![]() Join Date: Nov 2005
Touge Factory K-series Swap Kit
Just thought you guys might be interested in knowing about this if you don't and/or talking about it! Touge Factory has just released their K-series swap kit for S13/14/15. I had the pleasure of building them an engine harness and rewiring the power management on their S14 time attack car. Really cool stuff if you ask me!
The swap uses a BMW ZF transmission and adapter plate. Pictured below is the modified oil pan that was built and tested after the initial shakedown that Hoonigan attended. ![]() ![]() ![]() ![]() Some of the harness I built, which they'll be releasing as part of the kit soon: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Definitely interested in this kit.
Those subframe spacers look way thinner than the ones Speed Academy used for their K swap, so I'm guessing it won't really effect geometry that badly? Also, it would be nice to know if A/C is going to be a possibility. |
Cool.
I get that K series are more abundant and cheaper but the initial up front cost (Motor, swap parts, sourcing the e36 transmission, standalone ecu, etc) to even do this to an s chassis kinda defeats that argument.
http://www.nissanroadracing.com/ |
![]() Join Date: Mar 2009
So what are the typical engine management options for the K-Series? Anything Plug and Play? Or just whatever you want and a custom made harness.
I'd really love to do a K24 with a garret G25-550. Just seems like it would be a LOT of money. Yeah the long block is cheap, but literally everything else has to be custom/aftermarket. |
#8 | |
![]() Join Date: Mar 2007
yeah initial investment is high, but if you grenade a motor (as long as it isn't built) it's only gonna set you back a few hundred dollars instead of a few grand for a comparably-powered sr or ka.
^even than the initial price compared to the k miata kits a few years back is super low.... whenever i get my setup running and craps the bed this is def the way to go.....
#10 | |||
Thanks!
Check out TFs ks14 on dyno. Changed my opinion in a hurry lol
THIS.
I am definitely going to consider this swap. I agree with the initial investment being high, but 450+whp from a bone stock longblock is very inviting.
#16 | |
K24 - $600 ZF 5spd - $500 TF Kit - $1700 Custom DS - $600 Harness - $1000 Clutch - $600? Misc shit - $500? Header - $750? kpro - $800 so roughly $7k for a NA variant of this swap. A turbo setup will definitely rock that up.
#17 |
Turbo kit - factor in another 2-4K considering the need for fuel as well.
Also, because there is always the "forgot this" factor; add another $1000 to your $500 for miscellaneous shit. So for a cool $10K, you are balls deep into a turbo K20/K24 swap. So about the cost of a proper VET setup. Or about 1-2K more than a garden variety VET swap (which also includes a CD009 and building up from a bare block). Bare SR block with cam caps, crank, oil pan, etc - $400 VE head - $4-$700 VE valvetrain and/or N1 cams - Valvetrain - 800 N1 cams - 450 new shipped - Machine work for block - $800-1K - Forged internals - 1000 - swap miscellaneous - $1000 - Turbo kit - 2K - IM - 500 Injectors - 500 CD009 swap and kit - 2K ECU - 1K So for a cool 12K you are also into a VET swap. 10-12K for a stock K24 with a turbo kit than can be had in the junkyard for 500 if blown up or 10K for a VET that drops right in with all the parts necessary at your disposal to run AC/PS, etc but close to 1-2K if blown up. However plenty of parts still available either way. I guess pick you poison?? |
#18 |
You are also talking LS swap price range too, not that I'm a fanboy or anything.
We had a 2006 Accord with the k24, super reliable engine. Went 100k miles with only oil changes, a PS pump, a starter, and failed vtec solenoid at the end. We bought that car new and it was totaled when someone rear ended my mother. I'm very interested in the true max limit on what the stock block can actually hold reliably. I see some people hit high numbers on the dyno but for how long. |
#19 |
Meh. A LS swap (atleast for my intended purposes) requires addressing the oiling system, which adds several more thousands to the price. I also love me some turbo and a powerband that extends out from 3500 - 8500RPM. Also, keeps the engine bay accessible.
LS, K-series or VET all comes down to preference ![]() |
#20 |
This!
For a dedicated drift car I would definitely consider the K24. The reliability of the k series and what its capable of in stock trim is fantastic. Humble performance has a video up on Youtube of a 600+whp pass with a stock internal k24a4. I can agree that we won't know how itll hold up to the abuse of drifting but the drag racing guys have been using these engines for well over quite some time with huge success.
#21 | ||
#23 | |
#24 |
NO power band. Just simply flow dynamics as the K series heads flow so well.
It's akin to putting a single GTX2871 on a LS1 or 13BREW. It will be out of "flow" right off idle. |
#26 |
I guess it didn't cross my mind that the turbo could come on TOO fast and be a problem with stock bottom end.
I wish precision still made the 5252 turbo. Maybe too small still.. Yeah, everything for the K swap seems priced reasonably but still super easy to hit 10 grand on a finished 400hp turbo/swap... Fml. Stick with a 2871r sr20 setup for half lol. |
#27 | |
Half the cost for half the powerband ![]() ![]()
#28 |
^^ Yeah, IMHO "oh man, it doesn't make x amount of HP! Or doesn't bolt in!" is very 1 dimensional. A EFR 7163 on paper making 400HP sounds comparable to a DET at the same level from strictly a HP standpoint. However, boost recovery, drivability, reliability (lower PR for same power) etc all factor into why a VET with a 7163 is light years better than a bog standard DET with a 2871 although they both technically make the same power
![]() Same can be said for a K series into a 240. It's not just about power or being able to be bolted up ![]() Sorry TheReal, not trying to be a dick, just my opinion ![]() K series the world!!! |
#29 | |
![]() Join Date: Feb 2014
