#3422 | |
![]() Join Date: Sep 2009
![]() Feedback Score: 11 reviews
#3423 |
![]() Join Date: Nov 2006
Trader Rating: (56)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 56 reviews
Car: 1990 240SX KA24E 5MT
Problem: Engine bogs under full throttle doesn't rev past 4000 rpm I've looked the engine bay over and everything seems fine. Nothing is unplugged and no leaking. First rev in the video is me giving it full throttle at you can see the revs lower even when the throttle is wide open. Second rev is just half throttle to 3 and bog until 4. http://i33.photobucket.com/albums/d7...p/8594ef54.mp4 What do you guys think?
#3426 |
![]() Join Date: Apr 2010
![]() Feedback Score: 7 reviews
quick question, my 95 s14 has a koyo radiator and an aem short ram intake. now my clutch fan literally has about half an inch of clearance from the intake, can an oem fan shroud fit with everything? i don't wana buy one and it ends up not clearing something
#3427 | |
#3429 |
Someone help me understand this synchro thing again.
Driving a little bit more, Ive found some tricks to my 3rd gear grind. I mentioned going to second before first to prevent grinding going back into first. now if i go to N back to 2, then 3rd(2nd, N, 2nd, 3rd), I wont grind. Unlike going in 2nd before going into first, i can go right into third without doubling second all the rest of the drive like the problem is fixed ![]() ![]() Still going to try some amsoil. what can i expect then? |
#3431 |
97 kouki 5spd.
Car has been Misfiring on #4 and have been trying to figure out what the issue is. I have installed new injectors, seafoamed, knock sensor, rotor, cap, wires, plugs and fuel filter. I have a new intake Mani gasket to put on this weekend as well. What I'm wondering that if I unplug #4 injector should the car start to idle very bad? Motor rocking almost dying? I unplugged #4 and car doesn't change idle. But if I unplug #3-1 the car will idle bad, almost shutting off. I'm guessing that unplugging #4 should make the car do the same. Thinking it may be a wiring problem with injector #4? Any heldp would be great. |
#3434 |
![]() Join Date: Mar 2010
why do these two sets of kouki tail lamps look different?
![]() ![]() i have a set of oem koukis and they definitely dont look as yellow as that second picture shows them to be |
#3435 | |
Are you getting spark on that cylinder? Also, you might be able to disconnect all of the plug wires and loosen the bolts holding in the fuel rail and have someone crank the ignition to see if the injectors are firing. Just pull the fuel rail back out of the manifold a little to see if they are squirting. I was able to do that with my redtop. it's the lighting of the photos. In the 2nd pic, both cars have very yellow tails. First pic looks redder than normal, possibly because of lighting, possibly tinted.
#3436 |
Trader Rating: (38)
![]() Feedback Score: 38 reviews
When installing coilovers on a S13, you know the (2) 17mm bolts for the fronts and (1) 17mm bolt for the rear that connect the knuckle and the stock struts, I'm having the most difficulty trying to break all bolts, do I need a special tool? Advice is needed please
#3438 |
Trader Rating: (38)
Yeah, I meant getting them off. I used the term "breaking" because the bolts and everything is really stiff. But no, I used WD40...is that not recommended?
I'm on jack stands if that gives you an idea of how difficult it is to actually turn the bolt. Would lifting the car real high help? for leverage? |
#3439 | |
also a breaker bar or an impact gun.
#3440 |
![]() Join Date: Feb 2005
use pb blaster, wd40 kinda works but its more a rust protectant/lubricant. pb blaster breaks up the rust and dirt and whatnot. but something that will really help, invest in a small air compressor that will run a impact gun. that will help you out TONS. like i dont know what i'd do if i didnt have a impact gun to use on cars.
#3441 |
Trader Rating: (38)
@c72c: Yeah I don't have access to an impact gun at the moment, so I'm stuck with wrenches and a breaker bar. But for the rears, a breaker bar is too long for any type of leverage, how can I get around that, I know for the fronts, you'll have the wrench facing you.
I've been reading coilover installs on Zilvia, NICO, etc. and everybody seems to be able to get these bolts loose without using an impact gun so please, anybody can chime in. |
#3443 | |
#3444 | |
#3445 |
one more question ..
are side marker lamps required by law? i know my honda accord didnt come with them.. but when i look on google it says that they are required.. i dont want them if i dont need them. i have turn signals from the pignose.. is that enough of a position lamp? |
#3446 |
Ive had these wheels sitting in my garage for about a year. Buddy gave em to me, i have no idea what they are and they do fit on the 240 i was going to clean em up and put em on but i have no idea what lugnuts to use or if its even possible to mount em. I posted them in the Stance/Offset thread but it got deleted because they were not on a car and no specs that was my fault haha but any help is appreciated!
sorry for the large ass pics ![]() ![]() ![]() |
#3447 |
![]() Join Date: Jan 2008
Quick question, does anybody know if the rocket bunny fender flares will fit up with a s13 silvia aero front bumper without massive body work? I dunno if I dig the rocket bunny front but I dig everything else.
#3448 |
![]() Join Date: Apr 2008
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
to the guy thats having mis firing problems, check your distributor and all wiring
To the guy that cant get his stock shocks off, try using a little heat, torch from lowes or something is like 30 bux and works wonders. |
#3449 | ||
![]() Join Date: Dec 2003
Pn# K3068-S13001 Quote:
oh and for the rears use a breaker bar or jack handle like I said and step on it.
![]() **CoUpe LOve** Member #00 |
#3450 |
Trader Rating: (38)
Thanks for all of the answers guys, but our winner is VNG704!
@WakeBHR, I tried your method before your post and they were really stuck haha and so I took it to a mechanic down the block and they loosened all the 17mm bolts with a impact gun for 5 bucks ![]() |
