![]() Join Date: Oct 2004
Motor Oil Tests
I thought I would share this.... Looks a bit subjective and a bit reading from the bottle, but there are some tests that you can't refute..... Pretty cool stuff... I thought it was pretty informative.....
I use Redline or Amsoil Signature in my race motor and love it.... Royal purple in my daily.... What do you use?
I thought he did it as best as any of us could..... He has a whole bunch of videos that are awesome too like testing expensive to shitty electrical tapes, testing different types of JB or epoxy weld strength, and drywall anchors hhahaha
![]() Join Date: Dec 2007
I sell a lot of AMS signature oil to my E85 customers. Its a fantastic oil that I believe in. The TBN(total base number) is very high & really helps combat the acidic nature of the ethanol.
I use AMS oil 20W-50 high zinc in my Spec E30 Race car. I have had the same motor for three seasons now, so in my opinion its testament. As far as normal pump gas cars go....most motor oils are perfectly fine with adequate drain intervals. The cheaper the oil generally means the faster the detergents wear out. Almost all my European customers need a 5W-40 & I will sell them AMS oil Euro or Liquid Molly both fantastic oils. I even use AMS oil in my diesel they have great soot thickness control additives. These are just my opinions I know many people have different ones, with that said AMS oil is number 1! |
I DO believe amsoil is a great oil, but my problem is they seem to formulate things for stupid drain intervals, where I'd prefer maximum performance with an additive package that doesn't have to make trade-offs (according to my understanding, anyway) for freaken' million mile changes.
Also, their marketing is very frustrating and irresponsible, because cars need to be checked by someone who knows something about what they need, every few thousand miles - tell people that they can be super clever and save money and never change their oil and their engine will be totally happy and fine and even better than last time they checked it, and..... well, they believe it. It's fine for someone who can really take care of a car to go 25k and keep their fluids up, but people who can't get into trouble, because they don't understand (and can't be made to understand) the nature of engines, what happens inside them, what needs checking, what happens if you don't, and how unfixable it will be. |
I would also like to add their GL4 Transaxle Transmission Oil is the best as well. Improved cold shifting and notchiness to any transmission. I tested over cheap gear oil, shitty royal purple (never use it!), also redline shockproof and 1 other redline product....
There was a real big thread on zilvia about it a long time ago and a lot of people tried and agreed.
#7 | |||
![]() Join Date: Nov 2005
I do like this guy's testing and his honesty. He recognizes that the wear scar test is not indicative of a hydrodynamic wedge condition like engine's operate under. I definitely like that he cooked the oil, as that seemed to separate out a lot of good oils from basic ones. The problem with the testing is that none of them take into account shear, which is a very large factor in a hydrodynamic wedge environment. Would it have changed the results? Maybe, but probably not much IMO. I would like to point out that Amsoil is the only oil in this test that is confirmed to contain a majority of Group V Ester base stock. Some of the other oils have some, but are majority PAO or heavily hydrocracked Group III. I think this is significant. Redline had revised their safety data sheets to the point where it is unclear what percentage they use. Also higher end Motul uses Ester base stocks, but that wasn't tested. Motul and Redline both have some of the highest HTHS (High-temperature high-sheer) viscosities (at around 4.4), which mean they should do a better job not breaking down under hydrodynamic sheering. I'm not sure this has been directly compared via used oil analysis to other oils. It's also very hard to tell how engine oil is performing without long term testing in an engine over multiple oil change intervals. Additives like zinc and moly only adhere to metal over a certain temperature and form a high-pressure anti-wear layer that is sacrificial in nature. Even with long-term testing, it's hard to identify actual wear, as many oils perform admirably. Quote:
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 01-21-2020 at 09:15 AM.. |
![]() Join Date: Mar 2009
Personally i've transitioned to using Amsoil in every vehicle I own. Yes I change the engine oil in our daily drivers once a year because we don't come anywhere close to the 15k miles interval. More like 3-5k a year on it.
I use Amsoil Signature series in everything except my drift car which gets fresh Amsoil Dominator every 3-4 events. |
If anyone is interested, I've compiled a spreadsheet of information on oils in the 0w40-5w50 range (This would be the most common weight to use if you run your engine hard). I really want to do some long term analysis to see if it yields any worthwhile information but I haven't gotten around to it yet.
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 01-21-2020 at 09:52 AM.. |
![]() Join Date: Jan 2009
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
Always enjoyed this guys channel. He runs caparisons on everything.
As for oils, Amsoil is the best stuff I've ran in the trans on my s13. I'll be changing my s14 to it soon. I'd love to run their oil in my engine but I can't get past the price. I run Mobil 1 in my Subaru, which I change at 5k miles because it's usually getting pretty dark at that point, Rotella T5 in my s14 because a jug fills it perfectly, it's cheap, and the car doesn't get driven too much, and I've started running vr1 in the drift car. Wix filters on all of them.
#11 | ||
I think he ran oils that he could get ahold of... Esther and Motul is pretty hard to get ahold without ordering. Quote:
#13 | |
VR-1 is very cheap by comparison to AMS oil. I used to sell it but I stopped due to lack of demand. |
#14 |
![]() Join Date: Aug 2005
I've been using Delvac 15w-40 Diesel Oil. Cheap enough to change oil before and after an event and have been using it since I got my sr20.
Recommended by Martin as he runs this in his rx7. https://www.walmart.com/ip/Mobil-Del...1-gal/17034368 *Reminder, Oreilly's price match Walmart on oil.
#15 |
![]() Join Date: Dec 2014
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
I love any opportunity to share this link:
https://www.ferrarichat.com/forum/th...e-this.136052/ It is an incredibly detailed breakdown of how oil really works in your engine. The link isn't directly related to specific oils, but is full of awesome information. I read this about once a year and recommend it to any and all car enthusiasts. |
#16 | ||||
For another example, Rotella T6 that all the Subi's run because they think it saves their engine is not a great oil. It's pretty much all severely hydrocracked group III base stock. It has an okay additive package and is a 40 weight, which is why it helps them survive. All the UOA's that I've seen have shown that it sheers to close to 30 weight rather quickly anyway. I know they did just do a new formula. Quote:
Once I get my DSM running, I'm going to be doing an oil shootout of sorts on 0w40/5w40 weight oils.
#17 |
PoorMans180SX
What would you recommend for oil for a trackday 350-400WHP SR20VET that sees temp swings (trackday temp swings) from 30-40F Ambient to circa 100F ambient. Clearances for the mains and rods are standard SR20 spec. Ring clearances are slightly larger than SR20 specs. 4-5 20 min lapping sessions a day per event. |
#18 | |
If you had opened up the rods a little you could do 5w50+ and have a little more load capacity, but C'est la vie. Here's some valuable articles to read on clearance vs oil weight vs load capacity and such. https://www.substech.com/dokuwiki/do...ngine_bearings http://www.substech.com/dokuwiki/dok...ngine_bearings
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 01-22-2020 at 10:08 AM.. |
#19 | ||
#20 | |
Yeah, it's a great oil IMHO. Group V/IV base stocks, a good dose of moly and ZDDP for anti-wear, plenty of calcium for cleaning. Also ester oil tends to have a slight seal swelling effect. One of the cars I switched over stopped using oil all together and the other it was reduced by quite a bit! I run racing 50wt in my lawn mower (kinda silly I know) and that thing will sit for the entire winter and start first pull every time. A bit anecdotal, but impressive nonetheless.
#21 | |
Also, oil getting dark isn't a bad thing. That's contaminants staying suspended in the oil instead of deposited inside the engine. Hell change the oil on any diesel engine and it's black as soon as you start the engine and check the level again. Doesn't mean the oil is bad. |
#22 |
On frequent oil changes:
It's partly just paranoia, of course. Many of us got started with cars with pretty shitty cars. We've experienced firsthand how there's a lot more to an oil than just how it theoretically behaves when it fails, they've all got that figured out pretty fine. It's really the things that oil's formed as engines malfunction, and wear, and have not been maintained, and have been abused, and originally hand design flaws and planned failures and jobs that they'd need and intentional obsolescence and all that jazz. Oil that's well under it's change interval often has lots of water, chunky stuff from outside the engine, chunky stuff from inside the engine, wear metal crud, fuel contamination, and that's not even counting how the engine was dirty from two hundred thousand miles and thirty years of neglect before you even bought it. All that leads to diesel oils with very aggressive detergents and slightly boosted weights and stupid cheap prices performing pretty fuckin' amazing in real world use on multi-owner vehicles. Also, if it's still in the car, you can't know how well the oil's doing, or how well your engine in general is doing. You can take a sample, but when it's 15 dollars to drop and fill, why not just do that and know you've got any bad stuff and given it the best go at life you can, and still check out what you took out? T6 isn't the world's best oil, but from my somewhat lay and paranoid point of view on oil, it seems to be a great cheap (somewhat) synthetic on the thin side of 40 weight that you can put in just about anything. If you magicked a fresh fill of rotella 5w-40 into any random car you see on the street, you can be pretty sure that car would do better and live longer for it. |
#23 | |
The issues with neglect and "crud" should be solved in one oil and filter change, so not sure why that's a factor to consider. I've changed every car I've ever owned over to synthetic and they are all better for it for sure. T-6 is a perfectly serviceable oil that is an improvement over the dino junk a lot of people put in their cars, but it's far from the best option.
#24 |
I've been talking with Amsoil and Redline and neither one wants to disclose their ratio of PAO (Group IV) to Polyol Ester (Group V) base stocks. Redline said that it was majority PAO but "close to half" Ester, and Amsoil said their mix is "similar in ratio" to Redlines.
I'm actually pretty interested to try out Amsoil's Boosted XL line. While being group III base stock it has some pretty impressive specs on paper. Also, High Performance Lubricants, based in Manteno Illinois, has some impressive lubricants, all of which are PAO based Mostly. Schaeffer's 9000 is also a quality PAO based lube. I'm bored at work and I nerd out on this stuff. It would be interesting to see used oil analysis of these products in more hard-working, high performance engines. Bob is the oil guy is great, but it's 99% boring daily driver cars. I will be doing a shootout of sorts between a few of these. Logging oil pressure and temp and then sending them for analysis after they've served their purpose in my SR. Gonna take a while though.
#25 |
I think AMS Dominator is better in every aspect over the XL line, just a couple more dollars.
Still running AMS in everything. Can't beat it. I laugh at all the people on FB that say AMS is a scam, they don't understand. |
#26 | |
I think Amsoil is great stuff.
#27 |
im using 10-40 boosted xl in my sr20. only done about 2k miles on it tho, nothing out of the ordinary to report.
#29 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
I spoke with a long time family friend last weekend, he's owned a Transmission shop for over 40 years now and he swears by AMSoil. Like he said, sure you will pay more for the quality but they have done the R&D over the years to get the best.
He also went on to explain the 5 oil groups and pretty much anything off the shelf in NA will be a group 3 oil. There are a few exceptions like the Amsoil Sig series is a group 4 along with some redline oils. I wasn't aware of the oil groups and have no knowledge other than what he mentioned. He even said some oils are just distributed from a large factory and many companies just slap their brand on it. He said Supertech is one of them. Not sure on the accuracy, just food for thought.
#30 |
i've nerded out on engine oils before for a little bit, but still very noob.
poorman, i have a stock pile of T6 and pennzoil synthetics and mobil 1. they might not be the "best", but i feel they do a fairly adequate job of lubricating the engine in a 3k-5k oil change interval for their price. would you agree? if not, what are some of the lower-than-amsoil quality oils that you'd suggest? you said amsoil is at the top, but can u find a compromise in price and OCI with a less expensive oil? i like my SR, but not $15 per quart amounts of love :P hopefully you don't comeback with "gotta pay to play", cuz i find that hard to believe when it comes to oils of today. edit - yes if you pay more you'll get better quality oils, but i think a "lower quality" like a T6, pennzoil, mobil, will do a good enough job in a 3k-5k OCI condition or in a couple of race events, that most of us would never see the true benefits of a more expensive oil. although, i'm guessing the higher priced amsoil offers some kind of insurance if you lose oil pressure all of a sudden. because of its chemistry and bond, it allows the engine to perhaps run longer with no oil pressure than say a T6 or pennzoil or mobil1. |
