01-26-2014, 09:37 AM | #3391 | |
Sorry I was asking about the actual engine mount not the brackets used. I'm running the same setup with nismo mounts and the engine sits super high
01-26-2014, 04:43 PM | #3393 | |
you may want to consider some shorter solid mounts before you move forward if you want your hood to close
01-27-2014, 11:21 AM | #3395 | |
01-27-2014, 12:02 PM | #3396 |
I'm selling a aristo 2jzgte non vvti ecu for $120. And a 1jz/2jz map sensor for $75 if anyone is interested. Went aem so I'm not needing this stuff. U can pm me or text at 405-837-5212
Follow me on Ig- Andydennington |
01-27-2014, 12:33 PM | #3397 | |
What AEM part numbers are you using for the ECU and sensors? You have an aristo engine/harness?
01-27-2014, 12:52 PM | #3398 |
Ye I'm using an aristo engine harness. And the aem is just the toyota supra tt ecu, v2 unit. Plug and play and the map sensor is just Titan Motorsports 3.5 bar map
01-27-2014, 12:57 PM | #3399 | |
I was just reading there was a few different pins on the aristo vs the us supra. Any idea if that's true? What kinda deal did you get on that unit?
01-27-2014, 01:10 PM | #3400 |
There are a few pins that are different, but not main engine functions. Plus I went thru my harness and de-pinned all the unnecessary things since mine is just a drift car. And I paid around 2k for the unit. I'm running the driftmotion 6262 kit with stock injectors. Car made 346hp and 340tq on 13#. I was at full boost before 4k. So I highly recommend this kit if anyone is looking into going single
01-27-2014, 01:44 PM | #3402 |
Ya stock 440's. Lol that's where they were maxed out. 100% duty cycle on 13# so I turned it back down to 10# and am at 78%. But I'm going to be upgrading to FIC 1050cc and switching to E pretty soon
01-27-2014, 03:27 PM | #3403 |
Got a question for you guys.
I'm 1j, running a 6262 t4 .68, I am using jdm 2j 440's. But with c16 race gas, power limit of the 440's on race gas? Haha
01-27-2014, 09:25 PM | #3404 |
You should be able to idle with the 775cc's and a new SAFC. If I can idle and run my 2j with 1000cc and a SAFCII (choppy and wouldn't recommend to anyone) then you should since its at the limit.
As far as the starter goes, that ties into your original harness (nothing 2j related) and ignition. What lights stay on the dashboard? If it's the brake/cel then check your alternator wiring. That is what turns it off
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
01-28-2014, 07:56 AM | #3406 |
Your gonna be around the same power levels as me. Your gonna have your injector duty cycle maxed out before you can even start to mess with timing.
01-28-2014, 03:08 PM | #3407 |
Troubleshooting time.... Car friends please help!
Alright so, im 1jz, custom chassis harness, chasebays engine harness. Coils are working (everything is actually), except the injectors aren't pulsing... I can get the motor to run off of starting fluid, but as soon as the ether evaporates, the motor dies again.... I plugged in a electrical check light and the injectors are getting power, and if I keep the injector plugs unplugged with the light hooked to the power side and try and crank the motor the light will dim down (read to check that to see if theyre grounding correctly?).... Im really unsure of what it could be, any help would be greatly appreciated. |
01-28-2014, 03:40 PM | #3408 | |
I had this problem on my engine bay harness (that's connected to the fuse boxes). I was only getting 10v-11v to my injectors and it couldn't spray enough fuel.
01-28-2014, 03:43 PM | #3409 |
If anyone has any info to help with keeping AC and running custom lines (or whatever you used) I am all ears.
*s13 vert if it helps
01-28-2014, 06:10 PM | #3410 | |
01-28-2014, 08:05 PM | #3411 |
Going to triple check grounds tomorrow....
I want to clarify, I am running a 2jz ECU.... Im 99% sure its a JDM Supra ECU (yellow sticker with 88 on it, and the code is 89661-14501)... Which means high impedance injectors, So the stock 1j 370's should work just find with my ecu correct? I know the jdm 440's would work but I really don't want to upgrade yet... |
01-28-2014, 08:12 PM | #3412 | |
01-28-2014, 11:33 PM | #3414 | |
Have seen a few swaps in this thread running a similar setup so pretty sure it will work for both s13 and s14.
01-29-2014, 10:06 AM | #3416 |
Is that on a 1j or 2j? I figure 440's would be a lot more than the 370's stockers on a 1j.
I also figured I could get a lot of timing because of race gas.
01-29-2014, 11:18 AM | #3417 |
Trader Rating: (53)
Feedback Score: 53 reviews
That just doesnt seem right. From what i've read on supra forums some people are running damn near 20lbs on 440's safely. Note that this is for a 1JZ using 440's, i'm not sure if the numbers would be different on a 2JZ due to the higher displacement.
01-29-2014, 04:33 PM | #3418 |
This is on a 2j. And your not going to get much timing adjustment before hitting a high duty cycle.
01-29-2014, 04:39 PM | #3419 |
I could definatly see that on 550's but idk how someone could on 440's. Maybe they weren't monitoring duty cycles and was just going off afr's. Even at 100% duty cycle I wasn't leaning out at all. By 7200 rpm I was still low 11's.
01-29-2014, 09:23 PM | #3420 |
Just so everyone knows zerolift r154 bracket doesn't work with xcessive mount. I was thinking of notching the rear but I don't know of that will make it weak and bend under load. Any suggestions?
