#3361 | |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
IG/TikTok-ThatS14_Z06guy |
#3362 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
S3HL = 11.6 / 0.457 lift Remember the S3 cams are all stock valvetrain to 8000 rpm safe.
#3365 |
![]() Join Date: Jun 2010
Cody, you've convinced me that JWT is the way to go. Namely, the fact that it is more cost effective to use S3/S4 vs Procams / HKS Step 2 and springs
I don't think there is a single dyno result in here of someone using S4's on a DET. However the SCC article posted in the teen pages of this thread are pretty convincing, minimal midrange loss with more top end. I must still decide between S3HL, S4 or S4HL, but at this point, I am leaning towards S3HL, the page before shows a 40 WHP gain with those! The motor is used for drifting and spends more time at redline than conventional road racing, where an upshift would occur. If the powerband is limited to 6500-7000, then there is less of a chance of throwing a rocker. My setup: S13 SR20DET GT2871R .64 52 Trim Haltech PS1000 555cc Injectors 323 WHP @ 15 PSI on Dyno Dynanamics Looking to do Cams, Intake Manifold, 740cc Injectors and 20 PSI next to get around 400whp. |
#3366 |
Whats the difference in a low boost vs high boost tune? Shouldn't a high boost tune be just fine for daily driving as long as the injectors/turbo, etc are the same?
#3368 |
Sorry for double post, but i think the only difference is boost control settings. Youre trims and timing are going to be different for corresponding boost levels, so if you have a tune for say 22psi you should be able to run 8psi through the whole power band if you wanted to (asuming you didnt change the turbo or other engine components). I daily a 22psi tune with no hi/low switch. Of course my engine is built for it, but most of the time i dont even pop out of vacuum unless i need to pass someone or im drifting. I honestly dont see a point in having two settings if you have a solid tune and ability to control your throttle. I know i tend to accidently or incidently post misinformation sometimes so someone correct me if im wrong.
#3369 | |
i daily'd my all stock internal SR (other then ARP studs and an apexi HG... which really isnt much of an internal mod anyway) on 18lbs wit my gt2871r + z32 maf setup, and on a daily communte, i barely ever pounded on it unless i was late for work or something. And the SR is still holdin strong from over 2 years since i tuned it. Just regular driving and occasional spirited driving. A good tune and that shit will be fine. The only time i could see not dailyin on high ass boost is if you drive like an idiot and redline it everytime you in the car for like a year everyday lol. Its just using common sense you know? |
#3370 |
![]() Join Date: Nov 2003
Ok, so I'm going to go look at a GT2871R tonight that a buddy is selling, he thinks it might need a rebuild, but that seems strange because it can't have too many miles on it. And he says it has a bit of shaft play. Now being a ball bearing turbo, I know these inherently have a little bit of play, but how much is too much? And in/out or up/down?
He's only asking 300 for it total, so it could be a crazy good deal! Lol
-Kyle ![]() |
#3371 |
Keep in mind rebuilding a BB turbo is not like a journal bearing turbo. Most people just replace the chra.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
#3372 |
#3373 |
It's your only sensible option. I know there are people out there that will attempt BB rebuilds. But they seldom last very long. It's a waste of money IMO. Just get a new chra.
#3374 |
Yea exactly, I knew that, so I wasn't willing to buy it unless it wasn't actually blown. But I looked at it, bearings audibly sounded like garbage. plus, it was the .86 hot side, which I don't really care for. especially since I want the GTX2867, but figured if this was a good enough deal I could be in for it.
I bailed on it, gonna keep saving for that GTX...
-Kyle ![]() |
#3375 | ||||
Trader Rating: (58)
Looking to do Cams, Intake Manifold, 740cc Injectors and 20 PSI next to get around 400whp.[/QUOTE] Quote:
#3376 | |
AFC #1
![]() Join Date: Oct 2003
#3377 |
Any experience with a extrude honed intake off a S14/15 SR20?
#3379 | |
![]() Join Date: Aug 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
#3381 | |
Trader Rating: (58)
![]() Can't say I do, but the high port intakes are 'supposed' to make slightly better top end power...however for the cost of extrude honing a stocker, you can get a 'Freddy' for less and be fine. Just retap all the tappered thread holes or have a welder weld bungs on them and you'll be fine.
#3383 | |
looking into these guys at the moment though... Renegade Hybrids |
#3385 |
I might know a guy with a 2871r?.....lol
cONtRol FReAkS |
#3387 |
So I know this thread is about the gt2871r but what about the turbonetics, precision, and or like the tomei Gsp, Isis turbos? With the same specs? Or is this a stupid question if so sorry!!
#3388 | |
#3389 |
#3390 |
I'm running the precision 5128(.64) and I love it so far. Turbo pulls great and is very smooth. No mounting issues with the stock redtop mani if that is something you was curious about
