03-13-2014, 10:34 PM | #3661 |
what harness? apparently with wiring specialties [harness i have] they already have the wires ready and labeled to be hooked up. was wondering if anyones done it. you got the martin crawler speed sensor adapter too?
Follow on Instagram For The Latest Imported Inventory!: @2JOHNZ_GTE |
03-13-2014, 10:40 PM | #3662 | |
Edit: Just looked back at my notes and tach signal is pin F12 off of the body loom plug. You connect this to the Dakota box, from there to your tach. |
03-14-2014, 07:50 AM | #3663 | |
Trader Rating: (53)
Feedback Score: 53 reviews
03-14-2014, 09:58 AM | #3664 | |
Sent from my Nexus 5 using Tapatalk |
03-14-2014, 12:41 PM | #3666 |
Freed Mounts for sale - S14! Bump my thread if you take a look!
Thanks! http://zilvia.net/f/showthread.php?t=558333
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
03-14-2014, 12:55 PM | #3667 | |
Link to project - http://forums.nasioc.com/forums/show....php?t=2285887
03-14-2014, 01:33 PM | #3668 |
Hey guys how far should my wideband be from the back of the turbo? Gonna be running an innovate wideband as my O2 - no narrowband (AEM v2)
03-14-2014, 01:35 PM | #3669 |
03-14-2014, 06:00 PM | #3670 |
Trader Rating: (53)
Thanks for all of the information on the fuel hoses guys. Can i not clamp the open ends directly over the smooth barbs on the S14 OEM fuel pump assembly? Like will i have to terminate the twist-lok line with an AN fitting and then use an AN-to-barb adapter and then connect the two barbs using regular fuel hose?
03-14-2014, 10:05 PM | #3671 | |
03-14-2014, 10:11 PM | #3672 | |
03-16-2014, 05:51 PM | #3674 |
I think I need a fuel cut defender...
Running stock twins with an ebay y-pipe/downpipe, and straight blast pipes (all 3 inch no mufflers etc.)... FMIC, standard stuff, JDM Supra TT ECU. If I hit right around 6-6200rpm my car will cut really bad for a brief second, I let off the gas a little bit, and get back on it and its fine until I hit 6-6200 again...... Is this boost cut? I believe im boosting around 18psi but not 100% sure. It also idles rich, like 12.1-12.3 on my wideband, and varies at throttle anywhere from 12.4-13.1 or so.... stock FPR and walbro 255 Last edited by xoxide; 03-16-2014 at 06:37 PM.. |
03-16-2014, 08:58 PM | #3675 | |
Idling that rich at idle probably means you have a vacuum leak somewhere post throttle body. Could also be the reason for the hiccup. |
03-16-2014, 09:01 PM | #3676 |
Trader Rating: (53)
Correct me if im wrong but doesnt the factory ECU cut fuel after 14lbs of boost? I could have sworn that i read somewhere that if you are using the stock ECU it's always best to get a fuel cut defender.
03-17-2014, 08:15 AM | #3679 |
Im not terribly concerned about the rich condition... Id rather it run rich than lean lol.... Main concern is the cutting.... Going to perform a boost/vac leak test today some time... I thought the 2j cut was 17psi? Could be wrong though.
03-17-2014, 05:56 PM | #3681 |
Also, noticed quiet a bit of oil blasted up on my firewall.. I felt around and it seems like most of it is coming from the bottom of the stock TT hotpipe... Took an IC pipe off and there is oil blown on the inside of the piping (not a TON just enough to make everything slightly covered).... What would this indicate, blown turbos?
03-17-2014, 08:22 PM | #3682 |
Trader Rating: (18)
Feedback Score: 18 reviews
I'm using Freed mounts. I have 1" of clearance from the head to firewall per digital micrometer.
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
03-17-2014, 08:27 PM | #3683 | |
I'll measure mine tomorrow - I think that's about where I'm at as well. Get nuts lab brackets and custom 2" aluminum mounts
03-18-2014, 06:20 AM | #3684 |
Thanks, looking to switch my eBay brackets later down the road and it'll be between Get Nuts Lab and Ben Freed.
*Also, those with Tweakd and Wire Specialties harness did you have to run your fuel pump off a separate relay? Or does it just come on like the stock harness? I have a Chasebays ( ._.), sent it out to get "fixed" and of course it still doesn't work. Not sure if it's because I swapped everything into my s13 vert (I did the whole 5sp swap before hand) or just the harness itself.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
03-18-2014, 11:35 AM | #3686 |
My thoughts exactly. They (CBs) is for certain that it will with one of the unused slots/pins on the ecu. I've studied the ecu pinouts so many times that I could make my own harness but I can't due to work schedule.
03-18-2014, 12:31 PM | #3687 |
I have a Tweaked harness and it came with a built in relay for the fuel pump. Turns on just like it always has!
03-18-2014, 12:38 PM | #3688 | |
I believe my wiring specialities also has this same deal - there are 1-2 relays right next to the ECU probably for this as well. Car starts up no issue with stock ECU / AFC NEO
03-19-2014, 08:50 AM | #3689 |
Something else id like to get worked out before the next event....
I remember reading JZ's run hot, but sitting on the grid my water temp is around 190ish on a hotter day, 180 on a cooler day.... After I go for a run and come back to the grid my water temp ranges from 220-250 and then lowers back down to 180-190.... It doesn't seem like it should be getting that high? I have a Koyo 2 rod radiator, dual 12 inch flex-a-lite pusher (normal configuration) fans, stock t-stat, distilled water, and problend motorsports 40 below water additive. 1.1 bar radiator cap. Any ideas on what I can do to get it to run cooler? There are no air bubbles in the system, ive bled it multiple times, and top off the water after every few runs if it needs. |
03-19-2014, 09:21 AM | #3690 |
lower temp t stat will help you greatly. My cruising temps stayed at 180F but when I romp on it I noticed with the lower temp t stat my temps dropped about 20F cooler than with the stock stat
I'm using a forged racing tstat. I would have gone TRD if it wasn't insanely priced at $120 |
