Old 05-06-2005, 02:57 PM   #1
90sr
90sr is an unknown quantity at this point
boost controller ?
hey fellas got a little question, i just bought a manual boost controller, like 8 bucks on ebay, and shneider is the brand i believe, and i ran the hose from the wastegate to it and then a hose to the intake manifold, is this correct, it says run it to wastegate and to a boost source, im guessing its a vacuum source, so i did that and then it says turn 1/4 turns to increase boost so i did that like 2 or 3 times and boost didnt increase still at stock boost... can some1 pick me up here. thanks
chris
chris's sr
90sr is offline   Reply With Quote
Old 05-06-2005, 04:20 PM   #2
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Do you remember where the wastegate was connected to before? Thats where the other end goes. Its a nipple on the stock side mount (if you still have one) intercooler cold pipe.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 05-06-2005, 04:24 PM   #3
90sr
well i removed the stock bov, and that nipple was part of the hole little unit there and welded up the hole, and i have and hks aftermarket bov, and the wastegate was ran to the intake manifold nipple underneath the throttle body, so i duno should i runt he other hose to the bov?
chris
chris's sr
Old 05-06-2005, 04:37 PM   #4
sr240mike
No, the wastegate nipple is on the hard plastic cold pipe.
Old 05-06-2005, 04:42 PM   #5
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
refer to pg 44 of 61. The picture diagram will help you out. Also, no don't hook up the other hose to the bov...
Boost Controller
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 05-06-2005, 04:58 PM   #6
90sr
aright that definately helps alot ill go try it and see wat happens
chris
chris's sr
