11-12-2019, 11:44 PM | #4141 | |
11-15-2019, 10:13 PM | #4142 |
G’day fellas, I’ve recently bought an s14 with possibly the worst wheels possible on it, so I’ve been looking into purchasing a set of Work T7R’s and have found a set with the specs
[F] 18x9.5 +22 [Deep Concave] [R] 18x9.5 +22 [Deep Concave] Are these likely to fit on a car with stock unrolled guards, with bc good coil overs ? If not, what sizes would? |
11-19-2019, 07:50 PM | #4144 | |
No. Fuck off, weeb.
The mark of a true sucka: 'RARE JDM' & 'OLD LOGO NISMO'
11-25-2019, 05:50 PM | #4145 |
Black Friday coming up and I need some new wheels. Will these work with just a fender roll? Every time I search 10.5 wide its about the front
S14 Fortune Autos F 18x9 +12 235/35/18 R 18x10.5 +12 245/40/18 |
11-26-2019, 09:23 AM | #4147 | |
You may be able to pull it off, but ride height will be a factor. |
12-23-2019, 11:17 AM | #4149 |
Question
Anyone rolling Ambit RT12's 17x9 +15?
Just curious if your having to run spacers for zx caliper clearance And how much they stick out of the fenders? Also im planning on running 235/45 all around -is that too wide in the front? Thanks |
01-29-2020, 02:40 PM | #4150 |
I need some help while looking for wheels. I have searched high and low and can't find a definitive answer.
What is the max size wheel/tire that will fit under a S14 Kouki without touching the fenders and without stretching the tire? Currently I have 17x8 with 225/45 but was looking at a square set of 17x9 +25s. Will 255/40 fit under the stock fenders without rolling or pulling? I am on coilovers but I am not looking to be flush. I want a little bit of arch gap and currently have about an inch. I am more interested in retaining as much sidewall as I can. More of an "OEM" look. |
02-19-2020, 12:41 AM | #4151 | ||
I have a stock body S13 hatch that I autox/grip. No drifting. I was looking at 17x8+35 (+10mm spacer = +25 effective offset) for the front and 17x9 +20 for the rear.
71, 72 Celicas; 85 AE88 hatch; 89 S13 hatch; 20 86TRD |
02-26-2020, 08:35 AM | #4152 |
91 Drift/Street Hatch Setup
I'm sure it's somewhere in here, but do y'all have any advice as to what I can run on my 91 hatch that's purpose will be a solid drift/street build? I'm going to be running 40mm double vented Origin front fenders and 50mm Origin rear fenders. I was contemplating maybe an 18x9.5 +11 in the front and 18x10.5 +6 in the rear on Work Equips. Does this sound functional while having some good form? Or am I way off the mark? Please let me know.
02-26-2020, 09:28 AM | #4153 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
a good 17x9 and 17x10 wheel set will work fine and allow you plenty of fun on both street and track. |
02-26-2020, 11:47 AM | #4154 | |
03-12-2020, 02:03 PM | #4155 |
For some reason I can't post a long text so here is the short version. I live in Europe and have a Euro S13 hatch.
I want to run Japan Racing JR-3s in 17x9ET20 with 255/40s would this clear coilovers (heard different opinions) if yes which ones? Is a fender roll enough, or would a pull/roll be needed. Car will get coils but with minimal drop as my garage entry is steep and there are a lot of speed bumps in my town. 5 lug swap is not feasible as i want to retain abs all the swap kits come without ABS sensor rings (don't know if the stock one can be fit to them) and S14 parts cost 700€+ used so my wheel choice is limited. |
03-12-2020, 11:55 PM | #4156 |
ITS LISA'S FAULT!!!
Trader Rating: (41)
get rid of ABS! honestly no reason to have it, especially when you want to go with larger and better brakes mixed with your proposed wheel setup (your stopping distance will GREATLY improve with a full Z32 setup and sticky 255s). 17s on an S13 with its stock brakes is a no go... lets just say youre gonna have a bad time! (speaking from personal experience)
a roll should be just fine, but you may need to add a bit of camber front and rear. im not talking about super tilty bois style camber. maybe a degree or two at the most! though upfront youre gonna run into some issues simply due to inner fenderwell clearance (rather the lack there of) on the S13. and to be blunt, dont waste your money on those cheap wheels. quality top tier brand JDM wheels can be had SO easily now and fairly cheap too if you know how to use Yahoo Auctions Japan or Croooober. find yourself a nicely used set of Works or Volks and call it a day. you dont need to buy new. for the money you spend on those Japan Racing cast and heavy wheels, you can find yourself a set of old school, used and clean VSs, Meisters or GT-Us in similar sizes that will be lighter, stronger and look tons better! spend the money, go 5 lug, do a Z32 brake setup, ditch that god awful 1980s engineered ABS setup and import yourself some works, advans or volks in good condition. its worth the time, money, patience and labor!!! |
03-13-2020, 09:38 AM | #4157 | |
I have Z32 in the front and z32 bmc, the rear is still stock because it's bloody impossible to find N/A Z32 parts here, you see some TT stuff pop up once in a while but nothing N/A otherwise I would have done that swap even though it's supposedly horrendous to do due to the parking brake. In regards to camber I was planning on running -1.5 to -2 front and -1 to -1.5 in the rear after reading about the settings people were running so that would be in line with what you suggested. About the fenderwell, the whole body is going to be treated and repainted for rust removal so i might as well hammer out missing space where it's needed. I agree about the cheap wheels but I like the design, seeing as these are knockoff TE37s I'd instantly take the originals if I could find some anywhere reasonably priced, but then again they are still coveted so I guess it's not easy to find them even used. Another thing is offset, finding used wheels in proximity to my preferred offset is also not an easy task. On my 400hp Focus RS I'm running Bola B1 currently (also T37 knockoffs) and I'm pretty happy with them, ofc they are heavier but they also cost 2k-3k less than the originals. I also have to keep in mind that this is a daily, so damage to the wheels might happen and should it happen than I'd rather replace / repair a cheap wheel than one that I can't find a replacement for at all. I'm aware of the advantage of lower unsprung weight but all things considered this will still be a 95% daily and for track days I'd have a dedicated wheel set in the future anyway. Another question in regards to offset, I'm guessing +25 will hit the coils without spacers, correct? Doesn't the ABS still add saftey for daily driving? Even if it's 1980s technology. Tbh I haven't driven a car without ABS yet and the S13 would be my daily once it's finished, also from time to time someone else might drive it and I don't really want them to end up in a ditch even if I can get used to it with a bit of practice, but I'll read up how complicated the removal is in any case and think about it. Update: Call me a sucker, i found a 5lug swap (off an S14) including R34GTR brakes front R33 GTS-T brakes in the back that were on the car, with all hardware, knuckles, hubs, discs, pads whatnot (apart from ball joint and S14 ABS sensor) for a, lets say reasonable price. So I'll be going 5 lug after all *sigh* well at least the even bigger brakes + selling my Z32 stuff makes this swap worth it and then I don't have to worry about the braking balance being off with the GTS-T in the rear. Last edited by Inferno56kb; 03-18-2020 at 05:28 AM.. |
04-25-2020, 03:58 PM | #4158 |
Ok. After skimming the 139 pages of this thread I am still unsure if this is going to work so I need your help. I have a Kouki s14 with z32 brakes on the front and rear, stock suspension, and stock sheet metal. Will the combination below fit?
18x9.5 et+30 front 18x10.5 et+25 rear I don’t really want to pull rears and I wasn’t planning on running coilovers. Just maybe some lowering springs in the future. |
04-26-2020, 03:28 AM | #4159 | |
06-01-2020, 02:54 PM | #4161 |
Hi again, so my wheel choice got narrowed down to the basically Work Ultimate Kiwami in 17x9+17 is anyone here running a wheel in that sizing with 245 or 255 wide tires? I'd be interested if I can fit that with a pull and roll without rubbing in the front without silly camber as the build is performance oriented. So max -2.5 front -1.5 rear (the car will only get a mild drop on coils because i can't enter my garage or drive it normally around here otherwise).
The other option would be the Gram Lights 57DR in 17x9+22 but they only have them in pink and black this year according to Volk Japan and I hate both colors so I'd prefer the Kiwami in terms of color choice and looks + they would be cheaper considering a respray on the Grams. |
06-01-2020, 03:14 PM | #4162 | |
Trader Rating: (130)
Feedback Score: 130 reviews
stuffing a 245 in front and 255 in the rear will be where you have issues either: -you better not plan on going very low -you better plan on running lots of camber -you better pull that fender a pretty decent amount most of us run 215/40 or 225/40 on a 9" wheel in front 225/40 or 235/40 in the rear is very common. |
06-02-2020, 01:44 AM | #4163 | |
lots of camber is out of the question as I want that much rubber to put the power (300whp) on the road and not understeer at every corner either If it can be done with a pull I'll happily do it, what I'm wondering is if the stock fenders can be pulled that far without crumbling I know, that is actually the main reason why I asked because there are so many stretchy bois out there and almost nobody that is performance focused so it's hard to get good input. If I just wanted 215s I wouldn't choose a 9" wheel to start with. |
06-14-2020, 07:49 PM | #4164 |
Hey guys, I picked up a set of wheels a few months ago, and I just wanted to double check with guys who have more experience than I do in these matters.
Original wheels specs: 18x9+24 18x8.5+10 They'll be going on an s13, and I want a slightly more aggressive look without going too overboard. So my plan is to go a half inch wider with the lips front and back, roughly turning them into 18x9.5+12, and 18x9-2 (lets call it +-0 just to make things easier). Now it's a little hard to find pictures of an 18x9 with a zero offset on an s13 (I've found one, and he was running over 7 degrees of camber, which I'm not going to do. My main question is, should an 18x9+-0 on the front on an s13 fit similar to an 18x9.5+12? Rolling and pulling isn't a problem if it needs it, so that's not really an issue, and tire size "should" be a 225/40 F and a 235/40 R. I've seen plenty of guys run that size wheel on the front with stock fenders without having to run crazy camber (I'm not trying to tuck rim or anything crazy like that). educated thoughts and opinions would be appreciated
06-15-2020, 12:55 AM | #4165 |
^it’ll be fine with a slight pull and a decent amount of camber. shouldn’t bee more than -7? unless you’ve got extended lca’s. i’d just suggest a 225/35 up front instead to save your fenders.
06-15-2020, 10:36 AM | #4166 |
i don't mind running 3 degrees or so, but this s13 that was running 7 was slammed and just about tucking the top of the rim, and was tucking 1/2 an inch of rim on the back. my plan is to tuck just the top of the tire, so hopefully i don't have to run so much camber.
06-30-2020, 11:01 PM | #4167 |
Question:
Does anyone have experience with or photos of an S13 with 45mm extended LCAs and stock fenders? A less extended LCA with more aggressive offset or wheel spacers could also work, as long it's stock body and all the specs are there. Backstory: I have a stock body S13. Zero pull, hardly a roll up front. 17x9 +15's with 215/45/R17's up front. S15 LCA's (+10mm). Camber essentially maxed negative at the plates. It looks pretty decent in this form, especially with plain stock body. With kouki aero it is a bit too subtle for my taste. I'd like to add more negative camber and a bit more poke. I'm considering at Kazama S14/15 +35mm Extended LCAs to accomplish this. (+45mm over stock on the S13). Not looking to run adjustable, non-OEM style, or cut arms. I don't want clown car camber and I am afraid an additional 35mm of track will be too much. I'm having trouble finding anything that would give me an idea how this would look. Most 'stock body' pictures I've found are missing some key information. Here is a photo of my car currently to show +35mm wider track is at least feasible, maybe. As long as most of the 35mm is realized as negative camber rather than poke. And for reference, two of my favorites from Japan. Both are about as negative as I'd ever want to go. Bear in mind my ride height is and will remain a fair bit higher than either of them since I am running more tire. Thanks @bitaffu @katsu.180sx |
07-01-2020, 08:38 AM | #4168 |
you just answered your own question.
07-01-2020, 09:06 AM | #4169 |
https://i.imgur.com/GSfFX7o.jpg
Does anybody have any info on this car? I’m trying to replicate the fitment in the rear. It looks like a stock body car. 255/40/17? I have 17x9 +22 te’s and I’m hoping these lmgt’s are the same spec. Thanks in advance! |
