10-16-2014, 03:22 PM | #3211 |
Little update. cleaner cut headlight covers, wrapped and cleaned up the passenger frame rail wires, and wired up my fog lights and tucked the wires away...
eastcoaststeeze- did you cut out and weld new metal in around the tower and rear of the tower? Or weld new over top of the old? looks like it will be a nice looking bay when finished!!! |
10-16-2014, 06:49 PM | #3212 |
Just welded over the strut tower already, figured it was safer then cutting out and putting new ones in. But its almost all sanded out and smooth, ill get some good detailed photos over the weekend before it goes to paint
10-19-2014, 06:36 PM | #3219 | |
older shot from when it was stock internals/turbo right after i swapped it back in late 08 early 09
10-19-2014, 09:12 PM | #3220 |
That dude is a troll, don't sweat what he has to say. Look at some of the stupid threads he has created as of late.
10-19-2014, 09:38 PM | #3221 |
He is GarageMakS14 (http://zilvia.net/f/member.php?u=161199) who was banned a while ago. I think he may have used other names as well.
One can tell by the telltale signs of being the only person who still uses the term 'BFE' and suffers from dyslexia. |
10-22-2014, 01:50 PM | #3229 |
10-22-2014, 06:43 PM | #3230 |
eastcoaststeeze- that looks really nice!!! what color ARE you painting the bay?
A-Tech_Weapons- I cut up a 2.5 inch aluminum 90* and put holes in it for the IACV, Valve Cover PCV, and throttle body vacuum nipples. |
10-22-2014, 09:32 PM | #3232 |
I typically dislike tube core supports/upper radiator support, but this looks awesome, almost factory. Great job.
10-23-2014, 01:54 AM | #3234 |
Nothing new or exciting, going to be pulling the car apart this weekend. Getting ready for a new wiring specialties harness that will be getting built! Got a long list of things to change or fix over the winter.
10-23-2014, 07:35 PM | #3235 |
Thanks guys! =)
crzsteveo- yes, it bolts on at the lower core support and the sides. It made it nice as I had the engine in and out for wiring. Flicktitty- I've worked hard to keep the bay semi factory and focused on all the details keeping that in mind. Your bay is very tidy as well. Nicely thought out and we'll placed components. |
battery relocate |
