Old 01-15-2014, 11:35 AM   #3061
juvi22003
juvi22003 is an unknown quantity at this point
Still a lil new here ordered some wheels yesterday for my S14
18x9.5+10 Front
18x11+8 Rear
For all the guys running these crazy specs what did you do to make it fit, i know i have to roll my fenders, will i need a slight pull? Im planning to run 235 40 front and 265 35 rear tires.
***FortuneMinds***
95 240SX S14 / 14 Lexus IS250/ IG / Twitter: juvi22003
juvi22003 is offline   Reply With Quote
Old 01-15-2014, 12:45 PM   #3062
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
First off, those tires are definitely not classified as max rubber on those size wheels. As far as fitment goes you'll have to to dial in some camber if you don't want to pull your fenders
spooled240 is offline   Reply With Quote
Old 01-15-2014, 01:39 PM   #3063
juvi22003
I know they are max not rubber, this the first thread popped up that i think i could ask car is currently in the body shop getting a new paint job and wanted to know what other work i would need to do other than rolling the fenders and camber arms. I don't mine doing a lil fender work since its in the shop right now doing a color change and other body work......
***FortuneMinds***
Old 01-15-2014, 02:29 PM   #3064
Kensi
Kensi's Avatar
Kensi is an unknown quantity at this point
18x9.5+10 Front
18x11+8 Rear
I'm assuming you bought the Cosmis Racing XT-206R?
You will need a big pull and camber in the rear considering the offset and width of the wheels. I'm sure the stretched tire thread can help you more. I would recommend different tire sizes *cough* 305's *cough*
Kensi is offline   Reply With Quote
Old 01-15-2014, 03:45 PM   #3065
juvi22003
Appreciate the help, think i'm gonna stick with the 265 for now, i don't have all that power yet lol.
This was my old IS with 11 in the rear with a 265 and all i did was roll fenders, no camber arms.....
***FortuneMinds***
Old 01-15-2014, 04:18 PM   #3066
ka-titties
ka-titties is an unknown quantity at this point
you're comparing apples and oranges here. this is a 240, not a Lexus that's 15 years newer.
ka-titties is offline   Reply With Quote
Old 01-15-2014, 06:46 PM   #3067
juvi22003
Yes i know that, the point i was trying to make here was that i fit 265 on a 11 and it didn't even look like it was stretched. So the 305 was a lil extreme....
***FortuneMinds***
Old 01-15-2014, 06:48 PM   #3068
blackrms13
blackrms13's Avatar
you must have a different definition of "stretch" than most of us...
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 01-15-2014, 07:37 PM   #3069
juvi22003
I guess so !
***FortuneMinds***
Old 01-15-2014, 09:41 PM   #3070
HighwaystarJC
HighwaystarJC is an unknown quantity at this point
18x9.5+10 Front
18x11+8 Rear
you will not find what you want in this thread. check the wheel fitment thread or do some searching
HIGHWAYSTAR/TeamSUN*WORKS
@HighwayStarJC_sunworks #HSGS14
HighwaystarJC is offline   Reply With Quote
Old 01-16-2014, 10:17 AM   #3071
juvi22003
Thank you i did...
***FortuneMinds***
Old 01-16-2014, 01:28 PM   #3072
ka-titties
10-4 rubber ducky
Old 01-22-2014, 12:51 PM   #3073
jdm60
jdm60's Avatar
jdm60 is on the path to ruinjdm60 is on the path to ruin
I really need some help. Varrstoen just released a 18" wheel in their es6 model and I'm planning on picking some up.
They only offer 9.5 and 10.5 inch wide wheels. I am new to the wheel figment deal and I want to determine what would be the best offset to go with with a minimal fender pull.
Here are the options:
Front
9.5 et12
9.5 et22
Rear
10.5 et15
10.5 et22
I apologize for the noob question. I try to compare referencing some post on here, but I rather be safe than sorry.
jdm60 is offline   Reply With Quote
Old 01-22-2014, 01:57 PM   #3074
jr_ss
You need higher offsets if you want minimal pull/roll.
For instance, I run 9" +23 up front and 10" +36 out back. I have just a minor roll for the rear and haven't touched the front. I'm not stupid low though, roughly 1 finger width above the front/rear tires.
Old 01-22-2014, 04:38 PM   #3075
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
9.5 22 might fit out back on an s14 but that depends on height and tire choice. The rest, less likely.
My 17x10 +18 are 1.5 inches outisde my stock, pulled and rolled s13 fenders (with 315/35/17s for reference)
Sent from my SGH-T999 using Tapatalk
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal
Seraphim38 is offline   Reply With Quote
Old 01-22-2014, 09:21 PM   #3076
jdm60
jdm60's Avatar
Awesome, thanks for the feedback.
Old 02-09-2014, 11:14 AM   #3077
starfireS14
starfireS14's Avatar
starfireS14 is an unknown quantity at this point
Sorry for the thread jack but not sure where I saw someone list the different tires and which ones are true to size, bigger and smaller. I know R888's for example run bigger and some falkens run smaller just trying to find the list.
95 HardTop MKIV
starfireS14 is offline   Reply With Quote
Old 02-09-2014, 11:37 AM   #3078
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
I simply just go look at the actual specs for each tire in question. Each manufacturer will list the specs. If Tirerack carries the tire in question, it's the easiest place to check. Here are the specs on the Toyo:
http://www.tirerack.com/tires/tires....el=Proxes+R888
You can then compare section width, tread width etc.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 02-09-2014, 11:01 PM   #3079
S14DB
AFC #1
S14DB's Avatar
Monsters of Grip: Nine Summer-Performance Tires Tested - Comparison Test - Car and Driver
Is this the latest grip test?
Old 02-09-2014, 11:09 PM   #3080
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Grassroots motorsports is probably the best place to look for more recent tire tests.
Also, the results from Solo Nats in the street tire classes.
Old 02-09-2014, 11:30 PM   #3081
S14DB
AFC #1
S14DB's Avatar
Links ?
Old 02-09-2014, 11:38 PM   #3082
e1_griego
e1_griego's Avatar
Trader Rating: (24)
I'm not sure they're online.
The tl;dr is the top tier stuff is all fast. Rivals, Z2s, and rs3s. There is a new z2 star spec on the horizon, and a revised rs3, but they won't be out for a few months.
Rivals and rs3s aren't as good in the wet as the z2, though I think the z1 reigned supreme for inclement weather.
Autocrossers care more about street tires than any other group of folks though I'm biased since that's my sport of choice.
Old 02-10-2014, 01:00 AM   #3083
mad-ass
mad-ass's Avatar
So, I currently have on my S14..
18x9.5+15 235/40/18
18x10+38 275/35/18
keeping same wheel/alignment/ride height..I've been entertaining myself to some new tire sizes.
255/35/18 on 9.5J and 265/35/18 on the 10J
I think this should be a pretty fun setup for dicking around the town. Will update when I actually get the tires. LOL
Old 02-10-2014, 11:29 AM   #3084
spooled240
spooled240's Avatar
^ You'll probably have to dial in some camber and have some wheel gap to keep it from rubbing with those wheels in the front. I had a 255/35r18 on a 18x9 +25 in the front of my stock body s14 and the fitment was great, but I was really low so it rubbed.
Old 02-13-2014, 11:46 AM   #3085
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
how is fitment with 255/35 up front on stock tubs on a s14, rubs alot when you cut full lock? wheels are 18x9.5-1, will be running 30mm overs up front.
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 02-24-2014, 02:11 PM   #3086
spooled240
spooled240's Avatar
You can use this for reference. 18x9 +25 255/35r18. Only rubbed during really hard cornering at full lock. Camber was probably around -2 (this is after I raised the ride height up a bit)
Old 03-05-2014, 05:48 PM   #3087
jewlz
jewlz is an unknown quantity at this point
^specs for the rear? i'm kinda diggin this functional setup
jewlz is offline   Reply With Quote
Old 03-09-2014, 05:35 PM   #3088
Blackzenki82
Blackzenki82 is an unknown quantity at this point
Send a message via AIM to Blackzenki82
Sup guys? I've been looking all over the place, but since everyone stretches tires, and goes for all the stances these days, I've got some questions.
I've recently aquired some Cosmis wheels, 18x10 +20 in the rear, and have a line on some free Nitto NT05's that are 275/35/18's (like, 8 for free!!). Of note, the 275s run an actual 266 as per FD measuring, so they're kinda like a wide 265/35.
Question is, will those tires fit on the x10 +20's without stupid camber? I'm really not wanting to go past -1.5, and would like to stay as close to zero as possible.
Pic for reference. mexipoke due to 25mm H&R spacers to my my G35's sit all fancy like, but maybe you can get the picture.
Wheels are the x10 +20's, with a 235/40 mounted. With somewhere around 0.0 to -0.5 or -1.0 camber.
I'll see if I can find a better shot of the rears, test fit only lasted about 10 minutes.
Honestly, I prob need to just mount one up, pull the spacer, and test fit, but I'm just here to see what you guys know before I waste my time runnin' round like that.
Blackzenki82 is offline   Reply With Quote
Old 03-09-2014, 05:59 PM   #3089
mad-ass
mad-ass's Avatar
Blackzenki82,
This is my setup on the rear when I was on coilovers.(well, I still have same wheel/tire setup, just no longer on coilovers)
18x10+38 0 camber, the rear fender is pulled 3/4 inch from stock.
The big problem I was having was that the wheel inner barrel would hit the front of Rear LCA due to the amount of..more like lack there of, camber I had. I was toying with ideas on notching the LCA with some left over DOM tubes and what not..but never got around it because I am no longer on coilovers.
^That's my current state of the car(Tein lowering springs)
I had 0 rubbing with my 0camber, so your new wheel being 18mm more aggressive than mine with same size tire(Mine are 275/35/18 RE050A RFT ) you are either going to have to pull 18mm more than what mine is, or run 265/35/18's to keep the camber within the spec you want.(it'll be better match up with 235/40/18 if you use 265/35/18 rather than 275/35/18)
hope that helps!
Old 03-09-2014, 07:08 PM   #3090
jr_ss
I don't know what my camber is in the rear right now(I should buy a camber gauge) but I'm guessing around -1 or -1.5 with my 285's. I'm not dumped on the frame rails though. I have no intentions of going that low.
Marshall, I'm assuming you have little to no gap on the rears? If so, you're going to be cambered in quite a bit. 20's are too agressive unless you want that "stance" look. I wanted mine to be functional.
