#542 | |
![]() Join Date: Nov 2005
#544 |
#546 |
Well I finished with the gold tape on the exhaust side. Started with DEI but bought some non-branded stuff on Amazon, hopefully it holds up. Seems quite similar.
![]() Haven't gotten my THL crossmember, so I decided to just put it back together with the GKteck rack forward bushings for now. I don't want to wait to put the engine in. If it comes in the meantime well... That's life. ![]() Fitment is on point, obviously need to mount the fenders and fine tune, and the front needs to come down two fingers. ![]() I also need to get the inner tie rods in so I can see if this is realistic. ![]() And what I'm going to have to do with the lock stops to keep the wheel off the LCA ![]() ![]()
#548 | |
#549 |
These cars already have shit all for insulation, so yeah. Shell out the bucks. Fatigue and heat related failures due to turbo heat is a real issue on any turbo track cars.
A similar situation saw a weekend go up in smoke at VIR a few months ago. Got like 10 laps total for the entire 2 day weekend because of inadequate heat management..... Yeah, I have learned my lesson |
#550 |
Looking good!
I had to switch over to the GKtech FLCA's because i had that same issue with the wheel contacting the lca.
#551 | ||
![]() Quote:
In other news I'm picking up the block and head today!
#552 |
Got the engine back from the machine shop last week. A couple of minor things up with the block, but nothing that should really affect performance at the power levels I'm looking to make. I need to take some pictures when I get to work on it today. Line hone has a nice scrape in it though, luckily it's a low spot and shouldn't affect bearing clearances when it's assembled.
![]() Also discovered that a few of my head and main studs were stretched, probably because the previous engine builder had zero idea what he was doing. The headstuds were the old 8470 VW kit. While some stretch is okay on an ARP stud, I've decided to replace them with Mazworx studs due to the superior design and ARP2000 material. Even after the hot tank I had to rifle brush and blow out the main and head stud holes to get the ARP moly lube out of them :rollseyes: Ordered a cleaning tap for the head stud/main stud holes and some other odds and ends, but I'll be chasing every hole in the block. This thing will be put together correctly! Crossmember from THL supposedly shipped out today. I guess it's going to be four or more weeks until the fender braces are done. Still waiting on the turbo as well for some reason. This project has definitely stretched well beyond the original scope and timeline. I need to go drive! I've been trying to get this Evo X wiring project done so I can concentrate on my car more, here's some shots. ![]() ![]() Lots of tidying up to do in here. Don't ask me why he has the fuel tank in the passenger seat, IDK. ![]()
#553 |
I guess it's harder to see in these pics than I thought, but here's my attempt at capturing the stretched studs and thread damage on camera. Anyone interested in a "how to assemble an SR20" write-up or video?
![]() ![]() ![]() Looks like the Mazworx studs will be here on Friday. Have a few other things showing up this week too ![]()
#554 |
![]() Join Date: Mar 2009
Wouldn't you want to use new studs when doing the torque plate and when assembling the engine? I'm on the fence myself currently over doing a headgasket and arp head studs on my sr that i'm prepping. I don't want to worry about pulling the block threads out lol. The gasket is fine but I suspect there's an oil leak at the front cover
#555 | |
I've never seen someone pull the threads out of a block unless they installed things wrong. There is definitely a bunch of junk in the bottom of the head stud holes I need to clean out (I'll try and get a pic). I have a tap coming to make sure the threads are nice and clean as well. The devil is in the details.
#556 |
I could have swore the ARP instructions said to put lube on the block-end of the threads also. Its been years since I last installed ARP head studs for someone. Albeit there were no issues it all went fine.
#557 |
![]() Join Date: May 2019
how many stretched? And was that pics of the headstuds, cause i know on my mains, beleve it was 2 or 3 were shorted, to clear the rwd oil pan...glad i checked instructions and saw that..
#558 | ||
https://tech.arp-bolts.com/instructions/102-4701.pdf Quote:
Also, if you put main studs in your block, you need to align hone your crank main bore. Mine were .002" out vertically.
#559 | |
Was just checking... Correct had mine lined honed with arp studs. Motors almost back together, turns over perfectly... super excited |
#560 |
So i'm just trying to educate myself here. If you install ARP fasteners, the "correct way" is to install them using a stretch gauge, right? So they are supposed to stretch a specific amount. If you do that and then align hone it to set the mains, since the studs already stretched aren't those studs then no good to use for assembling the engine? And you'd have to use another set of new studs and stretch-gauge them again.
#561 | |
#562 |
These came in yesterday:
#563 |
They're a really great arm. I just haven't figured out how I want mine adjusted. And having to rearrange the shims on either side of the heim to make significant castor adjutsment is kind of a pain.
#564 |
Yeah my good friend Joe had them on his car. It's definitely a pain, but I'm kind of a "set it and forget it" kind of guy with things like this. I'll probably shoot for 5-6* of caster and be done with it. Looks like my crossmember should be here in a week or so, so that'll be cool to setup.
#566 |
Got the new studs in on Friday and measured bearing clearances on Saturday. I got King racing bearings with .001" extra clearance, which turns out was not necessary on the mains. They were at .003" which is a bit big for my liking. So I'll be getting some normal bearings which will bring them down to .002" which is pretty golden. The rods are at .0022-.0025" which is right where I want them. This thing will always have 5w50 in it, so that extra cushion should provide some margin of safety.
One thing I did, which I would not recommend, is running a tap down through the headstud holes. I couldn't find a thread cleaner long enough anywhere, and after doing some reading, it seemed like it wasn't a big deal to run a tap down them. Maybe I should have used some tapping lubricant or something, but now I feel like I should have just rifle-brushed them out. Anyway, the result is that the studs have a very small amount of wobble when threaded all the way in now, which I don't like, but I'm just going to assemble and send it. The mains weren't an issue since the thread cleaner I had was long enough. ![]() ![]() ![]() And just some of the little detail work I've done radiusing or chamfering the oil drains and such. ![]() ![]() Also took the dremel to the rough casting area at the water pump inlet. ![]()
#570 |
i ran 85ft lbs..didnt know with the wider evo washers, but seemd to of worked.... been slackn off motor should be in the car by this weekend, running shortly after if i can figure out the power fc initial setup
