Old 10-06-2020, 09:46 PM   #1
SidewayzAsFck
SidewayzAsFck can only hope to improve
Thumbs up Fall sale! 240sx, LS, and SR parts for sale!
Parts for sale (buyer pays shipping & PP; only shipping certain
<bold> LS parts </bold>
- WIring specialty ls1 - s14 BNIB harness (interface harness pretty and labeled for RHD chassis) + 411 PCM - $550
Lm7 truck intake - $85
Lm7 starter - 50
Rear sump LS oil pan - $175
T56 trans mount bushing x 2- 35 each
S13/s14 bmc heat shield - $60
<b>SR20det parts </bold>
Sr Comp clutch lightweight steel Flywheel (BNIB)- $270
Custom aluminum solid Sr/KA mounts -$125 (used for 800hp race car)
Used rps max Sr20det clutch setup - $195
ACT 6 puck sprung clutch disc (BNIB) ? $150
Koyo release throw out bearing (brand new & installed) - $50
Jgs fuel rail - $50
Coil pack harness - $50
Bings Coil pack cover w/ jdm black oil cap and bolts- $70
Peak performance Sr20det pro trans mount (slightly modded) -$35
4 sr20det coils - $100
Sr20det starter - 125
SR20DET oem alternator - $125
Sr20det ac compressor - 80
Sr ac bracket - 45
Sr PS setup (everything needed) - $150
Speed sensor - $50
4x stock s14 rims - $110
350z oem carbon fiber drive shaft (manual) - 250
350z - transmission mount - $25 (used OEm)
350z trans bracket - $75
https://ibb.co/vhMVQr6
https://ibb.co/85fPmMC
https://ibb.co/12T6WCf
https://ibb.co/RcC0cf8
https://ibb.co/DpcBLJP
https://ibb.co/tqYrtkP
https://ibb.co/ZW5n5Dp
https://ibb.co/r3wRbbF
https://ibb.co/56rpGTn
https://ibb.co/0G6zdtD
https://ibb.co/cQ9wsfv
https://ibb.co/Hz4KPrh
https://ibb.co/kDqNDmw
https://ibb.co/cN5RMNq
https://ibb.co/w6pZnp9
https://ibb.co/1zXCTbr
https://ibb.co/f9t0bnZ
https://ibb.co/TRt82VJ
https://ibb.co/6PHwm9C
https://ibb.co/P5Qf6VR
https://ibb.co/r0XbJhx
More picture and parts coming soon!! Hmu
SidewayzAsFck is offline   Reply With Quote
Old 10-06-2020, 11:08 PM   #2
Big_MO
Big_MO is making a name for him/her selfBig_MO is making a name for him/her self
What year is the speed sensor from?
Big_MO is offline   Reply With Quote
Old 10-07-2020, 09:26 AM   #3
SidewayzAsFck
93 SR20det i believe
Old 10-07-2020, 10:23 AM   #4
itsmrgreen
itsmrgreen is an unknown quantity at this point
The oil pan fits in a s14? And the wire harness does it still have all the labels and will it work with a lq4?
itsmrgreen is offline   Reply With Quote
Old 10-07-2020, 10:23 AM   #5
itsmrgreen
Never mind on the harness just noticed RHD��
Old 10-07-2020, 09:08 PM   #6
SidewayzAsFck
It?s not for RHD, it was going to be extended for a RHD project but switched routes. It?s a brand new harness other than the interface harness being cut & labeled to be extended. It?s for a truck motor with LS1 acc, t56 trans, and MAP. The harness alone is $700 from WS. The interface harness is also interchangeable from s13/14 and usuales the same chassis harness connector main plug I believe
Old 10-08-2020, 04:25 AM   #7
itsmrgreen
How about the oil pan? Does it fit a s14?
Old 10-08-2020, 02:05 PM   #8
LLTSbs
LLTSbs is an unknown quantity at this point
PM sent for wheels
LLTSbs is offline   Reply With Quote
Old 10-10-2020, 07:26 AM   #9
SidewayzAsFck
Pan is rear sump, for our swap you need a front sump i think. It fits the engine but idk about clearance for s chassis
Old 10-12-2020, 06:10 AM   #10
Thursday7
Thursday7's Avatar
Thursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfection
Pics of the RPS clutch? I'm only seeing an ACT disc and a SPEC disc & pressure plate.
Thursday7 is offline   Reply With Quote
Old 10-18-2020, 07:47 PM   #11
Thursday7
Thursday7's Avatar
Sent you a PM regarding the clutch(es)
Old 10-28-2020, 08:13 AM   #12
Thursday7
Thursday7's Avatar
Dood why post this stuff then disappear? Multiple PM's sent.
240 240sx s13 sr20, 350z, ls swap, wiring harness, wiring specialties
