#23612 |
What's the proper mounting method for the S13 GTR grille?
Clips? screw and grommet? Tired of using zip ties for them
IG: de_guzzi // Build Thread |
#23613 |
#23615 |
Correct. This is hosted on a private server which is likely slowly dying. Site owner has not bee in contact for 2 years now. Essentially Zilvia has become one of those abandon sites that once the server pukes will be gone forever.
#23616 |
Anyone know what wire color on the radio harness is the amp turn on. According to the graph on the internet it's supposed to be light green but I can't find any light green wire.
![]() Sent from my ELE-L04 using Tapatalk |
#23617 |
Do SR20's have the same black plastic fuel rail spacer washers that KA rails have? I don't remember there being any when I disassembled everything but it wouldn't be the first corner cut by the previous owner of the engine.
#23619 |
![]() Join Date: Nov 2013
Is there a way to find out what production number is your 240sx? I read that the last 6digits on the vin is the production number but it doesnt seem right as they were around 2000 1998 s14. Just trying to find out if my 240sx was the last one on the production line lol
#23620 |
![]() Join Date: Oct 2012
Issue: 92 dual cam- speedometer needle doesn't work, fluctuates around sometimes, doesn't work at all sometimes. Also the odometer stopped working.
Question: Is this likely the speed sensor that if failing? Or the cluster itself? Any input appreciated, thank you.
'92 vert, '10 accord coupe |
#23621 |
Question: Is this likely the speed sensor that is failing? Or the cluster itself? Any input appreciated, thank you.
'92 vert, '10 accord coupe Last edited by Kylerkickass240; 05-02-2021 at 02:09 AM.. |
#23623 | |
![]() Join Date: Jun 2003
Trader Rating: (130)
https://www.edoperformance.com/produ...ssan-s14-240sx |
#23624 | |
![]() Join Date: Mar 2008
#23625 | |
Future Moderator
![]() Join Date: Jun 2007
Does anyone have the complete torque specs for S14 suspension? Im getting conflicting info via googling.
#23627 | ||
Future Moderator
tension rods rear upper control arms front lower control arms toe rods
#23628 | |
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
tension rods - 80-90ft/lbs rear upper control arms - 51-65ft/lbs(sub frame), 57-72ft/lbs(knuckle) front lower control arms - 80-94ft/lbs, ball joint - 71.5-87.8ft/lbs toe rods - 57-72ft/lbs(both sides) |
#23629 | ||
Future Moderator
Im shocked how low the tie rods are.
#23630 | |
EDIT: Just checked the FSM I have--the LG wire is for cars with ACTIVE SPEAKER
#23631 |
Does anyone know if the Yashio Factory Okachan V2 will work with a KA24DE ECU through the consult port? Or does it require an SR20 ECU? Anyone tested with KA24DE before?
#23633 |
Help with muffler
Hey, guys, I am going to get a cat delete for my r33 gts but a buddy of mine recommended to also get a turbo muffler to make the car sound better. But I am not sure what turbo muffler to start with. Any suggestions?
#23635 |
Without erring on the side of caution, how likely do yous think it would be for there to be a decrease in oil pressure when using an S14 gasket on an S13 (see: O-Ring) pickup tube for SR20? My oil pressure is a bit low and I wasn't aware of there being a difference, yet I really don't see how the S14 flat gasket would do a poor job of sealing the S13 flange.
Edit: I'd like to add, just to save face, that I'm not trying to skip a step. I'm replacing it with the correct parts before running the engine, just wanna know how much I can look forward to this improving my condition. Edit 2 Update: Replaced the pickup tube and gasket and my oil pressure is phenomenal now. All is good. Last edited by Thursday7; 06-01-2021 at 10:52 AM.. |
#23637 | ||
#23638 |
What kind of quality can I expect from VIS Racing Sports? I'm interested in their Type-X style bumper for the S13, I really like that it has the lip and bumper extensions molded in, and no front plate mount.
https://visracing.com/i-30504368-198...%7Cyear%3D1992 Would I need any different brackets or anything to mount that on a Chuki S13? Thanks! |
#23640 | |
Tags |
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
