02-26-2013, 10:22 PM | #301 | |
-WES |
02-27-2013, 07:05 AM | #302 |
Trader Rating: (33)
Feedback Score: 33 reviews
Just checked with DuPont about the compatibility of PTFE with Gasoline and I was able to speak with a tech and was informed that Gasoline should have "Minor to Moderate Effect, 5 to 10% Volume Swell" when in contact with PTFE. This would mean that it would have minimal effects on the material and would not explain why the PTFE above was degrading. There must be something else going on with that experiment. It could be due to impurities in the PTFE material especially the "cheaper PTFE" (Not saying lines are cheap saying the company may have used a bad or cheap batch of PTFE material). Could be other factors...
02-27-2013, 08:31 AM | #303 |
what are you guys using for filters?..... would this work fine?
Russell ProFilter Fuel Filters 649160 - SummitRacing.com i guess my real question is, are nylon elements ok with E85? and how many micron's is recomended to use with E85? |
02-27-2013, 08:44 AM | #304 | |
Russell Competition Fuel Filters 650100 - SummitRacing.com
MunkyW3rkz Racing |
02-27-2013, 09:44 AM | #305 |
Trader Rating: (33)
@DRIFT_FX.....go with a Stainless Steel Mesh/Screen filter (like S@nt0s is using). I have a 40 Micron Pre-Filter and 10 Mircon Post-Filter.....but then again thats because I am a little neurotic.
Nylon material will breakdown in the presence of Strong Acid. |
02-28-2013, 06:59 PM | #307 | |
02-28-2013, 10:37 PM | #309 |
Using strictly teflon line hose with E85 is a myth. You can use rubber fuel hose, most of it nowadays is E85 compatible, just have to check the ratings on the hose. I use Gates Barricade EFI hose, which is E85 compatible and not nearly as much of a pain or as expensive as going with teflon stainless AN hose and fittings. Available at pretty much any Oreilly's. Also, be sure you use the proper ethanol compatible submersible fuel hose in the gas tank feeding your pumps, I used Gates 27097 for mine (went with 3/8" fuel lines). Save yourself a butt load of money and stick with barbed fittings/clamps/rubber hose. 3/8" is plenty big for E85 and 600 hp, and you can use a clamp on 3/8 EFI fuel filter with stainless filter media for a 2005 GMC Savanna. Not including the pump/regulator, I think I spent maybe $50 building my E85 compatible 3/8" fuel system.
03-06-2013, 07:40 AM | #310 |
Trader Rating: (33)
^Some of the Gates Barricade hoses are lined internally with a Fluoroelastomer or Nitrile which would make them compatible with E85. As AF mentioned just make sure you are getting a hose with either internal lining. Gates makes some awesome hoses.
09-07-2014, 07:41 PM | #314 |
To bring this thread back, what compression ratios have people been running with E85?
With my current SR20 build, I am shooting for 500 bhp (rough number to keep up with a few locals). Tuning will be done through a AEM EMS Series 2, and running ID1000 at 4 bars. I was originally going to go with some CP pistons at 9:1 CR, but I know people can run higher compression with E85. Is it worth hunting for some 9.5:1 or stay safe with the 9:1? |
09-07-2014, 10:41 PM | #315 | |
09-08-2014, 08:06 AM | #316 | |
11-06-2014, 09:40 PM | #320 |
I have a sr, it had a gt28, stock injectors, stock fuel pressure regulator, stock turbine outlet pipe, stock tune, I blew the turbo up back from buying it, I replaced it with a gt2871r, 850cc injectors, z32 MAF, adjustable fuel pressure regulator, Tomei turbine outlet, and e85, I got the car tuned for all of this by RS enthalpy for e85 and I feel that it doesn't pull as hard as it used to and just feels slow, when I start out from first it will bog out if I don't give it enough gas, have to give it more than what feels is right, also my friends will drive behind me and ask if I got a fuel leak because it smells like gas strong. Is that just e85 or is it running rich? I feel like it might be but I don't have a AFR gauge, also why does it feel slower? I got it tuned and I run e85, shouldn't that make it gain power and performance?
11-07-2014, 07:23 AM | #321 | |
11-07-2014, 08:00 AM | #322 | |
E85 does not smell like gas, to me! All 5 e85 tunes I've done, have made more power than the 93pump tunes they were currently on. If it starts and idles, you at least have a partial tune for e85. Wideband and logs!
11-07-2014, 08:45 AM | #323 |
Trader Rating: (22)
Feedback Score: 22 reviews
All my friends tell me "hey, bruh E85 kills fuel pumps and fuel injectors. You are so stupid you idiot. E85 is not cool, it's just hype."
Does E85 really do that sort of stuff or do my friends just hate my guts?
11-07-2014, 09:10 AM | #324 | |
If you use the proper injectors and fuel pump for your goals then you will be rewarded wit more power
11-07-2014, 09:57 AM | #325 | |
11-07-2014, 10:14 AM | #328 | |
You can think of these as different solvents. Water has its own properties; gasoline has different properties. If the properties of the solvent are such that, it will interact with whatever it's electron cloud can establish any kind of change. And that can be said for all matter, which is why it is silly to ask. Its kind of like being told that breathing might mutate the dna in my cells. Inside the cells are mechanisms, enzymes and proteins, that prevent oxygen from causing so much trouble. But not always to the same degree in every cell, from person to person. So the real question is, does my fuel system (cell) have the right equipment (enzymes/proteins) to protect itself from the solvent interactions (oxygen). Not every cell has all the right equipment. Some cells have some of the equipment. etc... extra points for the irony behind my example with respect to the electron donor / acceptor. |
11-07-2014, 11:25 AM | #329 | |
