Old 04-21-2020, 02:56 PM   #1
TheRedEyedTerror
TheRedEyedTerror is an unknown quantity at this point
s14 LED Headlight Swap
I have a 240sx s14 1995 and the headlights are crap. I want to upgrade to LED lights not just for headlights but for all exterior lights. I was wondering if I can do this simple just buy LED lights and swap them or will I have to change wiring for voltage issues? Any suggestions on where to buy all of it too would be greatly appreciated!
TheRedEyedTerror is offline   Reply With Quote
Old 04-22-2020, 11:28 AM   #2
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
If your headlights have poor output it's more likely that you need to polish the oxidation off them.
Oxidation on plastic lenses can reduce output by 80%.
Old 04-22-2020, 05:24 PM   #3
NashT
NashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choicesNashT has made poor choices
They make LED headlight bulbs with built in cooling fans. Ive never used them so cant recommend a brand.
All your other lights though, like markers, brake, reverse, etc -Spend more money on the first purchase versus buying cheap crap from china.
I just recently replaced every bulb in my S13 minus headlights with Phillips LED bulbs that are 6000K.
They are way brighter than standard bulbs and worth every cent
Back to your headlights though: you shouldnt need to do any extra wiring if you go with LED bulbs. However if you buy HIDs make sure the controller is a 55w versus a 35w. And you may need to run a power relay to supplement power if the lights flicker (thats really the only negative using HIDs)
NashT is offline   Reply With Quote
Old 04-23-2020, 11:50 AM   #4
TheRedEyedTerror
Thanks, that was my biggest worry!
s14
