Old 09-21-2010, 03:52 AM   #3091
blu808
blu808's Avatar
Here are some shots of a C6 Zo6 exhaust I started making tonight.
I actually put all the straight sections in the lathe and turn down each end till it is perfectly beveled and even. Makes for some incredible welding.
Old 09-21-2010, 09:48 PM   #3092
blu808
blu808's Avatar
Started making an H pipe. Notching the tubing on the Milling machine is the way to go.
Old 09-29-2010, 01:39 AM   #3093
Om1kron
Om1kron's Avatar
not my welds, but on my valve cover.
the fittings that turned brown had a hard anodizing on them I only had one -8 weld on fitting, the rest were stupid -8 - 3/8th npt fittings that baker performance had in stock, second time I went there they didn't have shit I wanted. I'll stick with anplumbing in the future.
Wayne Edwards
https://om1kron.blogspot.com
Old 09-29-2010, 09:40 AM   #3094
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
I get all of my AN stuff from Summit and/or Jegs. Between the two, they always have the Earls fittings I need in stock.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 09-29-2010, 03:50 PM   #3095
Om1kron
Om1kron's Avatar
Yeah it's rare I ever DRIVE to pick these things up, I just wanted to get everything I needed to my fab dude since -10 is what I originally was going to put on the back of the hump but that's too big a hose for the drainback into the block.
Wayne Edwards
Old 09-29-2010, 03:57 PM   #3096
GSXRJJordan
GSXRJJordan's Avatar
Earl's store 1 in Hawthorne (been there for almost 40 years) will beat Summit/Jegs, and Tom is an awesome dude. I almost always go through him.
Old 09-29-2010, 04:57 PM   #3097
Broadfield
Broadfield's Avatar
I don't know, I used -10 on all of mine!?! Are you talking about the fitting on the rear drivers side of the block right under the head?
My Portfolio
Please Share
Check Out My Builds
Old 09-29-2010, 05:23 PM   #3098
Om1kron
Om1kron's Avatar
Yee! that's the one. a -8 (1/2) hose fits it perfectly, -10 (5/8) is probably slightly too big but then again I have an s13 motor, I don't know if the drainback from the valve cover on an s14 motor is larger.
temporary valve cover until my hybrid cover is painted and I get some of those sweet bolts like yours. =)
Wayne Edwards
Old 09-29-2010, 06:41 PM   #3099
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
I was in a bind a while ago and needed a PS line replacement ASAP
he ended up charging me more than what was advertised on Earl's site
would have rather bought the line or parts online had I had the option
been there a few times and it's always been that way
just a bit more than online
but *shrug* sometimes you just can't wait
Old 10-01-2010, 04:20 PM   #3100
RPSil13
RPSil13 is making his/her stupidity well-knownRPSil13 is making his/her stupidity well-knownRPSil13 is making his/her stupidity well-known
quick question to you guys on here, im making a seat bracket and need to bend form 1x1/4 steel, whats the best way to do it other than a press? ive seen people put it in a vise and heat it but idk how safe that is?
RPSil13 is offline   Reply With Quote
Old 10-01-2010, 04:40 PM   #3101
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
If you have an oxy-actelyene setup than you can do it easily. Just heat it up and let it get orange and you should be able to bend it with some pliers and just a little bit of man power.
If you're concerned about the integrity of the steel from being bent and heated, just reheat it till its orange again and quench it in water.
But it's safe, you shouldn't have any issues.
duffman1278 is offline   Reply With Quote
Old 10-01-2010, 05:08 PM   #3102
GSXRJJordan
Agree. Plenty safe.
My question is why mess with 1/4" steel? ~1/8" is what Wedge uses for their brackets, and what I've always used. You trying to make a 20lb seat bracket or what?
Old 10-01-2010, 05:11 PM   #3103
duffman1278
^^^^ lol Factor of Safety yo!! of like 100!! He's right though, 1/4" is freakin beastly, and mad overkill.
Old 10-01-2010, 05:15 PM   #3104
2point0
2point0 is an unknown quantity at this point
Originally Posted by blu808 View Post
Wish, I had your skills.
2point0 is offline   Reply With Quote
Old 10-02-2010, 12:46 PM   #3105
RPSil13
Agree. Plenty safe.
i have wedge brackets on there right now, but they sit way too high, i took a micrometer to them and it was 3/16s, so i figured its like wood, were the actual measurement is a bit smaller like a 2x4 is actually 1 7/8 x 3 7/8, im new to metal
thanks for the info guys ill look in to a torch and some 1/8 steel,
Old 10-09-2010, 06:57 PM   #3106
dorramide7
dorramide7 is an unknown quantity at this point
Originally Posted by punxva View Post
Luke you've nailed it on the head, there needs to be more informative posts on zilvia, and this is a step in the right direction.
Subscribed
love this thread idea..this is coming from someone who will be getting into fab very soon.
might i add that perhaps some details on what techniques were used to fab. ie, what equipment was used to bend tubing, what was used for mockups, what type of welding, what equipment was used for welding, etc..
just a though for us fab wannabes.
+1 for unique thread idea.
how to download xbox 360 games
dorramide7 is offline   Reply With Quote
Old 10-12-2010, 06:37 PM   #3107
silhou
silhou is an unknown quantity at this point
few random shots from work lately
silhou is offline   Reply With Quote
Old 10-12-2010, 06:59 PM   #3108
Corbic
Corbic's Avatar
Get and bend soft steel for the hardlines.
Old 10-13-2010, 01:57 AM   #3109
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
On the mig weld what process do u do to get a weld like that?
godrifttoday is offline   Reply With Quote
Old 10-13-2010, 02:07 AM   #3110
duffman1278
Is that MIG'd? Looks TIG'd. If it's TIG'd how many amps did you run for that?
Old 10-13-2010, 03:17 AM   #3111
blu808
blu808's Avatar
Wow. Nice welds. def TIG.
Here are some custom Blu808 control arms I made today.
Old 10-13-2010, 08:35 AM   #3112
Anthony@Chaser
Anthony@Chaser is an unknown quantity at this point
We finished the plug for the miata roof wing
And also built the mold.
Upper Half
Lower Half
We are going to start popping wings out this week!!
I also put together a little blog for our projects.
ChaserGarage.com | Custom work and Fabrication at Chaser Aerodynamics, LLC.
Anthony
Anthony@Chaser is offline   Reply With Quote
Old 10-13-2010, 02:23 PM   #3113
240 GTR
240 GTR is an unknown quantity at this point
cage i just knocked out in a week and a half for my car. 1.5 x .095 DOM tubing, built per the 2010 FD rulebook
240 GTR is offline   Reply With Quote
Old 10-13-2010, 10:06 PM   #3114
Sleepy_Steve
Sleepy_Steve is an unknown quantity at this point
Nice cage.
Also, totally didn't make the connection about Chaser being local to MD till I saw the newish 1812 anniversary tag on the miata. Roof spoiler thing looks good.
'95 240 | @SleepySteve72
Sleepy_Steve is offline   Reply With Quote
Old 10-20-2010, 09:26 PM   #3115
silhou
the mild steel drill bit is mig. welding with flux core @ 350 amps. weaving the weld for that look. the aluminum is tig @ 300 amps, pre heated material to 350 degrees.
also got bored and made a bash bar for my car. gonna add some 45 angles on the ends to extend to the fenders tomorrow.
Old 10-20-2010, 11:44 PM   #3116
godrifttoday
Trader Rating: (82)
Old 10-21-2010, 01:24 PM   #3117
Steve Lloyd
Steve Lloyd's Avatar
Steve Lloyd is an unknown quantity at this point
Sorry, but that cage isn't built to FD specs, the rear bars have to tie into the rear frame, no more strut tower connections for the rear bars. Found that out at Irwindale........
Steve Lloyd is offline   Reply With Quote
Old 10-21-2010, 02:10 PM   #3118
blu808
blu808's Avatar
Who told you that? My roll cage goes to the rear towers and passed tech at Irwindale.
Old 10-21-2010, 02:20 PM   #3119
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
I'm with Blu808 on this one, I know three local guys (Miro and the Tuerck brothers) that went out to Pro-Am and their cages are tied to the rear strut towers.
Here's a shot of Miro's car, he placed 3rd in Pro-Am I believe.
thefro526 is offline   Reply With Quote
Old 10-22-2010, 10:45 AM   #3120
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
he might just be confused.
they can tie into the strut tower,...not the strut tower bar
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
