Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
08-12-2010, 06:58 AM | #331 |
Don't think only about the money that is going into the swap, the more money you put on your engine, the less you have for drifting.
I rather have my KA and drift 2 times per week than drift once a month because I spend all my moneys on my engine. Don't forget the more power you have, you need more tires (and bigger tires too), more fuel, it's break more.... Think about it. |
08-12-2010, 12:23 PM | #333 | |
can we stop going off topic...
take this crap to PM or to another thread...
08-12-2010, 05:03 PM | #335 | |
do some reading there, its has all the info you need.
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
08-13-2010, 02:10 PM | #337 | |
more like 7-8k....10k if your rebuilding/adding shit. If you are paying 15k, you should register on ls1tech.com motors are at most 3k, paying for fab shouldn't be more than 2k, leaving you with another 2k in case shit break/ comes up....but this isn't the ls1 thread. back on topic.... Rob...i want my car to drift for me...all i have to do is put a little input/ correction. haha |
08-13-2010, 02:57 PM | #338 | |
Everyone has there own type of driving style. FC like to let his car drift. I like to be ahead of my car drifting. Idk if that made any sense... =|
08-13-2010, 07:18 PM | #340 |
Wet conditions..
Took me awhile but i finally got it... Coming out of a drift and connecting into a fairly sharp 180 deg left... I found great success with a quick counter into the turn, with no gas whatsoever until mid apex then powering out with a little feather...Felt great to finally get that turn...
http://www.leg1t.com |
08-14-2010, 03:37 AM | #341 | |
08-14-2010, 03:41 AM | #342 |
it doesnt make any sense. the video you posted shows that your car is poorly setup for drifting and you dont know how to drift with it setup that way. you do have skill but i dont know if you understand what FC is really talking about. when you were driving your car in the vid, the car was ahead of you and you were waiting for it to do what you wanted. FC wants his car do to exactly what he wants without him thinking of corrections or inputs to make the car react how he wants.
08-14-2010, 10:12 AM | #343 | ||
Yes I do know what FC is doing. He's letting his car come smoothly vs what I did on the tight course which is letting the swing out and making the car where I want it to go. Not to talking like I know everything. I have good friend that instructs with Conrad Grunewald at Skip Barber teaching me a lot of this is how someone like Conrad would kinda of do on a tight course. There isn't a lot of room to get to a speed so I have to Again my video is aim at a tight course so I have to input a lot of steering correction. Also there isn't a lot of room to get to a speed so I have to make do with what I have and since I can't get much speed I'm generally in about 4k - 5k rpm so I'm not getting much wheel spin so I'm having to keep my speed has much has I can do keep the car sideways. VS A big more open course which wouldn't need it and that fact he going into the drift at top of 2nd or in 3rd at 65ish so he have plenty of wheel spin and speed. I probably do the same amount input has FC but in a different style if I was on the same track. I am sorry if my English isn't correct I don't have really good english and didn't reread any of that.
08-14-2010, 11:16 AM | #344 | |
08-14-2010, 11:33 AM | #345 |
hey fckillerbee, want to share with us your car setup/stuff on the car? I have a couple friends with stock KA's, me included, and you make drifting with a KA ridiculously easy lol. Maybe it's just cause I'm super n00b
08-14-2010, 11:51 AM | #346 |
hit me up, ill help you out lol search me on fb= robert airth
08-14-2010, 01:11 PM | #347 | |
My favorite setup front 225/40r18 dunlop star specs @ 32 psi with about -5.5 degrees of camber Cheap aftermarket front sway bar (bought from sonic motor) rear is 225/40r18 Triangles @ 55psi with about -1 degrees of camber(shitty tires..but last long, easy to break loose) no rear sway bar (compensates for shitty tires/gives grip) zero toe all around caster is stock...whatever that is (i've never understood it, so i've never played with it) stance coils...i'm sure most coilovers will work 6 puc unsprung clutch and pressure plate with 11.5 lbs flywheel. (easy to bring the revs up on clutch kicking) Welded diff (most lsd's i've driven on require more power than what the stock ka puts out, so i would have locking problems)....plus, it's predictable...always the same. All of this is setup cold, as I prefer to be consistent on my first laps...then after tires warm up for a couple minutes....typically in a competition, you don't get warm up laps to prepare your car for "your ideal temperature", so I prepare my car cold.... that's as much as I can think of off the top of my head.... If you run a non-r compound tire, you will get less input to your steering (as I have said I like the car to drive for itself, and just give it little input) So when I switched to a federal in the front, the car slid out farther, and created a lot more smoke...made it harder to drive, and point the car, but definitely made some cool photos. i've never had smoke....so I thought it was rad when I parked the car....to see the tires sizzle....and you could see the smoke just pouring from the tire....even parked. And this was a windy day and I highley recommend....16's for beginners....once you get weight shifting down...then you can move up to bigger sizes....and then drive even harder to keep them spinning. for the record..i don't want to be a stock ka...lol...i want powah! Castro....the man.....the myth...the legend....post your setup if these guys saw you drive!!! |
08-14-2010, 11:31 PM | #348 |
legit post hammy. i dont exactly approve of this thread but i cant win em all. caster=the amount of leverage the vehicles momentum transmits to the steering system to make the car countersteer itself(for drifting). more positive caster=more self countersteering. the issue with making the caster positive is that the more positive it goes, the more the driving wheel "rolls-over"(aka-positive front camber" as steering angle increases. one of the basic ways of compensating for positive caster is to increase negative camber. the reason why FC runs soo much negative camber in the front is to compensate for the +6.5* caster that s14's run "stock". compensation meaning to balance the vehicles drift angle with the front end's maximum traction. there is a point at which the car is within a range of being perfectly setup for a drivers preference then it goes too much neg camber(understeer at low drift angle) and too little negative camber(understeer at high drift angle). just fyi.
08-15-2010, 04:04 AM | #349 |
If you dont approve of this thread then why are you still on it? if you dont have anything good to say stop commenting.
DREW SLIDE TO SIDE WORLD WIDE Feedback!! http://www.zilvia.net/f/showthread.php?t=182673 661 sliders Gymkhana @ buttonwillow http://zilvia.net/f/south-western-st...-sessions.html >> Bakersfield Hook up thread << |
08-15-2010, 04:19 AM | #350 |
+1 for you bud. i dont anything better to add to that so, yea.
Built RB25 - RB The World - Vertex Everything @RBVertexRidge |
08-15-2010, 01:48 PM | #351 |
thanks^^^ I mean really why would you even look at a thread you didnt like??? FCKillerb.... why dont you throw a t25 or 28 on your KA???
08-15-2010, 02:18 PM | #352 | ||
I'm super aggressive on my transitions so I can keep my speed up so I could keep connect everything. TBH I don't have time to do that. If I were to do something like that I'd lose speed and then I would having problems with the drifts. And really? Didn't already say that I wasn't taught by a pro driver??? You don't have to try to help me. I'm just here to show how I do my entrances...
08-15-2010, 07:11 PM | #354 |
lol @ kid you thinks he's cool cause he "drifts" at autoX events.
Some people are giving good solid tips, others are cluttering the thread with HOLIER THAN THOU talk. Shut the fuck up and get back on topic. I like reading. |
08-15-2010, 07:13 PM | #355 | |
08-15-2010, 07:17 PM | #356 |
dont take it personal, but fuck off cone killer. lol. seriously tho, its not that i dont like this thread, its that it really wont do much for anyone. its just kinda useless. im trying to add some function to this thread by critiquing and providing answers to questions. sorry if you dont like me saying people can do better. and btw jspec240, get a more defined course to practice on.
08-15-2010, 07:27 PM | #358 |
what are your alignment settings?
08-15-2010, 07:41 PM | #359 | |
make up your mind. I agree if someone is critiquing your style lets not get butthurt, but Crazyrob you can also be less agressive when posting, you are basically chalenging and picking fights as you post.
08-15-2010, 08:11 PM | #360 | |
