Old 03-21-2014, 10:24 AM   #3001
slower than you
slower than you's Avatar
slower than you will become famous soon enoughslower than you will become famous soon enoughslower than you will become famous soon enough
I don't know for sure and don't know if anyone knows, but I would guess probably 15x7.5 0 offset or so. Probably 195/60/15. Might even be 14's.
slower than you is offline   Reply With Quote
Old 03-21-2014, 10:45 AM   #3002
jalgo3
jalgo3 is an unknown quantity at this point
wheel fitment help
I drive a 96 s14 zenki i just got a set of wheel 18x10 +12 all around what would be the best tire size would these sit flush or would i need a spacer? Before i get flamed im new to this whole thing so im trying to get as much info as possible and yes i have searched around maybe im over looking it but i cant find what im looking for. anyone have pictures of a close offset and wheel size please post. Also include tires size!
jalgo3 is offline   Reply With Quote
Old 03-21-2014, 11:42 AM   #3003
kamilitaryman
kamilitaryman's Avatar
kamilitaryman has a little shameless behavior in the past
Originally Posted by da_crew10 View Post
Dude look through this thread and you will find your answer. I mean what kind of question is where do you guys buy your wheels?
Sorry, perhaps I should've been a bit more detailed on that one. I was asking what your favorite source for wheels, where a company has great customer service & wheels @ a good price.
Originally Posted by fliprayzin240sx View Post
First off, figure out how much poke you want, that will dictate pretty much everything from offset to tire width to how much roll/pull you'd need or how much camber or even how low you can go. Since you said you don't want the stretched look, go look thru this thread and see if you find anything you like. If you do, just see what their specs are if its not listed already...PMing the person who posted it up never hurts...
http://zilvia.net/f/showthread.php?t=166563
There is a lot of planning involved to achieve the look you want, there's no question about that. I'll do some more research and return to the thread once I've made a decision. I simply want maximum contact patch with an aggressive look. I would like to avoid using spacers, I can deal with rolling/pulling of the fenders.
I also should've mentioned that the car will be driven at the track often.
I'll keep searching in the meantime...
400HP KA24DET in progress
kamilitaryman is offline   Reply With Quote
Old 03-21-2014, 02:57 PM   #3004
jalgo3
Can someone answer me this what will i need to do to run a 18x10 +12 all around with maybe a 225/40
Old 03-22-2014, 01:50 AM   #3005
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Well, atleast you know what you want to do out of it. Personally, for a set of square, meaty track wheels, I'd go 17x9.5 +22 (ish) and slap some 255/40-17 Nitto NT01 for grip. Should be good enough to get 0* camber in the rear and get away with some pull.
CLICK HERE!!!
Old 03-22-2014, 03:17 AM   #3006
mothon
mothon's Avatar
mothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond repute
225/40 will be fine.
You need to spend some time doing more research. Here is a good place to start. http://rimtuck.com/
instagram: madness_garages14
mothon is offline   Reply With Quote
Old 03-23-2014, 11:19 AM   #3007
jameswouldgo
jameswouldgo's Avatar
jameswouldgo is an unknown quantity at this point
I'm lost in this wheel fitment game and wondering if these rims would fit my ride, from another perspective.
http://zilvia.net/f/showthread.php?t=543189
jameswouldgo is offline   Reply With Quote
Old 03-23-2014, 11:25 AM   #3008
jalgo3
I know the 225 40 wouldnt be a problem but rimtuck seems to give me less search results everytime i search a wheel size but i know the 18x10 will fit its just how will they fit with the +12 offset will they poke or am i going to be tucking rim and need spacers to flush it im def. Doing my research its just hard when everyone is running mostly negative offsets...
Old 03-23-2014, 04:45 PM   #3009
cody_sir
cody_sir is an unknown quantity at this point
18x10 +12 up front of an s14?
hey guys so I found some wheels that I might be purchasing however they are a little wider than my original plan for the front. It will be going on an s14.
My fenders will be rolled but I dont want to pull... the rears are 18.10.5+6 with a 225/40 probably and the fronts are 18x10 +12 with a probably a 215/40 or 225/40.
The rear setup im sure will work with just a roll and lots of camber but the front is what im not to sure of...
Does anybody know for sure if it will work up front just a roll and more camber?
cody_sir is offline   Reply With Quote
Old 03-23-2014, 04:52 PM   #3010
jalgo3
My fenders will be rolled but I dont want to pull... the rears are 18.10.5+6 with a 225/40 probably and the fronts are 18x10 +12 with a probably a 215/40.
Im in the same boat as you 18x10 +12 all around i found a guy running 18x12 +15 with a 5mm spacer so we should be good but idk yet when i get mine on ill let you know a little more but 215 is a little risky for me on a 18x10 lowest ill go is a 225 just for the fact it has a little more contact around the rim plus i would hate to see that 215 blow out fast if your driving crazy
Old 03-23-2014, 06:03 PM   #3011
I'm Redline
I'm Redline's Avatar
Originally Posted by chuki.s13.coupe. View Post
But I want to be high off the ground like a "BOSS"
I suppose you wear your pants like a Prison Bitch too, huh?
When you slap over fenders on, you're supposed to cut the oem fender high up, both inner and outer since theres two metal. Then you're supposed to reweld them back together so the its sealed. Doesnt look like they cut the old fenders high enough.
From the looks of the picture, it doesnt look like they welded/sealed the inner and outer fender back together. You'll get shit/waster getting inside your car.
Here's a good step by step of the process...
http://www.cardomain.com/ride/392168...-silvia/page-4
Thanks for this. #searchfunctionworksbitches
Originally Posted by Sean P. View Post
Going 17x9+12 up front and x9.5+12 in the rear
Should I go 215/40 f and 215/45 r or 215/45 f 225/45 r?
Would a 215/45 up front cause rubbing issues?
THIS is EXACTLY what I was looking for! What are the specs as it shows in this photo?
My work in progress...
Old 03-24-2014, 11:09 PM   #3012
wurley
wurley's Avatar
wurley is an unknown quantity at this point
How much stretch you run makes a difference. Back will need a pull or some camber, or combination of both. And what size fenders in the front? Shouldn't be extremely difficult
wurley is offline   Reply With Quote
Old 03-24-2014, 11:12 PM   #3013
jameswouldgo
Not sure what size fenders is up front (traded for this ride). What tire size would you prefer for the best least hassle fit?
Old 03-25-2014, 03:29 AM   #3014
mothon
mothon's Avatar
It really all depends on how low the car is and how much camber you want to run. It will be flush unless you run a lot of camber.
Old 03-25-2014, 01:02 PM   #3015
Confuzedd
Confuzedd is an unknown quantity at this point
Would 18x9.5 +23 Mb battles fit on a s14 zenki or should I have gone with a +15 offset ?
Confuzedd is offline   Reply With Quote
Old 03-25-2014, 07:26 PM   #3016
fliprayzin240sx
May or may rub the front strut/coilover...depends on what you have.
CLICK HERE!!!
Old 03-26-2014, 05:29 AM   #3017
I'm Redline
+15 Battles don't need spacers. You'll fit those, and maybe need 5mm or 10mm, but you'll have to run some stretch, and get rid of that OE camber in back. 17x9+15's with 225-40's fit tight. These are 17x9+15's with 225's and a slight adjustment with Isis knock off's coils
http://clarksville.craigslist.org/cto/4361782726.html
Old 03-26-2014, 07:45 PM   #3018
wurley
wurley's Avatar
245 rear would work good. 215 or 225 up front depending on how wide you think your fenders are. 35 or 40 sidewall depending on how low you want to take it. Check out some other s14's http://rimtuck.com/search/datasheet&...&sort=4&page=3
Old 03-27-2014, 12:34 AM   #3019
cmercer89
cmercer89 is an unknown quantity at this point
Does anyone know if xxr 530 18x8.75 +20 on the front, and 18x9.75 +20 on the rear will give a flush look? If not how far do you think it will stick out passed the fender?
Sent from my SM-T520 using Tapatalk
cmercer89 is offline   Reply With Quote
Old 03-27-2014, 12:39 AM   #3020
cmercer89
Sorry it's a 1995 240, it's not super slammed yet so that's not really an issue right now
Old 03-27-2014, 07:39 PM   #3021
fliprayzin240sx
Depends on your definition of flush. Front probably wont poke out but the rear close to stock ride height will poke out some.
CLICK HERE!!!
Old 03-28-2014, 06:55 AM   #3022
NordicMistBB6
NordicMistBB6 is an unknown quantity at this point
s13 coupe here. im just curious if an 18x11 et11 will fit out back with just a pull, id rather not run an over. if anyone has a picture of their car running something similar id appreciate it.
NordicMistBB6 is offline   Reply With Quote
Old 03-28-2014, 05:26 PM   #3023
Steve5405
Steve5405's Avatar
Steve5405 is an unknown quantity at this point
Will 16x7 +25 xxr 522's clear z32 breaks?
Steve5405 is offline   Reply With Quote
Old 03-28-2014, 08:30 PM   #3024
fliprayzin240sx
Hard with +11. You'd need a massive pull, lots of camber and stretch to make that happen.
CLICK HERE!!!
Old 03-28-2014, 08:54 PM   #3025
jalgo3
Lots of work for 18x11 +11this pic is with -1
Camber
Old 03-28-2014, 09:00 PM   #3026
jalgo3
Wheels/Tires Weds Kranze LXZ 18x10 -44, Federal SS595 225/35/18 (front) 18x11.5-8 Federal SS595 255/35/18(rear)
Read more: http://www.importtuner.com/features/...#ixzz2xJhrPrlF
But of course with some over fenders you can work wonders
Old 03-29-2014, 07:44 PM   #3027
cody_sir
will 18x10 offset -10 fit in rear of an s14 with a 225/40 with ONLY a roll and camber?
Old 03-29-2014, 07:59 PM   #3028
jalgo3
You shouldnt have any problems i was gonna run a 16x10 -45 all around but even tho 18s r a diff story im still running 18x10 +12 with a 225/40 there working out quiet well i even had to run a spacer so you should have no problems!
Old 03-30-2014, 07:58 AM   #3029
I'm Redline
Heard the term 0-Disc from Allen Hsu from Work Wheels. Can anyone enlighten me to exactly what this means as to wheel fitment on S Chassis, and better yet, SHOW some photos on '95-'96 zenkis or fastbacks?
Old 03-31-2014, 08:56 PM   #3030
fliprayzin240sx
Work wheels has 3 Disc face differences when it comes to their multi-piece wheels: O-Disc, A-Disc, R-Disc and now a T-Disc. Difference between the 4 is basically brake clearance and amount of lip possible with each wheel. O-disc if you want the most amount of lip possible but the catch is you have the least amount of brake clearance. T-Disc gives you the most brake clearance but you have the least amount lip. Basically, the more brake clearance you get, the less lip you'll have. You'd need to go to a lower offset to get the same amount of lip.
Just to understand, I'll use a 18x10 VS-XX w/ 112mm lips:
O-disc +7
A-disc +0
R-disc -17
T-disc -22
They are all the same width, same lip amount but the offsets are completely different between the 4 faces.
If you need a T-disc but you need similar offset as the +7 O-disc, you'd need to get +4 or +9 R-disc but instead of getting 112mm lips, you'd only get 87mm.
http://www.workwheelsusa.com/media/w...FR_2014_v1.pdf
CLICK HERE!!!
