Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 11-14-2018, 08:13 PM   #1261
gills
gills's Avatar
gills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the rough
RBF600 is amazing stuff and $$$$. People usually think I'm lying, but I run Pentosin super DOT4 that's available at any advance auto parts in my 9 hour endurance races and without brake ducting. I'm always bleeding and flushing so the fluid I use never has time to get much water absorption.
RBF is good if you plan on leaving it in for awhile without worries since it's wet boiling point is very high. Also if you have a heavy car.
IG: core4motorsports
www.core4motorsports.com
gills is offline   Reply With Quote
Old 11-15-2018, 05:35 AM   #1262
240sx_sr20det
240sx_sr20det's Avatar
240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection
I enjoyed Castrol SRF for a long time until moving to RBF600.
240sx_sr20det is offline   Reply With Quote
Old 11-20-2018, 06:10 AM   #1263
Dolph_KYAS13
Dolph_KYAS13's Avatar
Dolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond repute
Originally Posted by slider2828 View Post
COngrats and welcome! Those look like two beasts.... Two things i always do now to prevent big issues.
Upgrade brake fluid and lines. Fluid Motul RBF600 and steel lines for sure. Helps a lot.
Pads are expensive, but you can swap them in and out after events. I love cobalt pads really and lot of confidence and no fade.
Also check all your hoses. If anything is older than 5 years, change them. One pin hole leak = blown engine.... Trust me I know :'(
But so jealous other people can run R chassis' on the street. Stupid california...
Thanks for the welcome!
Before my last track day I flushed the system with the highest temp brake fluid I could find at my local Canadian Tire store which worked fine for how hard I was pushing the car. Ill pick up some Motul fluid over the winter.
My car suffered an engine loss due to a cracked coolant hose (under the intake manifold) back in 2011. Got the car back together after a long hiatus in 2016 and made sure I replaced EVERY line and hose (brake lines included). So in theory we should have a good solid platform to learn with.
But now its snowing so we wait....
-Jordie
-Jordie Lewis
'93 Skyline Type M
Dolph_KYAS13 is offline   Reply With Quote
Old 11-26-2018, 07:49 PM   #1264
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
wait until you try Endless RF650 #nevergoingback
Review Thread
bardabe is offline   Reply With Quote
Old 11-26-2018, 08:23 PM   #1265
240sx_sr20det
Ohhh, thanks for the tip!
Old 11-26-2018, 08:50 PM   #1266
slider2828
slider2828's Avatar
-Jordie
DUDE!!! I was just reading this and was thinking did I type that? I had the EXACT same thing happen. Pinhole lead in the pipes under the coolant hose, basically blew up the piston due to extreme heat....
I have a thread that converts all of those hoses to 4 layer silicone....
Here is my thread about it.
http://zilvia.net/f/showthread.php?t=353261
Turn and Burn!
Old 04-16-2019, 03:02 PM   #1267
gills
gills's Avatar
How bout a little bump with different color shoes from my last race at Watkins Glen:
Old 04-16-2019, 11:23 PM   #1268
Karlitos
Karlitos's Avatar
Karlitos is an unknown quantity at this point
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3
Karlitos is offline   Reply With Quote
Old 08-12-2019, 03:55 PM   #1269
loser101
loser101 is an unknown quantity at this point
Send a message via AIM to loser101
loser101 is offline   Reply With Quote
Old 08-13-2019, 07:02 AM   #1270
Dolph_KYAS13
Running from mustangs
-Jordie Lewis
'93 Skyline Type M
Old 08-13-2019, 08:50 AM   #1271
slider2828
slider2828's Avatar
Dang even mustangs invading Canada? I think those new GT350's are going to be the next 240... cheap, a lot of horsepower, looks great and IRS now.... Geez....
For 40k its faster than a 240 at a 40k build...
What do you guys think?
Turn and Burn!
Old 08-13-2019, 09:50 AM   #1272
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Probably not the 350's, but the 5.0's for sure.
spooled240 is offline   Reply With Quote
Old 08-13-2019, 09:59 AM   #1273
ka-titties
ka-titties is an unknown quantity at this point
^this
you can get rear-end-damage 5.0's on copart for ~$10-15k. ready to missile.
ka-titties is offline   Reply With Quote
Old 08-13-2019, 11:16 AM   #1274
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
It wouldn't be too hard to build a 240 that put a hurt on GT350s for $40k. They're at about 7.07lbs/hp, so a 2550lb 240SX would need to make 360 crank horsepower to have the same straight-line speed potential.
The difference is that the Mustang is a $40k turn-key and the 240 would be hundreds of hours of wrench work. I think the 240 would be more fun.
KA24DESOneThree is offline   Reply With Quote
Old 08-13-2019, 01:07 PM   #1275
Dolph_KYAS13
Spoiler alert. The track day didnt end well for the mustang. He ended out going off at the end of the main straight and flipping a couple of times. Im not too sure what caused it but at least he walked away.
Hard to argue with performance per dollar with mustangs though.
-Jordie Lewis
'93 Skyline Type M
Old 08-13-2019, 01:58 PM   #1276
gills
gills's Avatar
Yea, they also have a ton of potential and factory support right now with the GT4 program (Multimatic preps them for Ford). But, they are still heavy. Heavy cars are $$$ to keep running on track.
https://performanceparts.ford.com/gt4/
Bang for buck is definitely the rear axle coyote engine car. I race against two of them and they are fast, loud, and irritating
Old 08-13-2019, 02:14 PM   #1277
ka-titties
hahahahahahaha
Old 12-29-2020, 09:42 AM   #1278
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Well, subscribing to this too. Another drift guy tired of smashing cars up, and expensive ass track day weekends trying to hang with 800hp pro cars...ugh...lol
Did a couple PDX days last year, spent 2020 doing 2020 stuff...not dying...and I'm going through the car this winter to prep for heavier track sessions.
So far in the past few months I've added a 25row oil cooler with thermo plate, 15 row power steering cooler and completely rebuilt PS system. New 200amp DC Power alternator and completely rebuilt power supply system. Then did some radiator/fmic ducting, and a full length frame mounted front splitter. Just finished last week, and added a TrackSpec motorsports hood vent over the weekend.
Now I'm going through the rear end, converting to Kouki JDM rear, and building a rear diffuser, mostly for aesthetic purposes honestly. Then next I'm moving to a real ECU (Link G4+ Storm) with all the safety sensors, and some bigger injectors. Hoping that gives me the margin I need to keep it healthy for next few years.
Goal is the make the car a trackable street car, with only a pad change needed to handle track day sessions. Currently running RBF660 fluid on R33 brakes F&R with Porterfield R4S pads, which i've found to not hold up too well for heavy track sessions. So I'm entertaining some ideas, trying to figure out if need to invest in a 2pc Wilwood setup or just run what I have and get a proper track pad for track days...
Pic from 2019
Coolers, Ducting, and Splitter
Vent and finished front
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 12-29-2020, 12:36 PM   #1279
gills
gills's Avatar
Beautiful! What's your plan for the differential? If you have yours set up for drifting still, take it out and disengage some of the clutch discs to make it less aggressive for road race duty.
As for the brakes, PM me as I have the best bang for buck solution for anyone who seriously tracks their cars.
Old 12-29-2020, 01:14 PM   #1280
BlackZenkiS14
Hey thanks man!! So the diff is a Cusco 1way actually with a 4.08 rear drive. I'm considering going to a 3.6 final drive to play a little nicer with my R154 trans, we'll see.
And on the brakes, trust me lol I spent the morning poking around on your website. I was gonna buy Erin Sanford's Def Sport Wilwood setup, but drug my feet and missed it, and he pointed me in your direction. That looks like the way to go, I just didnt plan for 1400 for a brake kit this off season, I'll have to keep it on my radar later in the year. My Link ECU+Sensors is eating up most of my funds for the winter build.
-Kyle
Old 12-29-2020, 07:32 PM   #1281
Dolph_KYAS13
I think thats a lot of people here. Well me anyways.
-Jordie Lewis
'93 Skyline Type M
Old 01-02-2021, 08:12 AM   #1282
BlackZenkiS14
Alright, so here's my next question about brakes. Does anyone make a caliper upgrade kit for Z32 rears? Something that utilizes a stock Z32 rotor, so I can maintain my Ebrake, but that uses a stronger caliper with a more common/effective pad size?
I know C4 makes their insanely awesome rear kit, but I'm gonna be strapped to get their front kit setup this season as is, and wont have an additional 1500 for rear brakes at this point I dont think.
So I'm looking for a caliper upgrade option.
-Kyle
Old 01-03-2021, 01:00 PM   #1283
BryanSayWhat
BryanSayWhat's Avatar
BryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud ofBryanSayWhat has much to be proud of
There's a lot of write ups about using rear STI Brembos with rear Z32 rotors. From what I've read though it's mainly a "bling" thing if you already have Z32 rear calibers. Meaning a larger diameter rotor is what you really want for an upgrade.
This dude did a write up about the rear swap (about half way down the page):
https://grassrootsmotorsports.com/fo...e/53359/page5/
The STI caliper is marketed as a great option online on Zilvia and other stupid websites like superstreetonline, and importtuner.com because it simply bolts into the same place as the s14 caliper with no adapter brackets or anything of the sort. What they don't really cover all that well is that evidently you run into a rotor to caliper offset issue when using these. They conflict, saying you need a 3mm spacer, a five mm spacer, or no spacer at all. What I can tell you is this: Using a Sti caliper on an S14 five lug hub with a Z32 one piece rotor creates the problem you can see in the image below. You can see that the caliper in its mounted location is to far to the drivers side, so the pads won't be contacting the rotor at the same time if I left things as they are. In case you are wondering whether I have the rotor snugged up to the hub appropriately, I snugged it up with three open ended lugnuts just to be sure.
BryanSayWhat is offline   Reply With Quote
Old 01-04-2021, 08:06 AM   #1284
BlackZenkiS14
Awesome, thanks man. Was really hoping to find something that utilized a Wilwood caliper, for cheaper consumeables. As the Brembo probably wont offer any better options on pads compared to the Z32/R33 rear.
Looks like I'll be sticking with the R33 rear caliper for this season lol
-Kyle
Old 01-05-2021, 06:43 PM   #1285
spooled240
spooled240's Avatar
This is true. The STi caliper has smaller pistons so less clamping force than the z32 calipers and the alignment is not that great. All of that on an already small rear rotor and it is just a bling upgrade. I experimented with some HFM brackets I had laying around and some 350mm rear rotors for the 370z/G37S. Pad overhang is about 1mm just due to the fact that the calipers weren't designed for such a large rotor, but it still fits better than the z32 rotors I had. Brake bias with the evo 8 front brembos is much, much better. Ebrake still works also, as it's all 172mm.
Old 01-06-2021, 10:15 AM   #1286
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
@BlackZenkiS14. Is that an off the shelf front bumper? Looks like it has great support for the front splitter! How noticeable was the increase in front downforce with the splitter and new hood vent?
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 01-06-2021, 11:05 AM   #1287
BlackZenkiS14
So the bumper is just an OEM JDM Kouki front bumper with a Greddy lip.
The splitter was totally designed around the shape of the bumper actually, I built it specifically for it.
No idea on downforce yet, havent had it to the track yet, just finished it a couple weeks ago. But cooling improvements were huge for the vent+splitter+ducting.
-Kyle
Old 01-06-2021, 12:06 PM   #1288
slider2828
slider2828's Avatar
I believe the rear STI calipers are lighter than the rear Z32 from what I read? I don't need the ebrake so I went with a girodisc 2 piece setup with evo8 rear rotor. I just then need like 4 washers to slightly space out the caliper from the rotor.
Turn and Burn!
Old 01-06-2021, 03:07 PM   #1289
BlackZenkiS14
Seems like a lot of work for not much performance or benefit beyond a Z32/R33 setup.
Unfortunately I still rely on my drum e-brake for the occasional drift event and normal parking. So i'm probably stuck with R33 until I decide that I care ZERO about drifting. Even teh C4 setup wouldnt work well with e-brake rips
-Kyle
Old 01-06-2021, 03:43 PM   #1290
spooled240
spooled240's Avatar
If they are it's probably only a few ounces lol I'm sure your rotors are much lighter than mine, but I prefer to have cheap rotors that I can source virtually anywhere.
