Old 12-19-2020, 05:52 AM   #1
Sweds13
Sweds13 is an unknown quantity at this point
Quick help pls. Dropped Plastic bit in my intake.
Hi.
Was changing injectors on sr20. Little useless plastic bit of injector had come loose. Idiot me tried to fish it out but instead it fell in the intake. Price is about 5mm high 8mm diameter. Removed the fuel rail, as I should have done straight away. Can't see it, can't really fish it out. Don't know what to do. I'm thinking worst-case scenario if I say fuck it is that it gets stuck in the valve open and valve fucks the piston. Advice please.
Sweds13 is offline   Reply With Quote
Old 12-19-2020, 06:55 AM   #2
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
pintle cap?
take the intake/intercooler cold pipe off and try to use a shopvac to suck it out through the throttle body (make sure its open).
worst case scenario take the manifold off and shake it out.
If it fell into the cylinder you could remove the spark plug and try to extract it with the age old "gum on a stick" type trick.
If its in the cylinder but you can't see it, you could try agitating it by blowing some air in there with the compressor.
Another way would be to roll the engine over until an intake/exhaust valve is open and blow air through the spark plug hole at, idk, maybe 70 psi and probably blow it out. Maybe even vacuum the TB while blowing air into the spark plug hole.
zombiewolf513 is offline   Reply With Quote
Old 12-19-2020, 08:13 AM   #3
Sweds13
Yeah the pintle cap. That's great advice. Only problem is the car is not near a outlet. Since changing the injectors is eminir job only requireing like two tools I didn't bother driving it up to the garage... In hindsight I highly regret it. Walked probably a mile to and from the fucking car.
Old 12-19-2020, 09:39 AM   #4
zombiewolf513
eh, itll melt.
Old 12-20-2020, 02:31 AM   #5
Sweds13
Originally Posted by zombiewolf513 View Post
eh, itll melt.
How sure are you about that?
Old 12-20-2020, 09:08 AM   #6
zombiewolf513
Roughly 93.726% sure.
Old 12-21-2020, 10:18 AM   #7
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
dude I would NOT run the car with a chunk of plastic floating around.
Get tools, remove the intake manifold, find the chunk, remove it.
even if it DOES pass through the cylinder, do you want it bouncing around in your turbo?
I get that its only plastic, but still.
Old 12-21-2020, 12:39 PM   #8
TheRealSy90
TheRealSy90's Avatar
It's crazy how many times i've removed injectors from an sr and they were missing pintle caps, and the engine still ran fine.
Such a good signature.
Old 12-22-2020, 08:24 AM   #9
brndck
brndck's Avatar
yes, but if you knew about it, when it happened, would you just send it?
I'd like to think i'd exhaust all possibilities of removing it instead of just hoping it would be fine.
Old 12-26-2020, 03:14 PM   #10
Kingtal0n
Kingtal0n's Avatar
So THATS where they've been going!
And here I thought somebody was going around, removing them
Blind! So blind. It turns into a snack! Of course it does
Old 01-23-2021, 07:42 AM   #11
Sweds13
Update, just sent it. It's been running fine. No problem
Old 01-23-2021, 09:02 AM   #12
tuzzio
tuzzio's Avatar
Wouldn't have been my recommendation but, wholesome update. Keep us updated.
Old 01-31-2021, 03:28 PM   #13
Kingtal0n
Kingtal0n's Avatar
Im sure the pistons are fine with pintle shaped holes peppered and mashed throughout
injector, sr20
