployment and I wasn't really able to check so thats why I have such a dumb question lol. I'm trying to just narrow down if it's IACV is clogged really bad, I have a boost leak, or if my BOV is too loose and I need to tighten it up. I've looked it up and googled it but I just wanted personal insight from other members. Thanks.
Driftphreak87 |
12-17-2010, 07:55 PM | #3702 |
Trader Rating: (26)
Feedback Score: 26 reviews
searched but no luck..
can anyone direct me to an in depth write up on how to replace a head gasket on a kade? I'm mainly worried about fucking up the timing..
12-17-2010, 11:05 PM | #3703 |
Z32 26mm clearance
I've searched till i've finally given up.
I'm looking at a set of super advan wheels that are 16x7 +35 offset. will these clear z32 26mm calipers? i do know that 17s will clear the calipers, but i'd rather have 16s if they'll clear em. and also will 17" Drag DR-31 fit? thanks |
12-18-2010, 12:41 AM | #3704 | |
O'Reilly's or w.e has a bunch of stuff like that (they have s13 ones so i'd assume 300zx also) and they come with warranties
street dancer. GLEAM |
12-18-2010, 08:43 AM | #3706 | |
how to change head gasket on ka24 : 240SX Technical Forum might want to cross reference that because it's nico. |
12-18-2010, 09:44 PM | #3709 |
Where/what does this go to. Before i put my sr20 in
Thanks! I actually have my dad that works on metal, maybe he can do it for me.
12-18-2010, 11:22 PM | #3710 |
I am starting to run my boost/ vacuum lines on my rb swap and I am kinda stuck.
I have a manual boost controller, which I assume goes to the port on the acuator. then what about the 2 ports on the bov and the one sticking out of my intercooler piping? which goes where? This is what I can come up with. From IM to top port on Boost controller,then bottom port goes to the tee that came with the BC, one side goes to the acuator, the other goes to the boost gauge? then another line from the IM to the BOV then from the BOV to the Intercooler piping? I am not sure if it's correct, just taking a guess. Also would there be a problem with the boost if I ran the controller into the interior? I know most are in the engine bay, but I wanted mine mounted by the driver seat.
12-18-2010, 11:40 PM | #3711 | ||
Trader Rating: (18)
Feedback Score: 18 reviews
Manual boost controller should go between the nipple on the intercooler piping and the wastegate. Bov should see intake manifold pressure so it knows when to relieve excess pressure from the intercooler piping. Boost gauge should be hooked to intake mani as well so you know how much vacuum you are pulling. not sure about the second connection to bov, what brand/model? Anyways, I would recommend against running your boost controller all the way into your cabin. The skinny tubes used for that thing need to be as short as possible because when they get long they cause really weird drops in pressure and stuff. I'm pretty sure about this but maybe someone who has done it can testify.. |
12-19-2010, 08:11 AM | #3712 | |
I have heard about it being ran far and problems with it. I just wanted to double check. Thanks man.
12-19-2010, 09:05 AM | #3713 |
I tried google'ing a few pictures but hadn't really found anything..
I want to swap it back in today, but i hadn't got any responses on this yet.. Hopefully someone can answer all these simple questions i have to ask. Come on sr swappers! please?.. Thanks! # 1 )The red wire that has something that goes somewhere on end, and a tube sticking out... on tranny. Better pic of it #2)top right of the circle/ accelerator part of manifold something screws into their i have the bolt but don't know what.. really silver on outside to help locate #3)Big bolt on top of timing belt beneath the head something obviously/ probably goes their but what? Two more on block that probably has something to do with that big bolt, but screws in. locations around front cover #4 Does power steering circle bracket thing need to be on before engine goes in or can i put engine in then bolt the three bolts on ? THE SITUATION (: |
12-19-2010, 12:59 PM | #3714 |
Are there really any noticeable gains from a short ram intake? Compared to a stock intake on an S14 KA. I thought about getting an AEM short ram intake, but then I realized 130 is kind of steep if I don't get much out of it.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
12-19-2010, 01:25 PM | #3715 | |
12-19-2010, 02:57 PM | #3716 |
I would never have thought of this sir, i thought it'd connect to something and i really appreciate your words.
Would you happen to know what goes on #3? That one would be hard to get to once the engine is in. And can i bolt up the power steering after the engine is in, or? I really, really appreciate it sir, thanks! |
12-19-2010, 05:10 PM | #3717 | |
AFC #1
http://www.turboneticsinc.com/sites/...les/Raptor.pdf You will not blow off or have any boost control with that setup.
12-19-2010, 09:53 PM | #3718 |
s13 sr20 redtop lower harness has left me with 2 extra plugs..am i using the right lower or should i be using the ka's harness?
MORE BACON STRIPS |
12-20-2010, 12:03 AM | #3720 |
I bought some bride seat fabric and i wanted to reupholster my door inserts. I tried searching on how it's done and all I found was that if your prior inserts are fine, use a strong adhesive and more or less glue the new fabric on? i also planned on doing the back seats and a shift boot. However there isnt really many custom interior shops in saskatoon that I'm aware of. If anyone could give me any pointers that would be much appreciated. Thanks.
