Old 08-11-2021, 12:49 PM   #23671
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
Originally Posted by BryanSayWhat View Post
https://www.kmakaero.com.au/r32-mspe...-skirts-2-door
They have a bunch of other R32 aero rep bits as well.
Out of Australia. I messaged them with no response in the past. Their shipping calculator won't pull US estimates.
Corbic is offline   Reply With Quote
Old 08-13-2021, 08:11 PM   #23672
NismoSilvia6666
NismoSilvia6666 is an unknown quantity at this point
I just got back on Zilvia after 7 years and I forgot How do I get ahold of a moderator to unlock my account so I can post new threads?
NismoSilvia6666 is offline   Reply With Quote
Old 08-20-2021, 01:58 PM   #23673
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
What is this coilover part called?
Lifted the car up and a bunch of tiny ball bearings fell to the floor. It's the part on top of the spring, and looks like the part that actually spins when you turn the wheel. Looked up top hat or coilover mounts and only found the top part that bolt to the car. My google-fu has failed me.
Mainly seeing if I can just buy this part.
Daughter bought an S13 with a bunch of suspension mods, but the body is rusted out. Trying to see what's salvageable off this car to transfer over to a clean stock S13 we picked up.
Here's a generic picture I found online and I circled the part where the bearings fell out of.
Not sure what brand coilovers are on the car, but based on the CX racing turbo kit, I'm going to assume they are budget friendly.
Old 08-21-2021, 01:53 AM   #23674
Papajin
Papajin is an unknown quantity at this point
My guess is you're talking about radial bearing mounts like this or this. I assume the pic wasn't the actual coilovers so it's hard to say for sure, but it's possible you could replace the bearing alone if that's what broke. My only other guess would be thrust bearings, but you don't normally see them on top, I don't think. Not an expert here though so YMMV.
Papajin is offline   Reply With Quote
Old 08-21-2021, 08:10 AM   #23675
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Edit: coilovers cleaned up pretty nice after I took everything apart. After searching a part number on the strut bearing itself, it turns out this is simply a GM strut bearing used on the G8/SS, etc. Hooray for easy to find OEM parts.
Thanks, went out and took a pic of the actual part. It's the blue part with a white plastic cover on top.
Also found a sticker and see that these are Megan. Probably better to bin these things.
Old 08-24-2021, 12:29 PM   #23676
mothon
mothon's Avatar
mothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond repute
Originally Posted by Reece View Post
Blacktop SR20
-new MAF
-new O2
-new TPS
-timing is correct
-new walbro 255
-new FPR
-new wiring specialties pro harness
Turns on and dies a few seconds later, won't rev
Help
Any codes? Does the same thing happen with MAF unplugged? stock ecu or rom tune?
instagram: madness_garages14
mothon is offline   Reply With Quote
Old 08-30-2021, 09:04 AM   #23677
Corbic
Corbic's Avatar
What rear axles work on an R32?
Old 09-05-2021, 02:00 PM   #23678
ItsAryx
ItsAryx is an unknown quantity at this point
s13 1991 240sx gauge cluster, power seatbelts, ac controls, and blinkers
So my gauge cluster, power seatbelts, ac controls, and blinkers all stopped working at the same time. When the issue first started it was very random for when this would happen. They would all be working and then all of a sudden they go out. It's at the point now where they havent worked in a few weeks. I'm thinking there's a bad ground somewhere but have no idea which would control all of those electronics. Any ideas?
ItsAryx is offline   Reply With Quote
Old 09-05-2021, 07:42 PM   #23679
burnsauto
burnsauto's Avatar
Could be an issue at the fuse box, or one of the main grounds under the dash. If I remember correctly, there are some major grounds for the chassis harness under the drivers side dashboard, near the kick panel.
Old 09-13-2021, 04:48 PM   #23680
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
time to grab the FSM and a power probe and go to town.
Old 09-25-2021, 07:26 PM   #23681
imbored205
imbored205 is an unknown quantity at this point
Any suggestions on how get a fan clutch that isn't so stiff?
I bought a used OEM one, Asin, and a new OEM one and they have all been stiff.
Water temps are typically around 160-180 and the fan is always roaring at 2k RPM and above.
The fan does not spin by hand when cold, after startup, or after driving a while. It rotates maybe a quarter turn if I slap it by hand.
Any solution besides buying 100 fan clutches and hoping one of them is good?
imbored205 is offline   Reply With Quote
Old 09-28-2021, 07:50 AM   #23682
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
Sound deadening question:
When adding (phat mat, kill mat, etc) new sound deadening, do you put it on top of the oem material or take it out and put it on the metal?
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline   Reply With Quote
Old 09-28-2021, 10:34 AM   #23683
LoSt180
LoSt180's Avatar
Trader Rating: (18)
If it's the sticky stuff, then replace the oem material. If it's just carpet matting, then lay that right over the oem stuff.
Old 09-28-2021, 11:13 AM   #23684
hellion240sx
Yeah I think I'm going to go with kill mat. So dry ice and a hammer and screw driver iirc.
Old 09-28-2021, 02:10 PM   #23685
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Now that I think of it, it was winter when I did mine and it came up pretty easily with a hammer and scraper. Dry ice will probably come in handy if it's all hot and sticky.
Old 09-28-2021, 02:40 PM   #23686
hellion240sx
That looks awesome! What did you use? What's the stuff on top of the tranny tunnel?
Old 09-28-2021, 02:56 PM   #23687
LoSt180
LoSt180's Avatar
Trader Rating: (18)
I used Noico 80mil sound deadening, looks pretty similar to the Killmat you mentioned. Got it off Amazon. That other stuff is DEI under carpet lite insulation that I laid new carpet over. Basically replicated what was under the stock carpet, but with newer/better material.
Over the shifter I used an insulating cone off a G35. Kinda went a little overboard.
Old 10-08-2021, 02:10 PM   #23688
hellion240sx
Is there a reason NOT to put it over the factory sound deadening? Is it just inferior and not worth keeping?
Old 10-08-2021, 05:00 PM   #23689
burnsauto
burnsauto's Avatar
The factory applies the sound deadening first, then paints over it, so you're bond to the car is only as good as that old paint is to the original stuff, which isn't that great. Besides, it looks janky. Don't be the guy with the janky s13, I'm tired of seeing that.
Old 10-25-2021, 04:22 PM   #23690
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
Hey guys, des anybody knows if automatic transmission flexplate on ka24de is the same as on sr20det?
cured13 is offline   Reply With Quote
Old 10-31-2021, 06:55 PM   #23691
Knownworldwide
Knownworldwide is an unknown quantity at this point
I wouldn’t think so. Possibly the flex plate off of a auto SR20 stateside could work. Like from a B14 Sentra or P11 G20.
Knownworldwide is offline   Reply With Quote
Old 11-02-2021, 09:39 PM   #23692
hookhead21
hookhead21's Avatar
hookhead21 is an unknown quantity at this point
S14 ganadors
Looking to buy some s14 ganadors. If anyone if selling some let me know thanks.
hookhead21 is offline   Reply With Quote
Old 03-23-2022, 05:14 PM   #23693
Pain
Pain is an unknown quantity at this point
Anyone know what grille came on a 95 slicktop zenki se?
Pain is offline   Reply With Quote
Old 03-23-2022, 07:05 PM   #23694
AKADriver
AKADriver's Avatar
This one
https://i.ebayimg.com/images/g/JkcAA...ale/s-l300.jpg
Old 03-23-2022, 07:26 PM   #23695
Pain
Originally Posted by AKADriver View Post
Had a good feeling it was that one but just wanted to make sure before I started looking for one, thank you
Old 03-30-2022, 01:03 AM   #23696
Kylerkickass240
Kylerkickass240 is an unknown quantity at this point
What kind of anti-seize should I use on the threads of adjustable suspension arms? How much to use?
'92 vert, '10 accord coupe
Kylerkickass240 is offline   Reply With Quote
Old 03-30-2022, 11:13 AM   #23697
Thursday7
Thursday7's Avatar
Thursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfection
Regular silver permatex stuff. Apply more than too little but less than too much.
Thursday7 is offline   Reply With Quote
Old 03-30-2022, 11:39 AM   #23698
tuzzio
tuzzio's Avatar
You'll know when you put enough on, it'll be on fucking everything.
Old 04-03-2022, 10:01 AM   #23699
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
Is the AC setup (lines, compressor, etc) the same between Sohc and Dohc s13s?
I have an 89-90 chassis which I swapped to dohc but deleted the AC along the way and now that I am older would like to re-install the setup
ZenkiKid is offline   Reply With Quote
Old 04-03-2022, 12:47 PM   #23700
burnsauto
burnsauto's Avatar
compressors are different between s13 and s14 ka24de's
My question for someone with an S13 SR, can you measure the bov recirculation fitting on the stock intake tube? I want to recirc. my bov and greddy sells different sized fittings. My thinking is then I don't need to find a hose that changes size from one end to another.
