07-19-2009, 02:45 AM | #3122 |
would a you trade a set of S13 coilovers for a salvage title zenki? lmao.
but yeah, how much for a set of S13 coils picked up? i am positive i have already asked this, but i forgot sorry, |
07-20-2009, 06:18 PM | #3124 | ||
yes sir in stock now $60
07-21-2009, 11:49 AM | #3127 |
what are the chances that a skid plate won't line up on my S13?
While I was fitting my front kit onto my car, I noticed that the previous owner must have hit the front of the car, causing some warpage in the structure near the headlights. Is there some template/measurement I can use to check to see if my car can accept it? THanks
"I'm a rage-aholic, I just can't live with rage-ahol!!!" |
07-21-2009, 12:46 PM | #3128 | |
we'll get those next month
-10 Quote:
We have made the holes oversize and slotted for S13 skidplates because we are well aware of how that old chassis tends to be.
07-22-2009, 01:06 PM | #3129 |
List of parts we are currently out of that is back in stock in August:
~Coilovers s13,s14,r32,FC,JZA,JZZ ~Wheel spacers in all sizes (we only have 4L 20 and 30mm left now) ~Camber arms New parts debut in August: ~Gen II hood vent spacer kit ~High Mount Intercooler Kit with short pipes, silicone coupler, and t-bolt clamps Stuff we're working on right now ~Genesis coilover ~S chassis rear knuckle with drop spindle, dual caliper, pillowballs
07-22-2009, 02:10 PM | #3131 |
lol, I know, so easy to get sidetracked.
I try to put priority towards stuff you cant buy anywhere else
07-22-2009, 03:53 PM | #3133 |
2.75 straight
2.5 straight 2 to 2.5 45 degree 2 to 2.5 straight
07-29-2009, 03:32 PM | #3135 |
$18 shipped, please specify color
sorry for late replies, I was recovering from desert heat stroke, smoke inhalation, and alcoholism at ASB 2009 check it
07-29-2009, 07:24 PM | #3136 |
Featured in JULY 2009 drift tengoku new parts section!
The CNC breather tank creates a vortex swirl of water/coolant inside that removes small air bubbles that rob cooling efficiency, and the sexy cooling fins don't hurt either! Available in 14 annodized color combos. They come with 2meters of see thru silicone hose and two radiator caps, and mounting clamps all for $100+sh Our slightly less sexy but still very effective polished aluminum breather tanks run $60 + shipping. The MAX Super Steering Angle Kit give you maximum angle, reduced ackerman, reduced bumpsteer, and 2 step adjustable quick steering with minimal modification to your oem parts! (parts only kit) is just $250 shipped. Includes: •1 Pair of MAX super angle knuckle box extensions •1 pair MAX Adjustable LCA bump stops •1 Pair of MAX super angle tie rod spacers •4 CNC lower arm gussets OR send in your OEM LCA and knuckle and we'll sell you the parts with professional install for $375+sh
08-07-2009, 05:15 PM | #3138 |
I have 20 and 30mm 4 lug in stock now and all sizes in stock at the end of the month
08-10-2009, 03:19 AM | #3139 | |
Please tell me this is a roll center adjusting spindle, it sounds awesome, I would like to hear more about it. Also, I need a price on a pair of 25mm 5 lug spacers and a magnetic oil drain plug shipped to 23325. I know the spacers are out of stock, but I can wait as long as you'll get them in at the end of August.
Instagram - SJKnoop |
08-11-2009, 07:52 PM | #3140 |
Sure, in addition to other things it corrects roll center. we have a special section on the MAX forum for communicating with our customers about development projects, its called the "WISH LIST"
$113 shipped
08-12-2009, 11:53 AM | #3142 |
only 15,20,25,30
08-14-2009, 11:40 AM | #3143 | |
Do I paypal you the money now or what? Do you have a set date on when the spacers will be in?
08-14-2009, 01:30 PM | #3144 |
now or later its up to you. Its around the end of the month, I dont have the exact day.
I'll manually approve your account. Were finished with the S14/15 High Mount InterCooler development. They are available now and the price is $380 with shipping to 48 states, limited time offer. Still need an S13 in the shop to do that application. Here are the final pix. I need to track test this still, im planning on seeing low water temps, and instant boost response, cant wait!
08-14-2009, 02:17 PM | #3145 | |
08-14-2009, 02:26 PM | #3146 |
If you have an s14/15 intake manifold and a S14/15 turbo you will need the S14/15 kit and you will have to modify your core support as needed.
08-14-2009, 03:10 PM | #3147 | |
Ill send payment on the 25th(payday) |
08-14-2009, 03:15 PM | #3148 |
radiator is in stock position
08-14-2009, 11:19 PM | #3149 | |
That intercooler set up is awesome btw! I have a Evo8 intercooler set up very similar to that in my car. I haven't noticed any water temerature differences at all and boost basically smacks you in the face. I went from a SMIC to this set up and it was WAY more responsive then that. The best part is my intercooler doesn't even get hot at drift events (on the cold side). I can go beat on it until my water temperature gets a little high, pop the hood and place my hand on the inercooler and it is warm on the hot side and room temperature on the cold side! That is also a stupid low price for that kit! I have a hook up at the shop I got mine done at and they told me if it was anyone else getting it done the cost would be around $700. Holy crap I just saw it is 380 shipped!!! That is INSANE!!!
08-15-2009, 12:24 AM | #3150 |
Dan will the S13 high mount kits use 3" couplers and piping?
or is there any you i can get some 3" couplers from you guys? black??? LMK plz, before my cobra ships out
