#3152 |
im installing an apexi turbo timer, to be able to use the a/f option it says to splice into the main ecu ground could anyone tell me which is the main ground or can i use any of them? thanks for any help
#3153 |
![]() Join Date: Aug 2006
![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
I need new tires BAD on my stock 95' LE (5bolt)
I am running 225/50/16 right now on the stock rim.. They aren't rubbing at all right now so I assume I should buy a another set of 225's How about these? any objections to size? http://www.tirerack.com/tires/tires....ADS4&tab=Sizes All-Season are a must where I live |
#3154 |
My absolute FAVORITE 225/50/16 tire is the Falken Ziex 912. Great dry traction, good wet traction, does pretty damn good in the snow, and doesnt squeal when you spin em. And theyre like $84 a piece. But thats just me.
#3155 | |
Another option, cheaper but good reviews.. http://www.tirerack.com/tires/tires....omCompare1=yes Also 3lbs lighter per tire, is that very significant? Last edited by BC240; 10-19-2010 at 11:33 AM.. |
#3156 |
225's up front makes it a little sloppier.. honestly the difference is barely noticeable. Probably the best handling setup would be 205/55 fronts and 225/50 rears, but I like the ability to rotate the tires, so the minimal trade off in handling is worth it to me to run 225's all around.
#3158 |
i just installed a clutch fan and fan shroud. i had to move my intercooler piping to put the shroud on but when i went to put the piping back in place the blow off hits the shroud, is there anything else i can do other then grinding out a spot for the blow off? and if i grind out a little hole for it will i lose any suction from the clutch fan through the radiator?
#3159 |
![]() Join Date: Aug 2010
my motor has low compression in cyl 2&3 120psi. on a ka24de. I found a brandnew engine for $1250. How long do you guys think my engine will last.?
#3160 | |
And $1250 is a ridiculous price to pay for a KADE. I mean, sure its nice to have a brand new engine, but for that kind of money you could get a used longblock, built/rebuild it yourself, and have a better motor for the same money. If all youre looking for is a stock replacement KA, get a used one off the forums from someone that seems legit. I'll be selling my 94k mile KA thats very healthy in a few weeks, and probably wont be looking for more than $300 for it. |
#3162 |
Quick question. I need transmission fluid asap for my sr swap. So what kind of fluid can I get from auto zone, advanced auto or oreilly's that would work well? PS NO one has redline around here and don't have time to order it. Thanks, Dominic
#3163 |
SOMEONE PLEASE ANSWER. Does an OBD1 s14 have 2 cats? One being right at the downpipe? And does an OBD1 s14 have 2 O2 sensors? One also being at the downpipe? Trying to pass smog legally.
Nothing says racecar like a stock car with no interior. |
#3165 | |
If I were you, Id buy another motor, and maybe even start buying mods for it, but hold off on swapping it as long as you can. Let the parts keep flowin in as long as possible, then when your motor finally takes a dump, swap it in. You have an advantage in that you know your motor is dying, but you have some time to prepare for it. Not a low of people luck our like that- i know someone who was a week away from putting his turbo kit on, and spun a bearing on the highway. Had to sell all his turbo parts to get a replacement motor. So consider it a good thing- your motor runs, but will poop out on you eventually. So drive the fuck out of it, and look for another motor in the mean time. Look on the bright side... you dont have to do any more oil changes, just top that bitch off. ![]() |
#3166 | |
Cali guys- It seems to me that Smog is a HUGE pain in the dick... Why dont any of you just register your car in another state? I'm from PA and my car is registered at my Moms house in GA, because GA doesnt have any emissions. I rock the GA plates, and never need to get inspected. Thats what I'd do if i was in cali anyway, find someone outta state to let me register it at their address. |
#3167 |
So i failed smog, i was told that my o2 sensor was failing.
So my dad swaps out my o2 sensor but then he connects the positive and negative together even though i told him not to. The check engine light is still on, so i reset my ecu. The light goes away (comes on randomly) Then i go smog, and I fail horribly, my emissions doubled. My first smog i was passed 25mph, but failed the 15mph NO. Second smog I failed the 25mph, and now am a GP at 15mph. Do I have to get a new ECU or something? any advice is appreciated. |
#3168 | |
![]() Join Date: Nov 2007
#3170 |
![]() Join Date: Jan 2008
Good circuit breaker for a battery relocation?
CIRCUIT BREAKER 150 AMP / SELF TEST new PS82/150A - eBay (item 400012269315 end time Nov-15-10 09:14:49 PST)
#3171 | |
AFC #1
![]() Join Date: Oct 2003
Cooper Bussmann ® - Heavy Duty Fuses
#3175 |
![]() Join Date: Oct 2006
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
Ive seen cars with other chassis subframes in them, ie S13 with S14 subframe, and S14 with Z32 subframe, is there a difference in these subframes? Mainly taking about the S13, S14, and Z32 subframe. If there is a difference can someone point me in the direction of what has to be modified to mix and match?? Thanks.
#3176 |
Trader Rating: (33)
I have a 95 S14 that was originally sold in NC and it only had 1 cat on it when I bought it completely stock. But I also recently picked up another 95 S14 that I haven't really looked into where it was originally sold and it has 2 cats on it. My "guess" would be that CARB legal cars from California had 2 cats from the factory.
#3177 | |
#3179 |
![]() Join Date: Sep 2010
cracked hose
i have some cracked water pump hoses.. my mechanic didnt want to use a custom foot long hose from autozone cause it had no moldings so i was wondering can i drive my car like 10 miles with it leaking or will that automatically mess up my engine? the reason i have to move my car is that its at my friends place and they got evicted so i gotta move it asap any suggesions dont have time to look for the right hose thanks
#3180 |
