#1051 |
I'm pretty happy with that torque level given the motor is stock internally. We had plenty of room to play but this feels and looks safe based on logs. I'm traveling but i'll upload the graph when I get back home next week.
Tuned At Atlantic Motorsports in Gaithersburg MD. |
#1052 |
![]() Join Date: Sep 2005
You should be happy, you paid for it!
My comment was on why so many people were fondling the satchel of someone posting numbers with the lack of proof. So I didn't miss that graph?! I still believe in the old zilvia, where if you mumbled lefty loosey right tighty, you got ethered!! [emoji41] Sent from my SM-N910T using Tapatalk
#1053 |
Bump for update. Any KA news, guys?
"Simplicity is the key to brilliance." - Bruce Lee |
#1054 |
Comp Turbo T25/T28 upgrade
Hey guys, we have a pretty solid option when it comes to this turbo. There seems to be a great deal of info and customer participation as far as testing etc.
This turbo charger is available in sizing to cross reference 2860/2871/3071/3076 in the T25/T28 configuration. If and when someone is willing to give our alternative a shot I would love to work a deal with you to put it through the rounds and receive feedback. ![]() Thanks guys. -Daniel |
#1055 |
![]() Join Date: Dec 2013
scratch all that just ordered gtx2867 .64 and looking for a oil coolant line kit not finding much. What line kit are you guys using and what size restrictor? .04?
#1056 | |
You do not need bigger cams for a measly 350hp. Nor do you need a twin scroll or a 3071. A 16g turbo in a T2 bolt on housing is all you need for that.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
#1061 |
I didn't want 82 ar I got a .64 ar i'm surprised I didn't see it because I was searching not sure how old your post was but I went back 4 5 pages but anyway I need to source some oil and coolant lines
#1062 | |
![]() Join Date: Jun 2010
#1065 |
Yeah, that's it. I had the DIF lines, and bought their small restrictor to use on my Garrett BB. Must be ATP Turbo that sells the .035" one I was thinking of. Same idea. The orifice on both are extremely close in diameter and will produce nearly the same oil pressure at the turbo.
#1066 |
^ The "premium" version of those DIF lines just showed up last week for my build. Premium for the silicone heat shielding and billet steel fittings I guess.. They are v nice for sure.
On topic, they are plumbed to a gtx2867r, Tial 0.64 vband housing future fab manifold + Turbosmart 45 wg manley h-beams and cp pistons BC springs and retainers ECU Masters black edition stand-alone plus all the other expected stuff, 255 pump, straight piped and greddy mid mount i/c I'm coming from an s15 turbo + z maf + nistune setup, so the bolt-ons were already there. Fully worked and reassembled, zero miles. ARP studs aftermarket gasket blah blah, otherwise typical s13 redtop. Not much headwork but I beefed the bottom end up, so my tuner is just going to throw a good amount of boost at it and I'm going to stand there and pucker up. 850 side feeds and AZ 91 octane will likely be the limiting factor. Taking bets on whp...! Hopefully hitting the dyno later this week It will also be interesting to compare this to the next stage which will be corn fuel, 1000 topfeeds, greddy intake manifold and cams. Something I look forward to but I'm ready to get back behind the wheel! |
#1067 | |
I don't see many people with nistune. That's what I just got only reason being my sr is euro spec so plug n play stand alone was not an option so went with nistune. |
#1069 | |
But your comment leads me to believe you feel that you more or less settled with Nistune, so you get it ![]() |
#1070 |
Hey there, I've had a GTX2867 .63 laying around for a while and Im getting close to installing it onto my car.
Engine is the typical built (S13) SR: CP Pistons Manley rods Tomei Poncams Ported heads 3 angle valve job Recently i've been trying to figure out if its worth going for an aftermarket intake manifold for this setup. Been emailing Mazworx, Otaku Garage, and a couple other manufacturers in Australia, but none really give me a straight answer or an honest recommendation. Would going for an aftermarket intake manifold be worthwhile for a turbo of this size? I was initially all right with the stock intake for streetability/ response goals, but now im worried that I wont be able to enjoy the top end as much. Car is gonna be my final build and I plan to enjoy it in the canyons and track days aside from driving it around town. |
#1071 |
![]() Join Date: Nov 2003
So I had a very similar setup, and ended up going with the Greddy intake manifold. I made 417whp on pump gas at like 22psi. Car was an absolute blast!
I have no idea how much difference the intake made, but I wanted to do it, for no other reason other than having a cleaner looking IC pipe routing lol ![]() ![]() ![]()
-Kyle ![]() |
#1072 | |
Damn it looks like it pulls!!
#1073 |
![]() Join Date: Oct 2013
I've been curious on that otaku garage intake manifold as well. There's little to no data on it available though on the internet.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille |
#1074 |
I emailed them and all they could say was that their manifold focuses on mid to top end "depending on the setup"
Another guy I know is running some sort of gtx28 frame ,stock engine, and an otaku garage manifold. The car made 370whp with a power FC. I wasnt at the dyno session so i didnt see a graph. It was a roller dyno tho, not a dynapack. Also, they never tuned the engine using a stock manifold. EDIT: Car made a max of 360whp. Doesnt have a picture of the graph though. Just the graph for 326whp. 326whp 265 torque (lbs or nm i dont know because the pic of the gfraph was cut off, but im betting it was ft/lbs hahaha) Last edited by Marphie21; 08-27-2020 at 11:44 AM.. |
#1075 |
Although dont SR20s seem to have max HP and torque figure very close to each other? Or maybe im confusing myself with graphs that read nm vs lbs/ft?
Could the descrepancy be due to the intake + smaller frame turbo? |
#1076 | |
![]() Join Date: Oct 2004
If you want to go with legit top end manifold, then you go plazmaman. If you want to focus on street and mild track or fun drift day, then go with xcessive engineering plenum with stock runners. https://www.xcessivemanufacturing.co...et-s13-wi.html
#1077 |
![]() Join Date: Jan 2010
![]() This goes to the dyno tomorrow. GTX2650 Gen2 10.5:1 comp HKS step 1 cams Some light head work Greddy intake Last time out it made 360 on 18 psi/100 octane with a 9:1 bottom end and we had plenty left to go. This time it'll be on e85 and I'm hoping to crack 450 at around 25 psi. We'll see
gt2871, gtx, gtx2867r |
