#31 | |
And just FYI, someone above posted that the RWD SR20DETs had 8.3:1 CR. That's false. It's 8.5:1, not 8.3:1. If you don't believe me, ask Enthalpy and do a search on Fresh Alloy. They will laugh at you if you said 8.3:1. Also, I am not sure if hydralic self adjusting lifters is the same as "mechanical shim in bucket type lifters", but I have a feeling that they're not the same, and the RWD SRs indeed have hydralic self adjusting lifters. Not all RWD SRs have the VVT on the intake cam. Only the S14 and S15 motors came with them. S13 redtop or blacktop motors were both static cams that has 1 set lift and 1 set duration configuration. Nothing adjusts them other than aftermarket adjustable cam sprockets. |
#32 | |
![]() Join Date: Mar 2003
#35 |
![]() Join Date: Mar 2004
Trader Rating: (-1)
![]() Feedback Score: -1 reviews
Its in. Its official. After rocking the shiat outta it trying to get the mounts in, it finnally popped in. Its a grand sight indeed. Tommorrow I go about attaching all the miscellanous stuff, and just maybe.... starting it up! pics tommorrow morning for you guys.
Its an S13 motor, destined to be bolt on powered with ITB's
![]() Current Project: Operation: N/A SR: 93 Silvia Q SR20DE Engine with go fast goodies. ![]() "Common problems 240sx's suffer from are curbs, trees, ditches, and other immovable objects."thx247 "on the tounge... there is no guardrails."- citizen |
#37 |
lol i didnt notice that you were gonna go sr20de i always thought it was a typo...lol anyways..will the 89 maxima clutch w/ 90 throw out bearing fit a sr20det?
-thanks? |
#38 |
Trader Rating: (-1)
89 maxima clutch and pressure plate work, you must use a 90 throw out bearing from a 240.
O Kazuo, its easier because of the wiring, its literally plug and play. That and you dont have to cut out part of your fender for the SMIC. Heres some pics, hopefully by the end of today it will look almost like an engine. ![]() ![]()
#41 |
Trader Rating: (-1)
autech? no clue, must be thinking of someone else.
OH BOY the wiring. This is gonna be fun. I'm going to try to use the KA harness. Wish me luck guys Today, I got a few things done. The heater hoses are all set up nice nice, custom routed. Worked out pretty well! The power steering is on, after I swapped pullies with my KA... different amount of ribs on the belts. AC is mounted and ready to go, and I test fit the SR20DE harness. Talk about a lot of plugs that I have no idea what they go to. In comparision to the KA harness, near the MAF sensor wire I have 3 big plugs that I have no idea about.
#42 | |
#43 |
Trader Rating: (-1)
well...ya!
After readin more in depth it appears a lot of the plugs just arent simply used. Still though, Its not as simple as first thought.
#44 | |
Props to u, that's a nice project.
Nissan 240SX LE 1992 SR20DET Redtop |
#45 |
Trader Rating: (-1)
wiring Day 2. In the process of pulling the stock KA harness out through the firewall, and lengthing the SR20DE harness wires. More to come
#46 | |
#47 |
Trader Rating: (-1)
an SR20DE with DET pistons and rods, oil squirters, is essentially the same motor, minus a different valve train design. It can handle the same boost at that point.
#48 |
Trader Rating: (-1)
UP FREAKIN DATE. Looking back on this swap, let me say this. At first I was intimidated with the wiring. I have thus realized, its pretty easy to get it to work. What you need to do guys to get a running SR20DE the easiest way.
- Use KA harness. This eliminates having to redo the 3 plugs by the battery - Rewire Idle air control valve and FICD into one plug. Tommorrow I'll try to write up some more info for you guys and toss up some pics. So today I cleaned up some of the wiring, My harness was all unpeeled, so I taped it back up. *pics tommorrow* I purchased a heater hose from a neon 2.0L to use as the top radiator hose, since im using the KA radiator. Trimmed to fit, worked well. *pics tommorrow* Interesting sidenote. You can use a stock KA24DE radiator hose on the bottom radiator fitting, elimanating the need for crazy custom bent ones. I then connected the vacuum line to master cylinder with a 3/8 fitting, since mine was cut on the SR. I used the stock KA24DE ignition coil, in the OEM location, with my SR20DE coil plug. Since I used the KA harness, plug and play. I checked all the grounds and dodads, filled up the radiator, filled up the tranny, and installed the SR20DE ecu. NOTHING. Car will not start by just plugging it into the harness. Clearly a pin or 2 is off, I will need to fix the ECU pinouts! DAMNIT! ( Anyone have a RWD SR20DE ecu pinout???) I than attached the KA ecu. Cranked over! ( My ignition was disconnected, valve cover off, and I had poured oil on the cams ) I cranked it over for about 20 seconds, than oil came pouring out the tubes onto the cams, and I was a happy camper. I then put the valve cover back on, and looked at my good friend Rob. The moment of truth. I turned the key, and it started up on the FIRST CRANK!!! So there it was, on the KA ecu, KA harness slightly modified, idling pretty happily after sitting for a year in my garage at a cool calm 850 rpm. The sound of the stock secondary exhaust piping EGR outlet open was quite... racy. I let it idle for a bit, than gave it a little rev. OMG it rocks socks. Another sidenote, I need to change the coolant sensor, according to my friend it reads in celsius, not farhenhiet, or vice versa so i gotta swap it. Anyhow more info and pics later. GO ME!!!
#49 | |
![]() Join Date: Oct 2003
temp sensors dont read celcius or farenheit, they just change resistance at different temperatures
#51 |
how much was that motor, is that a waste of time to replace the stock ka with that motor? i mean i know its all personal prefrence, but as far as power is concerned couldnt you have spent a lil more for a sr20deT or a turbo setup for the ka? nice swap btw.. what are the numbers on the stock sr20de? Have u started/driven it yet?
#52 |
![]() Join Date: Nov 2003
Beat me to the draw,mcsepulchral....IIRC they have less output (stock) then a KA (stock) ? Hmm. Its a hot swap just for rareness,and etc alone.
Update with pics! |
#53 |
Trader Rating: (-1)
![]() Hotness
#55 |
Trader Rating: (-1)
it needs new fuel injector o-rings, im flooding it out after i turn it off!!! o well. almost done!
#56 |
![]() Join Date: Apr 2003
Good job on your swap, but what was the point. You just spent T&M installing a NA sr. Now you have an engine that is inferior to the DET, and you are going to probably be spending another $2500 on a turbo kit and more T&M for an engine that is still more inferior to that of the KA when bolted down to a turbo.
But if you are happy whatever floats your boat.
#59 | |
I refuse to tip toe through life, only to arrive safely at death. |
