Old 05-08-2008, 06:17 PM   #271
Coolwhip
Coolwhip's Avatar
Coolwhip is an unknown quantity at this point
Send a message via AIM to Coolwhip
Oil starvation will always occur on a wet sump and crazy driving. Once the oil creeps up off to one side or towards the rear of the sump when launching or cornering hard then the pick up goes dry. Proper windage and baffling is the fighter to those issues as well.
Adding oil is a temp. remedy. Adding a cooler and lines allows more capacity. Only problem is that with more oil in the sump can cause the crank to slap oil and usually ends up in lost HP and slower revs.
Its a pretty deep issue. But with normal use/ modest racing you shouldn't see problems which require the microscope to the nitty gritty.
Coolwhip is offline   Reply With Quote
Old 05-17-2008, 05:07 AM   #272
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
Originally Posted by GoodOl'S13 View Post
Where can i find intercooler piping for a S13 rb25 w/ Greddy IM?
+rep for help
Syko Performance has them. There web site says they don't but they really do. Just email the owner Gary. His address is on the site.
s13coupedrfter is offline   Reply With Quote
Old 06-04-2008, 11:07 AM   #273
noeleven
noeleven is an unknown quantity at this point
Hm... can you put A/C on the s14 with Rb25det?
noeleven is offline   Reply With Quote
Old 06-04-2008, 12:19 PM   #274
gijoe69
gijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant future
Send a message via AIM to gijoe69
yes, you can have A/C in a S14 w/ RB2x motor......its just a matter of fitting the KA AC lines and extended them...any AC shop should be able to do it...
gijoe69 is offline   Reply With Quote
Old 06-19-2008, 10:34 AM   #275
Rizzo
Rizzo is making a name for him/her selfRizzo is making a name for him/her self
I have a rb25det that is getting close to done and i can not find what oil is recomended for the trans and how much does it take? Thanks in advance.
Rizzo is offline   Reply With Quote
Old 07-02-2008, 05:19 PM   #276
Solidus311
Solidus311's Avatar
Solidus311 is making a name for him/her selfSolidus311 is making a name for him/her self
What is the rb25det oil pressure supposed to be?
cardomain.com/ride/3113705
Solidus311 is offline   Reply With Quote
Old 07-02-2008, 05:45 PM   #277
Coolwhip
Coolwhip's Avatar
Idle = +/-25psi
Old 07-02-2008, 06:57 PM   #278
Solidus311
Solidus311's Avatar
Originally Posted by Coolwhip View Post
Idle = +/-25psi
wow something is seriously wrong, I'm running about 10 now. I'm not sure when the oil has been changed last. I just got the car. Will an oil change help?
Old 07-02-2008, 08:43 PM   #279
bardabe
bardabe's Avatar
change oil, see if it goes up, if not the oil pump / bearings are worn.
Review Thread
bardabe is offline   Reply With Quote
Old 07-02-2008, 08:43 PM   #280
bardabe
bardabe's Avatar
I had about 20ish at idle, after warm up with 5W-30 Royal Purple
Review Thread
Old 07-02-2008, 08:47 PM   #281
Solidus311
Solidus311's Avatar
bearings are worn.
Yeah I did some research. I'm going to buy a mechanical oil pressure gauge and change the oil and see if it is the same. Bearings as in connecting rod bearings? Also how hard is it to replace the oil pump? Thanks for your input guys.
Old 07-09-2008, 10:59 AM   #282
sldbyuramg
sldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant futuresldbyuramg has a brilliant future
can somebody please pm me a pic of the RB20 ignition system... in there engine bay...thanks
sldbyuramg is offline   Reply With Quote
Old 08-23-2008, 11:19 PM   #283
blackhawk8259
blackhawk8259's Avatar
blackhawk8259 is an unknown quantity at this point
s15 Swap questions?
Ok i have a few questions for who ever knows enough about rb swaps vs sr swap.
Ok heres the deal. I am going to do a swap into my 1991 nissan 240sx for a grad project at my high school. heres so guestion.
1. Sr or Rb?
2. Which is cheaper to install?
3. Which is easier to installl?
4. How much to install either?
5. Cost of parts?
6. which i could make the most hp for a low budget?
Thanks so much cuz i really need to get started on this project. It means alot.
blackhawk8259 is offline   Reply With Quote
Old 08-23-2008, 11:22 PM   #284
blu808
blu808's Avatar
are you joking?
Old 08-23-2008, 11:24 PM   #285
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
1. Sr or Rb?
5. Cost of parts?
just turbo the motor in your car !.
cheapest way.
racer98 is offline   Reply With Quote
Old 08-23-2008, 11:24 PM   #286
racer98
racer98's Avatar
what engine do you have and did you see if your leaking oil from somewhere else ?
Old 08-23-2008, 11:34 PM   #287
racer98
racer98's Avatar
Originally Posted by blu808 View Post
are you joking?
I have some good ones from another forum.
Easly, guys who have S30's are spending about any where from
$2,500 for a shot motor canada and dropping another $10K in overhaul and rebuild with out tunning.
clean motors are good to start with and the prices are a little higher just depends what are you going to be doing.
example should I get an R32 GT-R. motor is comming out RB30E bottom end with .20 over lots of bottom end work R34 turbos , Single 90mm throttle body....... R34 Z-tune parts, HKS V-Cam set up but run the RB25DE neo head and mill/port grind and trim some items here and there. leave it looking stock 3.1 set up when Im done. run a HKS oil pump and an aftermarket oil cooler.
that right there is $15,000 easly.
even though prices are comming down on R32 motor but the owners who dont take care of them is going up and the quality of the used motors are going into the trash can.
so you have to be careful what you get.
R32 motor RB25DET transmission = $3800
R33 $4800
R34 red $5800
R34 Nur - most of them are just sold as long blocks $++++
Old 08-24-2008, 11:11 PM   #288
racer98
racer98's Avatar
just as a heads up.................................
you can use a Z32 transmission rear section and use the bell housing from the AWD transmission from the GT-R and you have a transmission set up for your Rb26 2wd set up.
Old 08-29-2008, 09:40 AM   #289
Jesses240
Jesses240's Avatar
Jesses240 is making a name for him/her selfJesses240 is making a name for him/her selfJesses240 is making a name for him/her self
ok I searched throughout this RB FAQ and didn't find any definitive answers to my issue.
I need to rebuild my 95 r33's rb25det transmission... I need to know part #'s or if there is a US transmission that has the same internals So I can can order syncro's from and rebuild my transmisison.
I also searched google and couldn't find if the internals of the RB and anything in the US that are the same.
--Jesse R33
Jesses240 is offline   Reply With Quote
Old 08-29-2008, 10:00 AM   #290
racer98
racer98's Avatar
just get it from a Z32 TT and swap your bell housing on to the rebuilt Z32 TT 5speed also you know you can use the Getrag 6 box as well from the JZ80 TT also I know there is a Cobra R 6 speed from BW you can swap as well.......
takeing it up anoter notch is using the SMG box from the E46 M3 but you will need to swap and modifiy the bellhousing + also figure out the computer for the SMG !
Old 08-29-2008, 11:04 AM   #291
ProjNightshade
ProjNightshade will become famous soon enoughProjNightshade will become famous soon enoughProjNightshade will become famous soon enoughProjNightshade will become famous soon enough
I knew about the Z32 compatibility. Please explain what I would need to do to use the 6spd's you mentioned. I know the supra tt tranny's are way expensive, but I would imagine that the cobra r tranny is significantly less expensive.
ProjNightshade is offline   Reply With Quote
Old 08-29-2008, 11:08 AM   #292
racer98
racer98's Avatar
its all about having those items side by side and making slight modifications to fit on the bell housings...
that is the same thing for the BW transmission's
Old 08-29-2008, 11:13 AM   #293
ProjNightshade
So my understanding is that the input shaft that goes through the clutch is the same as the rb25/z32 and will accept the rb25 clutch? And then I would need to have a new driveshaft made and modify the tranny x-member? Then like you said, just modify (which I assume means just drilling new holes) the rb25 bellhousing to accept the new rear section?
Old 11-04-2008, 08:30 PM   #294
soon2bs13
soon2bs13's Avatar
soon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-knownsoon2bs13 is making his/her stupidity well-known
Send a message via AIM to soon2bs13
I read through the FAQs and have some questions of my own to help clear things up for me. Hopefully you guys can help.
1.) The Oil Pressure on the Lower KA harness is 1 wire (I believe), while the Lower RB harness is 2 wire. I read that you cut the KA and put it on the RB. Do you just splice the 2 wires into 1 and put it in?
2.) My RB starts up and has a high idle. When giving it throttle it seems like it is hitting a rev limiter. When I unhooked the MAF it was acting the same with the high idle. Could this be a bad MAF?
3.) I did not read anything that stated of lines that needed to be blocked because of them not being used. Anyone have any information or pictures?
4.) There is a big hose near the firewall on the intake side that needs to be clamped on somewhere but I have no idea where. It is a vaccum but I am not sure where it goes?
Thanks.
neg repping is cool!!
soon2bs13 is offline   Reply With Quote
Old 11-04-2008, 09:10 PM   #295
racer98
racer98's Avatar
Nissan parts are interchangeable between car looking into the parts on the Z32 TT might be a good start to find that conector your looking for.
check the IAC and also there are some throttle adj on the itb for that motor if not you might have a air intake leak.
think this might be the problem of an open or missing line from your motor.
cap it off and play with what works best for your motor
now before you go any farther on the motor what is the compression and also is it an r32 or r33 motor ?
Old 11-04-2008, 10:43 PM   #296
soon2bs13
soon2bs13's Avatar
I have the RB Oil Pressure sender, just was not sure about the wire since one has 1 wire connection and the other has 2.
I will also check into that. Also, I do need a 45 degree pipe to finish the rest of the intercooler piping.
Yeah, there are many lines that are not connected to anything where I could not figure out where they connect to.
Thanks. What do you suggest to be good in order to cap lines off? Sticking a bolt does not seem like a smart idea. hahaha.
I have not checked the compression and I hope it is the R32. I have had the motor for a while and do not remember the exact specs on it.
Thanks for the help!
Old 11-20-2008, 12:15 AM   #297
DirtyOldMan
DirtyOldMan's Avatar
Location: NORCAL - SAC NOT Bayarea NOT So Cal NOT Anywhere Else! JUST SACRAMENTO
DirtyOldMan is an unknown quantity at this point
Send a message via AIM to DirtyOldMan
whats the cross ref for rb20 clutch? is it z32 300zx?
DirtyOldMan is offline   Reply With Quote
Old 01-01-2009, 11:26 PM   #298
skylinegtr20
skylinegtr20 is an unknown quantity at this point
What exactly do you need? I have Nissan Fast, just let me know the product and I can get you the part numbers...
300zx N/A clutch will work in all RB transmissions.
Post a picture of what you need to connect and I can help you out.
Is it right by your Clutch master cylinder or is it farther forward?
skylinegtr20 is offline   Reply With Quote
Old 01-02-2009, 12:47 AM   #299
racer98
racer98's Avatar
Originally Posted by skylinegtr20 View Post
what exactly do you need? I have nissan fast, just let me know the product and i can get you the part numbers...
Post a picture of what you need to connect and i can help you out.
Is it right by your clutch master cylinder or is it farther forward?
08-29-2008, 08:40 am
300zx n/a clutch will work in all rb transmissions.
u shure about that ?
Old 01-02-2009, 04:34 AM   #300
skylinegtr20
R32 and R33 yes as they are both push type. R34 6spd Getrag is the only transmission it will not work in due to it been a pull type.
Learned this the hard way years ago when I got my first R32. Purchased a Nismo Coppermix from a reputable seller so I thought, turned out it was from a R34. Didn't get my money back and now have a gigantic doorstop.
