Old 12-04-2010, 06:03 PM   #3571
facepalm
facepalm is an unknown quantity at this point
hey guys i need to figure out where the clips go on a Navan skirt. I got a 95 240 but there are no mounting holes corresponding to the clips
as you see there are hangers and plastic rivets that mount onto the hangers, but there are no holes in the body to clip the plastic rivets into. Any help?
thanks
facepalm is offline   Reply With Quote
Old 12-04-2010, 06:11 PM   #3572
240sx123$
240sx123$ is an unknown quantity at this point
Drill holes. Problem solved. Just kidding.
Question about Q45 brakes- i read that the 240's abs sensor is in the spindle/hub, as opposed to on the caliper. Does that mean I can just remove the sensors that are on the q45 caliper?
240sx123$ is offline   Reply With Quote
Old 12-04-2010, 06:25 PM   #3573
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
Looking for shorter radiator that'll fit in s13. Want to do mid mount intercooler setup with pipes going on the sides of the radiator, pretty similar to Max setup but want to keep functional flip lights. Does anybody have experience with aftermarket radiators for other cars that will fit that project?
cured13 is offline   Reply With Quote
Old 12-04-2010, 07:07 PM   #3574
Drummer
Drummer is an unknown quantity at this point
what does welding up a Dif do?
Drummer is offline   Reply With Quote
Old 12-04-2010, 07:47 PM   #3575
240sx123$
Makes the rear spin posi (both rear wheels). It completely LOCKS the left and right rear wheels to one another, so while the positive is two wheeled burnouts, the negative is that those two wheels arent allowed to turn at different speeds, which can be noticeable when going around tight turns. A limited slip differential (LSD) locks the rear wheels only when they break traction. This allows the car to go around turns without skipping, as many welded difs do.
Welded difs (generally) are best suited for track/drift only cars, but there are plenty of guys who rock them on the street. I like a comfortable ride in my semi-performance vehicle, so i stick with a semi-performance dif.. the vlsd. Best of both worlds in my opinion, when taking into consideration of cost, comfort, and performance.
Old 12-05-2010, 01:39 PM   #3576
Mangudai
Mangudai's Avatar
Mangudai is an unknown quantity at this point
What are these two lights offically called? Also, what bulbs do they use?
Almost there.
Mangudai is offline   Reply With Quote
Old 12-05-2010, 01:51 PM   #3577
rwdaccordswtf
rwdaccordswtf's Avatar
rwdaccordswtf is an unknown quantity at this point
Send a message via MSN to rwdaccordswtf
the front ones are blinkers the side ones are side markers no idea the bulbs
rwdaccordswtf is offline   Reply With Quote
Old 12-05-2010, 06:05 PM   #3578
chris_240sx
chris_240sx is an unknown quantity at this point
^ I think the turn signals are called winker lights.
I live in Missouri and it's in the 20's in the mornings and getting colder.
I run 10w-30 in my SR. Is it too thick?
It seems like it to me, but I saw people up in Jersey running like 15w-40 or something so I can't tell if I'm being overly sensitive about it. I just don't wanna cause damage by not doing something so simple as switching oils.
chris_240sx is offline   Reply With Quote
Old 12-05-2010, 06:53 PM   #3579
S14DB
AFC #1
S14DB's Avatar
If you are starting your car in below 32F weather I would switch to 5w-30 for the winter.
Old 12-05-2010, 06:55 PM   #3580
.emerson.
.emerson. is an unknown quantity at this point
Can anyone provide me with basic instructions to install Navan sideskirts?
-I really don't want to drill holes in my car.
-the rear part of the skirts have holes but when I look at my rear fenders there is no place to screw.
.emerson. is offline   Reply With Quote
Old 12-05-2010, 07:10 PM   #3581
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
will I need hubcentric rings for my enkei rpf1's on my s14?
18x9.5 +15
If I do, know where I can get some?
Thanks
-duder
dudermagee is offline   Reply With Quote
Old 12-05-2010, 08:31 PM   #3582
chiboy002
chiboy002 is an unknown quantity at this point
18x9.5 +15
Thanks
-duder
hubcentric rings have no relation to offset/width. If the hub bore is greater than 66.1 then you'll need a hubcentric ring for the car not to shake at higher speeds. If its smaller than 66.1 then wheels won't mount right
Varrstoren sells some, but idk enkei's sizes so they might not fit
touge factory sells some too iirc
street dancer.
GLEAM
Old 12-05-2010, 09:05 PM   #3583
chiboy002
Originally Posted by chiboy002 View Post
can anyone help me find s13 5-lug front hubs?
I'm planning on going with the OEM s14 ones on fr-sport, maybe have my old bearings pressed in but probably just buy new everything.
I heard good/bad stuff about ichiba, i can't justify buying oem rears and going with completely shitty-looking front hubs.
I also don't want to buy all that shit and have to get flca unless its the only option, cause i don't want a new alignment
round 2
msglnght
street dancer.
GLEAM
Old 12-06-2010, 01:11 AM   #3584
dorifto_demon
dorifto_demon is an unknown quantity at this point
i`m not sure whether this is the appropriate place to ask this..
anyway..
sr20det typeX (J4 ecu) in a s13 hatch..
what can cause the ecu to send more than 5v to the sensors?
5.12v to be exact..
this is the supply voltage to the tps..
the tps keeps on blowing out..
i measured the supply voltage that goes to the ect (engine coolant temp)..
it shows 4.89v..
if the power is shorted to positive, it would give 12v right?? (or whatever the batt voltage is)
i`m stumped.
any help is appreciated..
thanks
dorifto_demon is offline   Reply With Quote
Old 12-06-2010, 11:27 AM   #3585
JKL1031
JKL1031 is an unknown quantity at this point
95 s14. Does the horn suppose to sound when u lock the doors with the remote fob?
JKL1031 is offline   Reply With Quote
Old 12-06-2010, 11:41 AM   #3586
S14DB
AFC #1
S14DB's Avatar
Is it the horn by the grill sounding or the horn by the brake master?
Old 12-06-2010, 12:18 PM   #3587
ksemar
ksemar is an unknown quantity at this point
Would Work Emotion XD9 18x10 +18 clear z32's up front on an s14. I'd imagine there would be alot of hammering to get them to fit up front anyone have any experience?
ksemar is offline   Reply With Quote
Old 12-06-2010, 12:25 PM   #3588
JKL1031
Neither of those sound when i lock the doors. previous owner said he put in another horn besides the stock one, but maybe he meant he replaced one. I do only see those two horns. I can get the horn to sound off with the panic button, but im curious if one of them should sound when the door locks as well.
Old 12-06-2010, 01:37 PM   #3589
S14DB
AFC #1
S14DB's Avatar
The hazards should just flash twice.
When the alarm sounds both horns should go sound and the headlights should flash.
Old 12-06-2010, 01:52 PM   #3590
xBtony
xBtony's Avatar
xBtony is an unknown quantity at this point
Originally Posted by xBtony View Post
Whats the best timming setting for a single cam ka, if im lookin for only performance?
really no one one can help me out? I know stock is 15BTDC but i know u can advance or retard it slightly to get a little more performance out of it. I just cant remember which one. haha
xBtony is offline   Reply With Quote
Old 12-06-2010, 03:27 PM   #3591
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
If you have a s14, OEM s14 front hubs WILL NOT FIT. They have a different bore size, I believe the OEM front hubs are too large in circumference.
What do you mean by "shitty-looking" front hubs?
For the record I had Ichiba hubs and had no problems.
This was my car I built last year
HS13KLS is offline   Reply With Quote
Old 12-06-2010, 10:51 PM   #3592
WERDdabuilder
WERDdabuilder's Avatar
i removed my turbo/mani and put the bolts/etc in a bag. i see that there is a rubber washer...but have no idea where it goes. maybe i just picked up a randomly off the ground? any help will do..
When the power of love overcomes the love of power, the world will know peace
Old 12-06-2010, 11:16 PM   #3593
chiboy002
i mean like, shitty quality. I've decided to go with attain, case closed! thanks anyways man
street dancer.
GLEAM
Old 12-06-2010, 11:59 PM   #3594
jdmjap808
jdmjap808's Avatar
jdmjap808 is an unknown quantity at this point
this is the deal. couple of my studs broke off on my wheel hub and i was wondering how can i make the stud "seat" sit in all the way without a press and or taking out the hub?
jdmjap808 is offline   Reply With Quote
Old 12-07-2010, 12:32 AM   #3595
S14DB
AFC #1
S14DB's Avatar
Washers and a lugnut.
Old 12-07-2010, 01:31 AM   #3596
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
+ impact gun for fast and best result
REVIEW
killer240 is offline   Reply With Quote
Old 12-07-2010, 04:48 AM   #3597
TheEightyNine
TheEightyNine's Avatar
TheEightyNine is an unknown quantity at this point
acouple of brake related questions...
-Can i use a usdm s14 front brake caliper on an s13? Ive heard people say they are the same, but ive also heard its not safe to have one s13 and one s14 caliper on at the same time. Need to replace my front drivers side caliper and have a good s14 caliper
-When looking at used brake calipers what are the main things your looking at to determine if they are good or not?
thanks
TheEightyNine is offline   Reply With Quote
Old 12-07-2010, 10:55 AM   #3598
BoostinEuros
BoostinEuros is an unknown quantity at this point
Will silvia sideskirts and valences fit my hatch?
BoostinEuros is offline   Reply With Quote
Old 12-07-2010, 12:02 PM   #3599
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
thanks
13 and 14 brakes are the same.
make sure all the parts are there, not broken and check the seal around the piston.
the valences won't directly fit and i'm not sure about the skirts. i've been told they're different, but never tried fitting them.
c72c is offline   Reply With Quote
Old 12-07-2010, 12:28 PM   #3600
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Where can I get 16 or 18 guage Wire, 30Amp toggle switch or button, (2)Male and (5)Female blade connectors? My friend wants me to help him put in a toggle switch to do the lazy eyes to his headlights.
For Sale #1 | For Sale #2
