Old 06-13-2009, 08:40 PM   #301
LOUD240
LOUD240's Avatar
LOUD240 is an unknown quantity at this point
cfinch how much do you want for a pair of lca's?
LOUD240 is offline   Reply With Quote
Old 06-14-2009, 08:25 PM   #302
LOUD240
LOUD240's Avatar
ok so when is the next meet?
Old 06-14-2009, 11:17 PM   #303
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
saw your car today dino, looks like it's coming along nicely..you just need paint lol :P
spooled240 is offline   Reply With Quote
Old 06-14-2009, 11:23 PM   #304
LOUD240
LOUD240's Avatar
paint is over rated!! lol
primer is paint
Old 06-15-2009, 01:44 AM   #305
cfinch
cfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond reputecfinch has a reputation beyond repute
Yeah I figured it would be an easy fix... It's not uncommon thats for sure...
Spare lca's? How does free sound?
cfinch is offline   Reply With Quote
Old 06-15-2009, 02:01 AM   #306
cfinch
spooled240- I got a good ka bottom end with 46k on it... I could rebuild a cylinder head then toss on a metal headgasket, arp studs and that should be good to go for your setup as long as it's properly tuned... I got a new full timing chain set for it too I just picked up. I was gonna assemble it this week for a turbo ka setup but I just picked up a bmw I want to build instead... I could possibly have a motor together for you pretty quickly... A ka trans should be easy to pick up or I do have some friends that work over at A-Tech and build trannies... I could get one of them to do a rebuild on the side...
Old 06-15-2009, 03:08 PM   #307
spooled240
spooled240's Avatar
how much would you want for it?. A few ppl on nico were telling me that stock internals would be fine for my 300rwhp goal(stock rods, stock pistons I doubt they will break anyway). I'm gonna go ahead and probably do a cheapo rebuild on my ka with new rings and gaskets but i'll def keep your ka in mind.
Old 06-15-2009, 05:28 PM   #308
cfinch
Yeah I wouldn't try pushing over 300hp but I mean thats still alot of power for a street car. It really boils down to good tuning at that point.
You have to figure out why the motor has low compression in that cylinder... You have to worry about damage to pistons and scoring of the cylinder walls... It's not always as easy as slapping in new rings if you want to do it right.
I'll have to think about how much it's gonna cost me to get the whole motor together... I'm thinking some where around a grand? I figure like $300+ to have the head rebuild and the valves adjusted... Prolly like $250 for a metal headgasket & arp studs. Then I need misc gaskets, valve stem seals, full timing chain kit with new sprockets/guides/tensioners/chains etc... New front main seal plus assembly of everything and a block with 46k on it which you can see the car it came from and carfax it to verify... I'd say around a grand would be more than fair...
Old 06-15-2009, 06:20 PM   #309
spooled240
spooled240's Avatar
the motor began pinging on the 4th cylinder at 12psi but it runs fine at lower boost, I dunno why. Maybe i have a dirty injector?
but hopefully the cylinder walls are messed up and I can just get in there with a flex hone and re-ring it.
Old 06-15-2009, 07:18 PM   #310
LOUD240
LOUD240's Avatar
Cfinch the lca's would be cool I just want a set so I can powder coat them and bushings etc tell me when and where
Thanx
Dino
Old 06-15-2009, 11:45 PM   #311
cfinch
I get home around 6pm and I'm in oak hills... Just give me a call (760)885-8355
Old 06-16-2009, 12:34 AM   #312
LOUD240
LOUD240's Avatar
I'm usually blasting by oak hills at around6-6:30
Old 06-16-2009, 11:47 AM   #313
cfinch
I should be there around then!
Old 06-16-2009, 02:53 PM   #314
wideride
wideride is an unknown quantity at this point
any picture?
Mike,can post some picture...
Originally Posted by spooled240 View Post
yeah when i finally left L & L a cop came behind me but then passed me up. If you drive like a normal human being, they usually don't mess with you
mike, how often are you gonna have these meets?
wideride is offline   Reply With Quote
Old 06-18-2009, 07:33 PM   #315
LOUD240
LOUD240's Avatar
thanks chris the LCA'S are turning out good. great to be able to redo them without putting the car down
when can I pick up that cross member?
Old 06-22-2009, 02:48 PM   #316
spooled240
spooled240's Avatar
BUMP!
cfinch can i haz freee stuffz too?
Old 06-22-2009, 07:37 PM   #317
LOUD240
LOUD240's Avatar
josh bring over your front lip and I'll fix it for you
Old 06-22-2009, 08:11 PM   #318
Silviaoneday
Silviaoneday's Avatar
Silviaoneday is an unknown quantity at this point
Hey guys just finished my rb25 swap in my s14, just have to finish minor things, when's the next meet?
Silviaoneday is offline   Reply With Quote
Old 06-23-2009, 12:28 AM   #319
spooled240
spooled240's Avatar
Would the fiberglass hold pretty well? I need this lip to be kinda stong and able to scrape a little lol
Old 06-23-2009, 10:17 AM   #320
cfinch
lol I'm not giving away anything worth a shit...
Old 06-23-2009, 02:09 PM   #321
LOUD240
LOUD240's Avatar
Josh yeah the glass will hold up just fine and I can do it this weekend
cfinch, that cross member was bent pretty bad its all good got a straight one over at pick a part on saturday should I chrome it? lol
Old 06-23-2009, 08:58 PM   #322
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
is there a decent pick-a-part or boneyard up here?
upsdude is offline   Reply With Quote
Old 06-23-2009, 10:24 PM   #323
OLDSCHOOLRICER
OLDSCHOOLRICER is an unknown quantity at this point
i used to live out there. and i used to go to the friday meet's at LOWES. some of you might know me i used to drive a grey turbo mazda protege. anyways are the meets still going on or is there new meet's now?
OLDSCHOOLRICER is offline   Reply With Quote
Old 06-23-2009, 11:52 PM   #324
xBtony
xBtony's Avatar
xBtony is an unknown quantity at this point
Hmmm...I live in the AV (antolope) And Im down to go to any meets out here...Lol...Post if anything is going down...
xBtony is offline   Reply With Quote
Old 06-24-2009, 11:49 AM   #325
cfinch
There is a pick a part on santa fe... They used to have a ton of shit when it opened but now it's pretty slim...
The friday night meets always have been horrible and always will be... I remember when all the douche bags used to meet up at del taco...
Old 06-24-2009, 06:27 PM   #326
Silviaoneday
LOL the meets have always been pretty crappy here. I just wanna go out and cruise with no hondas and shit, pretty annoying.
Old 06-24-2009, 07:57 PM   #327
LOUD240
LOUD240's Avatar
I have been trying to start one up here but nobody ever seems interested
Old 06-24-2009, 09:34 PM   #328
upsdude
upsdude's Avatar
Trader Rating: (46)
i'm interested
Old 06-25-2009, 04:43 PM   #329
spooled240
spooled240's Avatar
that pick a part on santa fe had some clean hatches in there when they first opened up: dual cam, m/t, complete, no dents/rust with the pignose lip...was a shame.
i thought the super target idea was good location but we never got it going. My car is gonna be down for a good while since I'm pulling the motor and trans out for a rebuild.
Old 06-25-2009, 07:17 PM   #330
LOUD240
LOUD240's Avatar
Im down for a weekly meet at the super target , over near the Subway what night you all thinking? How's wednessday sound?
