Old 04-18-2017, 03:43 PM   #301
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Originally Posted by yousmellfunnytoo View Post
. Also, custom driveshaft for it would be similar, as they only needed the length from flange to flange
shaftmasters /thread
http://shaftmasters.com/nissan-240sx-drivesha240.html
Old 04-19-2017, 06:40 AM   #302
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
The collins adapter worked really well, poor documentation came with it, and there are only about 8 bolts that bolt the trans to the adapter.
Only 8 bolts? That seems pretty good actually.
Originally Posted by dwnshft2drft View Post
I'm confused. Too many engines types and vast variety of conversions for one tranny. Is there any thread that covers only SR motor? Sometimes you read it interesting and find out that is not for what you want to do.
To be fair, he says his setup right at the beginning of his post.
In other news the T56 slaves are a no go. The bolt holes line up but the input shaft hole is ever so slightly off center. I could redrill one of the mount holes to get it center but I don't trust myself to be that precise.
My S13 SR Street Mod Build
LuckyX2 is offline   Reply With Quote
Old 04-19-2017, 11:48 AM   #303
LuckyX2
LuckyX2's Avatar
Internal throwout bearing gap:
I'm assuming I measure this with the slave fully compressed? The spring keeps in at full extension. Also, does this mean the bearing is always in contact with the release fingers? That doesn't sound good for wear.
Old 04-19-2017, 12:50 PM   #304
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
Originally Posted by Itsalexwoo View Post
I'm still waiting for my CBF shifter as well. The only way I've stayed in contact was through Facebook. He told me he's making everyone in the group buys and shipping them out in order now but who know how long it'll take I just contacted him yesterday for an update still waiting for reply
I asked for a refund. Every time i contacted the guy it was another couple of weeks and so on, it can get old quick. He never responded to my refund request so i called my credit card to dispute the charge. Ordered a serial nine.
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 04-19-2017, 01:07 PM   #305
travon47
travon47 is an unknown quantity at this point
Good to hear, you will not regret it
travon47 is offline   Reply With Quote
Old 04-19-2017, 03:40 PM   #306
TheRealSy90
TheRealSy90's Avatar
The everything cd009 swap thread.
The throwout bearing is not supposed to ride on the pressure plate fingers when the clutch is engaged. There should be a small gap between them.
Such a good signature.
Old 04-19-2017, 03:50 PM   #307
Itsalexwoo
Itsalexwoo's Avatar
Itsalexwoo is an unknown quantity at this point
How do you find the gap
Itsalexwoo is offline   Reply With Quote
Old 04-19-2017, 03:52 PM   #308
brndck
brndck's Avatar
he JUST told you
Old 04-19-2017, 04:13 PM   #309
Itsalexwoo
Itsalexwoo's Avatar
Really? That says how to find the gap?....I'm pretty sure that's describing the end result. I'm asking for the steps leading up to...
Old 04-19-2017, 04:13 PM   #310
TheRealSy90
Need to take measurements of everything.
Old 04-19-2017, 07:34 PM   #311
LuckyX2
LuckyX2's Avatar
I don't see how this is possible with the internal slave throwout bearings though, that's my problem.
They're spring loaded so they're fully extended at rest. How in the world am I supposed to get that to not touch the clutch fingers?
Exhibit A: Spring loaded, always extended internal slave cylinder
Edit: I have to measure with it fully compressed. I'm guessing the hydraulic fluid holds it back when the clutch pedal isn't pressed?
https://ls1tech.com/forums/manual-tr...need-shim.html
Also, how the hell do I get the bellhousing off to ship out for machining? I removed the bolts connecting the back portion to the front (the ones that go through the "sandwich piece" that's a few inches thick) and broke most of the liquid gasket seal but I still can't get it to budge.
Old 04-19-2017, 08:11 PM   #312
TheRealSy90
You need to remove the front cover, and the snap rings underneath the front cover. Also there's one bolt underneath the black inspection plate on top of the trans that people forget to remove that holds the bellhousing on.
Old 04-19-2017, 08:12 PM   #313
TheRealSy90
Maybe it's okay for an internal slave to ride on the pressure plate, I'm not sure. As far as external slave and fork goes, when it returns with clutch engaged there's supposed to be a slight gap.
Old 04-19-2017, 09:28 PM   #314
nauss18
nauss18 is an unknown quantity at this point
S15 rb25det --> cd009
I'm currently gathering everything I need to install my CD009 into my S15 with an Rb25det swap.
Currently I have;
-Transmission CD009
-Collins adapter plate
-Shortener pivot ball
-Collins recommended 200sx release bearing sleeve
Things I need;
-Clutch/clutch fork
-Driveshaft
-Shifter adapter?
So as for the clutch any RB push style clutch will work?(Multi or Single disc set ups) Also the shifter adapter... Will I need one or will the shifter line up close enough that I could, If needed just cut some of the tunnel? Also which clutch forks will work with this application?
nauss18 is offline   Reply With Quote
Old 04-19-2017, 09:53 PM   #315
TheRealSy90
Unless you want the shifter to be behind your seat, you will need an aftermarket shifter relocation.
Old 04-20-2017, 11:39 AM   #316
LuckyX2
LuckyX2's Avatar
Thanks, that's what I was missing.
Also just want to say that I wish I had known more about the HR trans when I got into this. Was planning on a CD009 but then a low mileage JK40C came up cheap and I went for it. Then I read about the slave cylinders being garbage so I wound up buying a $430 ZSpeed slave ($325 + line + twin plate adapter + shipping). $350 for the adapter, $430 for the slave, $400 for the driveshaft, $175 for the shifter, $100 for machining, $100 for the crossmember and I'm at the price of the Mazworx kit. That slave I didn't plan on buying really ruined the budget.
So tl;dr if you have an HR trans, just get the Mazworx kit. DE trans you can save $400-500 going with an adapter plate if you wish.
Old 04-20-2017, 12:55 PM   #317
brndck
brndck's Avatar
for everyone
this is the fsm for z33 trans (cdxxx, not sure about z34)
it also has a diagram showing the only way I've found to tell cd008 apart from cd009
http://pdf.textfiles.com/manuals/AUT...pe/2005/mt.pdf
you're welcome
Old 04-20-2017, 01:09 PM   #318
travon47
for everyone
you're welcome
I've looked at this a few times before but don't see what diagram your talking about that shows you the difference? Unless your talking about looking at the synchros which are obviously different, since that's what the changes mostly are.
Old 04-20-2017, 01:56 PM   #319
brndck
brndck's Avatar
page 21 there is a blow apart diagram, CD008 has a 2pc bearing retainer thing (items 22 & 23) where CD009 its one piece (item 22).
when you remove the rear extension (item 27) you can see this, and other than pulling the whole gear set out to inspect the synchros, this is the fastest method I've found of determining if you have cd009 or not
Old 04-20-2017, 02:02 PM   #320
travon47
Oh word, yeah not planning on opening either of mine up anytime soon since they are both installed lol. Good to know if you have to take the case off though
Old 04-20-2017, 02:08 PM   #321
dwnshft2drft
dwnshft2drft's Avatar
Trader Rating: (28)
dwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enough
Feedback Score: 28 reviews
Looks like everyone is expert.
I'm planning to go with the z34 tranny but I don't want to deal with the hydraulic throw out bearing. Is there an adapter to use with mazworx bell housing with all the SR flywheel, clutch kits and slave cylinder?
dwnshft2drft is offline   Reply With Quote
Old 04-20-2017, 02:12 PM   #322
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Well our kit is exactly that... Our kit uses all SR20 clutch components.
[email protected]
hanzbrady is offline   Reply With Quote
Old 04-20-2017, 02:31 PM   #323
kkaleher
kkaleher's Avatar
kkaleher is an unknown quantity at this point
Yep I asked for a refund and got no reply still (going on 2 weeks), so I filed a paypal dispute and he contacted me 20min after it was submitted
Ordered the serialnine shifter. I fb messaged him and he told me they were about a week out from TF-works and there were still some available. While it isn't cheap by any means, as long as there is some kind of communication (which so far has been great) and it works as well as advertised I will be happy.
S13- 2jz, 370z 6spd, PT6262
Nissan Master/GT-R Technician
kkaleher is offline   Reply With Quote
Old 04-20-2017, 02:36 PM   #324
dwnshft2drft
Trader Rating: (28)
Do you have a link where I can check them out. Thanks!
Old 04-20-2017, 02:39 PM   #325
brndck
brndck's Avatar
well ya kinda hafta pull it off to remove the bellhousing in order to have it machined, so......
lmgtfy.com
Old 04-20-2017, 02:59 PM   #326
travon47
uhhhh, when did I say I need anything machined? I bought a kit that doesn't need to be machined/cut or anything, and had it running and driving last year. also the one in my g35 definitely doesn't need to be machined
Old 04-20-2017, 03:52 PM   #327
brndck
brndck's Avatar
that's mantastic, but since this is the cd009 SWAP thread, the general assumption is that we're SWAPPING cd00x trans into things, your g35 obv doesn't count. now fuck off with your attitude while I'm trying to help.
Old 04-20-2017, 06:50 PM   #328
hanzbrady
hanzbrady's Avatar
We only have 2 kits in stock so order soon they'll be backorded for about 3-5 months.
https://www.mazworx.com/mazworx-sr-v...s-chassis.aspx
[email protected]
Old 04-20-2017, 07:23 PM   #329
MattTenFour
MattTenFour is an unknown quantity at this point
Is anyone else having issues with their transmission popping out of fifth gear? Mine only does it after I accelerate in fifth and let off the gas. As soon as the engine is no longer under load it goes into neutral unless I hold the shifter in fifth. SR, CD009, GKTech shifter, Collins adapter, GKTech trans mount. My Collins throw out bearing was shot from the minute I installed it, I don't know if that could cause this but I'm planning on replacing it this weekend.
MattTenFour is offline   Reply With Quote
Old 04-21-2017, 07:22 AM   #330
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
You should verify that your GKTech shifter is allowing it to fully engage in 5th gear.
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
