Old 04-28-2013, 04:39 PM   #3091
sr20det_510
sr20det_510 is an unknown quantity at this point
Not yet but when I get it .5 bored over I'm prob gonna deck the block so everything is nice and tidy most likely gonna deck the head also what u guys think thanks for the input
sr20det_510 is offline   Reply With Quote
Old 04-28-2013, 04:42 PM   #3092
KoukiMonsta
KoukiMonsta's Avatar
get measurements from the machine shop how much material is removed, search online for a static compression ration calculator, plug in values and mess with HG value till you get desired compression ratio
@UpshiftEngineering
Old 04-28-2013, 04:50 PM   #3093
sr20det_510
Well the higher the comp the lower boost right? The more material removed the higher the comp so that's why go with a 1.5 gasket?
Old 04-28-2013, 05:19 PM   #3094
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
I said the 1.5 because if you get a bunch of material removed you're compression ratio wouldn't be absurdly high, and if they didn't remove a lot you'd be sitting closer to a stock compression ratio and be safer from knock if you run into shitty gas.
Oh, and get some nice springs for those cams, not cheap garbage.
zombiewolf513 is offline   Reply With Quote
Old 04-28-2013, 05:28 PM   #3095
zombiewolf513
Firstly, sorry for the double post
But what do you guys think about the 9:1 compression pistons? Run that 1.5 apexi gasket? What do u guys think about my setup? Ecu? Bore? Thanks for your input zombie
CodyAce swears by JWT, and they're highly rated. If you want a super nice standalone you could go with a Haltech Platinum Sport, a lot of people tune them. Or AEM, or PowerFC if you've got someone to tune it.
The post up there ^^^ answers the pistons thing in association with the head gasket. Keep in mind that what I said is just my understanding and opinion and what I did. You can see all the deets here: http://zilvia.net/f/builds-builds-on...ida-build.html
Originally Posted by KoukiMonsta View Post
has the block/head been decked?
that effects compression ratio, i have been researching it myself lately as im running the same setup...
apexi 1.5 seems to be my plan, tho i think this head has been surfaced twice..not entirely sure.
my buddy runs a 1.8 Tomei HG with only Tomei Poncams and Tomei Reytec without anything decked and the thing is super quick on 1 bar. Not sure what it's output is, but it can hang. I'd say go with the 1.5 to be safe.
Old 04-28-2013, 05:32 PM   #3096
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Go AEM V2 or AEM Infinity series.
Seriously fuck all other stand alones.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 04-28-2013, 05:33 PM   #3097
EsChassisLove
Trader Rating: (26)
And JWT S3s are really really mild cams. I regret getting them. I should of got S4 or S4HL.
LIFT is where the powers at.
Old 04-28-2013, 05:37 PM   #3098
sr20det_510
Well I'm about to get bc264's what u guys think?
Old 04-28-2013, 05:44 PM   #3099
zombiewolf513
screw BC. JWT cams hands down best choice.
Old 04-28-2013, 05:47 PM   #3100
sr20det_510
Why so negative towards bc
Old 04-28-2013, 06:01 PM   #3101
zombiewolf513
I've seen nothing but bad come from their products being used on my friends cars.
Old 04-28-2013, 08:51 PM   #3102
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Same here, friend installed some BC 264s and the car idled rougher, and sounded better, but said it was almost negligible power gains.
I went with JWT S3s myself. Can't wait to get them installed!
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 04-28-2013, 08:56 PM   #3103
gotta240
So sell em to me. Seriously. I'm local and am looking for a decent priced set.
Old 04-29-2013, 12:58 AM   #3104
sr20det_510
lol ok i guess ill get jwt s3's since i want this to be a daily.... so you guys agree with the .5 bore and 9:1 comp? decked block and head, 1.5 gasket, micro polish crank maybe not on the arp mains but for sure head, greedy pan jw or hks 264 cams, greddy intake gt2871r a power fc or aem stand alone.... maf or map?????
Old 04-29-2013, 01:00 AM   #3105
sr20det_510
also what kind of injectors and valves? springs? retainers? lifters? stoppers? adjustable cams? tb? can someone list like a complete lil beast reliable setup list please???? thanks guys
Old 04-29-2013, 01:34 AM   #3106
EsChassisLove
Trader Rating: (26)
With JWT S3s you can use a completely stock head. No need for fancy stuff.
Old 04-29-2013, 01:40 AM   #3107
sr20det_510
Ok great saves me some cash and as far as fuel delivery I will be using a walbro 255 koo right?
Old 04-29-2013, 01:42 AM   #3108
EsChassisLove
Trader Rating: (26)
Use an AEM 310lph. Costs a few bucks more an much more reliable.
550 or 740cc injectors with a Tomei FPR will be great.
Old 04-29-2013, 01:45 AM   #3109
sr20det_510
Thank will keep that in mind that setup will kill mpg tho huh
Old 04-29-2013, 06:40 AM   #3110
4-20sx
Trader Rating: (50)
4-20sx is an unknown quantity at this point
Feedback Score: 50 reviews
Send a message via AIM to 4-20sx
I believe Cody gets like 30 miles a gallon on his setup.
"get that nacho out of my face"
4-20sx is offline   Reply With Quote
Old 04-29-2013, 07:27 AM   #3111
EsChassisLove
Trader Rating: (26)
Not with a good tune. I average about 28 highway on my engine right now
Old 04-29-2013, 08:37 AM   #3112
BlackZenkiS14
Seems like a shit ton of machine work and excess expenditures that would otherwise be unnecessary for a daily?
Why not just run a stock block and head with cams and bolt ons and a JWT ECU? You'll still make like 350whp easy, and not have all the bullshit that comes along with a race prepped built engine. And you'll have a daily reliable tune that you don't have to mess with all the time, or take somewhere every year or so to get tuned?
-Kyle
Old 04-29-2013, 09:31 AM   #3113
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
not only that, with a 350rwhp the Greddy intake manifold will rob more bottom end than it will give back up top.
Go MAP sensor whether you do AEM or Apexi. Apexi is easier to tune since it is simpler than the AEM EMS, but the EMS has more long range capability and is just slightly more expensive, new.
Either the JWT or Enthalpy solutions for a GT2871R are quite competent. I had an Enthalpy and it was great, when I was at that stage.
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal
Seraphim38 is offline   Reply With Quote
Old 04-29-2013, 10:23 AM   #3114
sr20det_510
Thanks for the input guys really appreciate it, well i already got the pistons i mean i have the engine apart so might as well do it right? like this i know i have a good bottom end, or should i sell the pistons and not bore the block?, as far as porting the head im getting that done for free, so should i not got a greddy intake mani, should i get a freddy or stay with the stock one and just port it?, i have a guy that works for me does good port jobs,
Old 04-29-2013, 10:50 AM   #3115
Seraphim38
Seraphim38's Avatar
"doing it" while the motor is out can be a slippery slope: there's all kinds of stuff that can be done, the question is what is necessary to achieve your goals and what isn't necessary. The Mazworx workup on the bottom end of my SR was over $5 grand. It wouldn't be necessary for a 350whp goal, and labor/parts can add up quickly if not controlled.
Boring the block and running aftermarket pistons is ok. I wouldn't get too crazy with the bottom end, since that's not where most of the bang for the buck can be had. I suggest building it right for tolerances with good bearings, and spend the money on other stuff. There are plenty of SRs running to 400rwhp with a stock bottom end, a metal head gasket and ARP head studs (among other things not in the bottom end).
Locally my builder has had stock manifolds to 500rwhp on pro-am drift cars, and the purpose of using it was to get more torque in the midrange. Greddy/Freddy manifolds move the powerband up higher because of shorter intake runners and that may or may not be right for you: it may not gain you anything at 350rwhp, and if it does, it may not be in an area up high that you would use commonly in daily driving. If it isn't plainly obvious, spending it on a better turbo, or better intercooler piping, or into stage 1 or 2 professional head porting, or a better tune--these are the things that will pay off big time.
Old 04-29-2013, 11:09 AM   #3116
sr20det_510
awesome thanks for the heads up, as far as lobor for engine work, i will be doing my self, and my engine builder, i work at a shop were im surrounded by ex nascar engine builders, and ive been turning wrenches for about 5 years. so bottom end wont be that bad, i just want to make sure that .5 bore and the 9:1 comp is fine, i guess ill just port the stock mani, what tb should i use, once again thanks for your input guys and sorry for the million qurestions i just wanna do this right
Old 04-29-2013, 11:14 AM   #3117
801nismo104
801nismo104 is an unknown quantity at this point
stock tb will be fine for only 350hp
801nismo104 is offline   Reply With Quote
Old 04-29-2013, 11:22 AM   #3118
Seraphim38
Seraphim38's Avatar
.5 bore is also not a big deal. I have built two motors at +0.5. 9:1 compression is also fine. There are guys that go higher and run less boost for responsiveness and midrange, to reduce turbo lag, but it becomes more sensitive to tuning and detonation. Yes, stock TB is fine at that hp level.
Old 04-29-2013, 11:37 AM   #3119
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
Best advice ever. I had a s14 sr, swapped the bearings out, apexi 1.1mm hg, gt2871r, supertech single springs, hks step 1 256 / 264 cams, 555cc injectors, enthalpy tune, N/A s14 SR throttle body. Car never missed a beat and was by far the most reliable / fun motor I've ever owned. 355whp 330tq
mewantkouki is offline   Reply With Quote
Old 04-29-2013, 12:03 PM   #3120
sr20det_510
that sound like what i exactly want, but since i already have the pistons i might as well throw them in, so here it goes in conclusion micropolished crank, if needed main bearings, arp main yah or nah?, .5 bore 9:1 comp, no deck on block 1.5 apexi gasket with arp head studs, no deck on head just port, supertech single springs, either hks, bc, or jw 264 cams, stock lifters, stock ratianers, stock valves gt2871r stock tb, stock intake with port, megan top mount ex mani, 255 pump ok? 310? 800cc injectors, with tomei frp? call it a day? oh yeah and aem ems? you guys approve?
