03-26-2014, 07:49 AM | #331 |
Something behind the timing belt cover? Maybe the water pump gasket or the pump seal failing? I'm just grasping at straws, I'm not at home so I can't really look at my engine to give you any ideas.
03-27-2014, 09:50 AM | #335 | |
What trans are you running? I have a full set up for a ka/sr trans that has brand new ACT lightweight flywheel and pressure plate. Just needs a disk. I only mounted it, car never ran. Let me know if you need it! Sent from my SAMSUNG-SGH-I337 using Tapatalk
Instagram @CheddarCheesus I hope you're offended |
04-02-2014, 09:00 AM | #337 |
So here's that hole where the water was coming from. After a brisk cleaning I realized it was a hole in a plastic cover.
So, after downloading a tutorial on waterpump replacement from ClubLexus I started removing stuff until I could see the waterpump... behold, a $2.00 freeze plug is going to cost me $150 to replace the entire waterpump. Looks like it's been leaking for a while too. Oh well, at least I'll have peace of mind. Looks good without any of the front covers
'05 350Z Vortech @ 12 psi (SOLD ) '89 240SX 1UZ (turbo?) coupe |
04-06-2014, 07:22 PM | #348 |
I run no front sway in my s13 coupe. Running on HSD coils. Drifts like a beast. Has no understeer issues. No sway, no problem. Plus you get more clearance for steering lock lol
04-07-2014, 10:46 PM | #350 |
What spring rates are you all running?
Still need to pick up my transmission adaptor any suggestion because I've heard of fitment issues with the Collins adaptors. Also anyone running the ka transmission how much did you shorten your driveshaft by |
04-09-2014, 12:22 AM | #352 |
I'm running a Sikky sway on my s14. Can't vouch on anything yet since the car is not finished but it's super beefy and clears the oil pan no problemo. Still debating on cutting and redirecting my the headers myself or buying some from turtle
04-11-2014, 12:22 AM | #357 | ||
1. it cost more since its in newer motors. A lot more on that note. 2. It's a iron block. 3. there's no real advantages from 1uz to 2uz
04-11-2014, 12:01 PM | #358 |
Eh I have 2 2uz engine that i got each cheaper than my 1uzfe. I just dont know what I'll do with them. One I think I'm going to swap NA into some old toyota pickup and drive it around like that. But then I'd have to swap the fbw throttle body to a throttle cable setup. The rods are weaker but the head flows better than than non-vvti 1uz. The block adds 82lbs i think.
