Old 12-15-2019, 01:15 PM   #1
Colorful.Knightz
Colorful.Knightz is an unknown quantity at this point
What fluid to run for power steering?
I have a 1993 240sx and want to flush the power steering. I have seen people recommend using dexron iii ATF for power steering instead of normal power steering fluid. What would be better to use, ATF or normal PS fluid?
Colorful.Knightz is offline   Reply With Quote
Old 12-15-2019, 01:26 PM   #2
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
Lightbulb
Motul Multi ATF 103221 ...........
cured13 is offline   Reply With Quote
Old 12-15-2019, 01:27 PM   #3
Kingtal0n
Kingtal0n's Avatar
If its a manual transmission car, I always use ATF
As everybody knows, all 240 leak power steering fluid.
theres nothing quite like the feeling of somebody asking you why your car leaks ATF when its clearly got a manual transmission and 80W gear oil in it.
I never tell them my secret Just act surprised
Old 12-15-2019, 01:28 PM   #4
Colorful.Knightz
Originally Posted by cured13 View Post
for power steering?
Old 12-15-2019, 01:30 PM   #5
cured13
just don't overfill
Old 12-15-2019, 01:30 PM   #6
Colorful.Knightz
for the ATF you use, do you use synthetic or normal?
Old 12-15-2019, 03:46 PM   #7
Kingtal0n
Kingtal0n's Avatar
lol use whatever kind you want. Hydraulic fluid in general will work, like for a forklift or vehicle lift or something.
I'd use a regular fluid because technically the particle size distribution should be larger and less conforming than synthetic therefore it might leak less. That applies to engine oil but I am not sure about ATF... never really thought about it
Old 12-15-2019, 04:28 PM   #8
S14rebuild
Power steering fluid goes in power steering reservoir
Atf(automatic transmission fluid) goes in the??.....
Old 12-15-2019, 05:10 PM   #9
cured13
Old 12-15-2019, 07:12 PM   #10
Kingtal0n
Kingtal0n's Avatar
I prefer atf
1. its red so you can find the leak
2. atf detergents I hear will clean the pump/lines keep em clear
3. something about seals becoming swollen
4. its cheaper, maybe
even in the ls swap I am using atf in the ps system
one time I had to put it into the clutch master to get home
won't hurt anything. worst it can do IMO is deteriorate or swell some kinda rubber and cause a leak or deform a hose. But at the same time, if the rubber was that close to falling apart, then you just dumbed down the immune system in order to find the virus, so you can cure it.
Old 12-16-2019, 08:50 AM   #11
jedi03
ATF, able to handle high temps better, detergents keep components cleaner/lasting longer, the cheap stuff tends to be less expensive than cheap power steering fluid...also is great for cleaning behind the vanes in the pump making it quieter!
Old 12-16-2019, 08:54 AM   #12
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
ATF + lucas oil PS fluid.
Don't overthink this.
Old 12-16-2019, 03:06 PM   #13
Kingtal0n
Kingtal0n's Avatar
oh, OH lets share our secret special power steering fluid recipes!
mine is:
33% ATF
24% glycol-ether 'propylene glycol'
17% mineral oil
12.5% silicone fluid
5% marvel mystery oil
5% isopropyl alcohol
2% ethanol, non denatured
1% 0W-20 synthetic engine oil
0.5% brake fluid DOT3
Old 12-16-2019, 04:25 PM   #14
brndck
brndck's Avatar
mine is:
33% ATF
17% mineral oil
sounds delicious!
Old 12-16-2019, 05:15 PM   #15
cured13
Old 12-17-2019, 08:40 AM   #16
TheRealSy90
TheRealSy90's Avatar
It's not "people" recommending ATF. Nissan recommends ATF. The cars were designed to use ATF in the power steering system. Powersteering fluid is not correct for these cars.
Such a good signature.
Old 12-17-2019, 09:32 AM   #17
jedi03
even in power steering required cars ATF performs better...https://www.reddit.com/r/MechanicAdv..._atf_fluid_as/
Old 12-17-2019, 01:45 PM   #18
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
75% Dexron VI + 25% Lucas P/S Stop leak. No lie. Lol
Jorgs_7 is offline   Reply With Quote
Old 12-17-2019, 09:21 PM   #19
Kingtal0n
Kingtal0n's Avatar
SHHhhhh GTFO STOP POSTING FACTS WTF
i can't believe this is a thread
wait maybe I can
Old 12-18-2019, 05:27 PM   #20
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
Pumps are pretty reliable on these cars, ive run them dry, with ATF, with PS fluid. or a mix of the 2 with lucas. haven't had any problems. Just don't over do it with the lucas
The Game
you lose haha
kyral is offline   Reply With Quote
Old 12-18-2019, 08:34 PM   #21
Kingtal0n
Kingtal0n's Avatar
I wasn't being sarcastic
This question comes up every 30 to 90 days on many car forums
https://www.supraforums.com/threads/...track.1118830/
Since the Supra's power steering system requires transmission fluid, I wouldn't use anything but that. Toyota 00718ATF00 Dexron III Transmission Fluid
Old 12-26-2019, 10:38 AM   #22
z31andrew
z31andrew's Avatar
z31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of lightz31andrew is a glorious beacon of light
Literally any ATF Dexron III or equivalent.
z31andrew is offline   Reply With Quote
Old 12-26-2019, 10:39 AM   #23
S14rebuild
How the fuk is this a thread in 2019......?
Old 12-26-2019, 11:14 AM   #24
Kingtal0n
Kingtal0n's Avatar
we have nothing else to discuss
this is the last interesting topic on the internet for our cars because everything has been discussed and solved already.
Did you miss it? Already gone just like that
Old 12-26-2019, 12:01 PM   #25
S14rebuild
Could u refer me to the proper window washer fluid specified in the fsm?
Old 12-26-2019, 02:10 PM   #26
Kingtal0n
Kingtal0n's Avatar
Subtype-B
Article 2 dash 1A
specific weight geometric temperature property .852gK/Lm
formula "original"
color: green/blue with orange stripes
Old 12-26-2019, 02:29 PM   #27
S14rebuild
Subtype-B
Article 2 dash 1A
formula "original"
+rep for u good sir!
Old 12-30-2019, 12:50 PM   #28
jedi03
ooh just remembered a funny one, but applicable, use electricity!!!!
