Old 04-29-2013, 12:05 PM   #3121
sr20det_510
sr20det_510 is an unknown quantity at this point
oh and alumi lightweight crank,wp,and alt pulleys?
sr20det_510 is offline   Reply With Quote
Old 04-29-2013, 12:06 PM   #3122
sr20det_510
thanks again u guys are the best unlike other forums where people are d$%ks
Old 04-29-2013, 12:47 PM   #3123
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
lightweight pulleys are a complete waste of money, especially on the crank. If you are going to swap the crank pulley go to an ATI damper, but if you aren't going to install solid lifters in the head to rev it high you don't need it.
HKS cams are great but expensive. BC cams have had bad quality control in the past but seem to be better lately, I don't know. Best bang for the buck in my book are Tomei's from my personal experience. They are half the cost of HKS and shouldn't be overlooked. There are many JWT fanboys here, and I have no objective data to enable me to argue for or against. Nobody locally to me runs the JWT cams.
The Megan manifold will probably crack unless reinforced. Make sure you use the exhaust hanger to the trans mount: without it your manifold will crack quickly. And yes, I know because I had a cracked megan manifold in my closet until I gave it away.
The 255lph fuel pump will easily work to 400rwhp and beyond.
Injector Dynamics top feed injectors are the best to work with, by far. Fuel injectors are really important. Some designs are hard to tune with or to get to idle well. I like ID1000s because you won't have any duty cycle problems at 350whp, you will have plenty of room to grow and getting them to idle will be easy. If you are going with a ROM tune though, find out what injectors they recommend and stick with it. The Tomei's are expensive for what they are. The Tomei FPR is fine. EMS is the most expensive option and if you are staying in the 350hp range, you may not have to go that big.
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal
Seraphim38 is offline   Reply With Quote
Old 04-29-2013, 01:24 PM   #3124
sr20det_510
AWESOME thanks for the input brother as far as everything else i listed u guys approve?
Old 04-29-2013, 01:46 PM   #3125
KoukiMonsta
KoukiMonsta's Avatar
if your going to run a metal headgasket i would deck the surfaces..
@UpshiftEngineering
Old 04-29-2013, 02:11 PM   #3126
sr20det_510
Well ima do the apexi 1.5 that's what everyone been saying
Old 04-29-2013, 03:21 PM   #3127
mattsil80wis
mattsil80wis is making a name for him/her selfmattsil80wis is making a name for him/her self
Originally Posted by 801nismo104 View Post
stock tb will be fine for only 350hp
im on stock tb making 403hp on the "codyace" setup
mattsil80wis is offline   Reply With Quote
Old 04-29-2013, 03:37 PM   #3128
sr20det_510
so deck or no deck?
Old 04-30-2013, 08:10 AM   #3129
JN1AS4
JN1AS4's Avatar
JN1AS4 is an unknown quantity at this point
Deck....to insure that all surfaces are truly flat. Before clamping the head down to the block.
JN1AS4 is offline   Reply With Quote
Old 04-30-2013, 08:33 AM   #3130
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Deck the head, deck the block, get the oil pump machined flat with the face of the block. No copper spray or rtv on the headgasket.
Tomei TYPE-L fpr
1000cc injectors are WAY to much. 550-750 is were you wanna be.
Stock intake manifold, stock tb
zombiewolf513 is offline   Reply With Quote
Old 04-30-2013, 08:36 AM   #3131
sr20det_510
deck
Originally Posted by zombiewolf513 View Post
I said the 1.5 because if you get a bunch of material removed you're compression ratio wouldn't be absurdly high, and if they didn't remove a lot you'd be sitting closer to a stock compression ratio and be safer from knock if you run into shitty gas.
Oh, and get some nice springs for those cams, not cheap garbage.
i tought you guys said dont deck?
Old 04-30-2013, 08:38 AM   #3132
sr20det_510
Originally Posted by BlackZenkiS14 View Post
Seems like a shit ton of machine work and excess expenditures that would otherwise be unnecessary for a daily?
Why not just run a stock block and head with cams and bolt ons and a JWT ECU? You'll still make like 350whp easy, and not have all the bullshit that comes along with a race prepped built engine. And you'll have a daily reliable tune that you don't have to mess with all the time, or take somewhere every year or so to get tuned?
ahhhhh confusion
Old 04-30-2013, 08:49 AM   #3133
zombiewolf513
Deck it and run a 1.5mm head gasket.
Earlier i was saying (this is my personal opinion, others may dispute), "if the machine shop cuts only a little bit off (.001"-.003" [off of the head AND block combined] when they deck, you can use a 1.1mm headgasket"
BUT... If you are ordering parts before you get the machining done, just get the 1.5mm head gasket. I say this because if they cut a lot off you're safe from too high of a CR, if they only cut a little off you're safer from knock.
On another note, you should get the machine shop to gap your rings for you before the hone so it doesnt get marred. Youll probably need to rent some sort of torque plate as well unless your machine shop does a lot of SR20s
Old 04-30-2013, 09:31 AM   #3134
Seraphim38
Seraphim38's Avatar
550s will be near out of duty cycle at 350whp. It has been discussed here many times. 1000s on the other hand, on my car, max datalogged value was at 50% duty cycle. However, it is worth noting that duty cycle increases under load at lower rpms, so I max my 1000cs on the street at low rpm and as boost comes on they back down on duty cycle. My 1000s at 350hp ran smooth as silk and now that I am dishing out more hp I am glad I bought the right injectors once and don't have to upgrade now.
I say deck the head and do the right head gasket based on target compression ratio. I currently have running a 0.8mm HG, since I have low compression Greddy pistons
Old 04-30-2013, 09:43 AM   #3135
zombiewolf513
Thats good to know. I take my setup to get the haltech initially tuned today, 9:1 .02" over pistons, eagle rods, all arp studs, all acl race bearings, 750s, 1.5mm head gasket, .004" total decked, 2871r, jwt s3 cams, doc bottom mount, hmic, map setup, stock intake and tb, stock springs, full exhaust. With the tune being done by national speed in wilmington im hoping for 400 whp, some friends say 410-420 but im not so sure on that. Opinions? Estimates? Guesses? My only concern is the turbos internal gate, i ported it, but im still concerned it wont offer the performance i need.
Member sr20det510, notice he has low CR pistons with his .8 HG. IMO do not do that with your 9:1 pistons, unless you have a nice EMS and a REALLY good tuner. Your CR would be through the roof.
Old 04-30-2013, 10:10 AM   #3136
sr20det_510
i have 9:1 86.5mm pistons with eagle rods
Old 04-30-2013, 10:51 AM   #3137
sr20det_510
yah i dont want high cp so i can run atleast decent boost
Old 04-30-2013, 10:56 AM   #3138
Fatboy Garage
Fatboy Garage's Avatar
Fatboy Garage is an unknown quantity at this point
Send a message via MSN to Fatboy Garage
Tomei TYPE-L fpr
What is your reasoning behind no copper spray on the headgasket?
On all the motors we have built we have never had an issue with the head gasket that has had copper sprayed onto it. Just wanted to see your opinion.
Godspeed Project
2518 Continental Ave
El Monte CA 91733
P: 626-442-3988
W:godspeedproject.com
www.facebook.com/godspeedproject
Fatboy Garage is offline   Reply With Quote
Old 04-30-2013, 11:07 AM   #3139
zombiewolf513
I called Apexi and that was what they told me...
No spray if the block and head have been decked. I figure it is sort of like when you take two panels of flat glass and twist them together, they create a tight seal. No need for a sealant between the two. Metal with a smooth surface finish acts in a similar fashion, and the apexi head gasket does appear to have some sort of very thin coating (maybe electro-plated?) on the two outer (the word escapse me right now but...) "sandwich plates."
I, personally, would be inclined to use copper spray if the surface finish was course or scratched somewhere though.
Old 04-30-2013, 11:33 AM   #3140
sr20det_510
because im afraid if i get my head and block deck they might shave too much
Old 04-30-2013, 12:58 PM   #3141
sr20det_510
thats it im getting a rb26dett lol
Old 04-30-2013, 01:34 PM   #3142
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Block is sleeved, both head and block decked and my Apexi HG failed without any copper seal.
Fuck Apexi gaskets lol.
I went cosworth and put a bunch of spray on it, almost 3000 miles of abuse later it's perfect.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 04-30-2013, 01:59 PM   #3143
zombiewolf513
Thats a first
Old 04-30-2013, 02:09 PM   #3144
EsChassisLove
Trader Rating: (26)
Thats a first
Nah it's not. Apexis fail with sleeved blocks. Darton failed to mention that until after wards.
Old 04-30-2013, 02:16 PM   #3145
sr20det_510
Old 04-30-2013, 02:26 PM   #3146
Seraphim38
Seraphim38's Avatar
news to me: I have a sleeved block with an Apexi HG. I will have to ask my builder and ask Mazworx, who did my bottom end about this, but so far I have no evidence of an HG problem and my motor puts down some good power. Anyway, I can't think of why someone would ever want to sleeve a block for 350whp: it is completely unnecessary.
Old 04-30-2013, 02:54 PM   #3147
EsChassisLove
Trader Rating: (26)
Who said my main goal was 350?
I'm slowly making my way to 600.
I'm not like most idiots that shoot for massive power right of the bat then come to realize they can't control the power for shit because they have driven anything near that powerful.
I sold the 2871 for a reason lol
Old 04-30-2013, 02:58 PM   #3148
jamg
what's the "codyace" set up?
Old 04-30-2013, 03:03 PM   #3149
zombiewolf513
If thats true, I wonder why that is
Like i said
What are you worried about? Just copy someone elses setup
Old 04-30-2013, 03:16 PM   #3150
zombiewolf513
JWT s3 cams
Jwt ecu
2871r extrude honed and swaned
Stock manifold extrude honed and swaned
Uhhh theres something else i think but i forget, its something like that
