Old 09-21-2019, 09:40 PM   #1
Presto
Presto's Avatar
Presto is an unknown quantity at this point
First project going terribly need guidance
Okay guys, bought a 240sx off Craigslist that ran like complete shit but I didn’t know anything about cars at the time. Fired on like 2 cylinders and couldn’t idle, backfired constantly and, arrived at my house with a cut open header, wires running to the wrong plugs, I make a tiny check and all my time and money been going into driving this on the road one day
I did work and research over the past 6 months to get this car running nicely, it runs good in IDLE, I can step on it and it will go back to good idle and stay idleing with decent response, little to no misfire
BUT AS SOON AS THE CAR MOVES A FOOT FORWARD OR BACKWARDS IN GEAR IT INSTANTLY SHUTS OFF
Is their something DIRECTLY linked to the car moving that could cause this? It’s so annoying as soon as I think it’s time to drive it after replacing a random part every fucking pay check just to have it die after 5mseconds of moving it’s killing me inside
Sohc ka 240sx 1989
Presto is offline   Reply With Quote
Old 09-21-2019, 09:44 PM   #2
Presto
Presto's Avatar
bought headers but didn’t fit right, hammered it in so the steering rack doesn’t grind it so it gets pretty narrow off one cylinder a couple feet down the header
Bought injector rings, but ripped them on installation, replaced them again
Bought all new injectors, one didn’t work right, + fuel rail stripped, had to fix that
Bought new o2 sensor, but connecting wire looks fried, still plugs in and seems to work
Bought tps, but multimeter can’t get reading for calibration so I just have it to the right from when I put it in
Bought coolant temp sensor connector and soldered new one in
Bought a reman maf sensor, but still have intake hissing
Bought a new air cleaner, but still have intake hissing
Pulled out the fuel pump, fixed a wire, but could still be having fuel problems
Old 09-21-2019, 09:46 PM   #3
Presto
Presto's Avatar
Replaced iacv gasket/ cleaned iacv, but still have vacuum leak possibly somewhere
Adjusted idle as low as possible, but still have high idle like 1000-1100
Bought bolts to plug holes on intake manifold, but bolts are too long/poke out
Ripped the spark plug wire so replaced all ignition wires
Old 09-21-2019, 09:47 PM   #4
Presto
Presto's Avatar
Reset distributor 5 times, but timing still completely off no matter how I do it
Previous owner did emissions delete / egr block off plate seems to not be leaking
Compression test said each cylinder was at 120 exactly so that’s fucked
Searched vin number and it said in mechanics notes that engine caught on fire at some point
One of the coolant hoses under the intake manifold is KINKED
Injen aftermarket intake
Car starts up every time first try though
Old 09-21-2019, 10:16 PM   #5
Presto
Presto's Avatar
I have bad luck or I’m dumb as fuck
Old 09-22-2019, 01:21 AM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Sounds like you have a LONG list ahead of you. Fix the easy shit first, like the kinked hose under the intake manifold.
If your compression is that low, you got bigger issues.
Old 09-22-2019, 01:40 AM   #7
Presto
Presto's Avatar
I hear hissing from somewhere I think it’s vacuum leak
Also I put tape over the intake to make it run alright haha
If this ends up bad, What is a cheapest engine besides another SOHC (s13 coupe)
Old 09-22-2019, 07:55 AM   #8
StoobyMcDooby
StoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the roughStoobyMcDooby is a jewel in the rough
Agreed that if your compression is low, this all may be for nothing. I also think there is no cheaper replacement option for you than another SOHC. Where are you located?
StoobyMcDooby is offline   Reply With Quote
Old 09-22-2019, 11:49 PM   #9
Presto
Presto's Avatar
I might get ca18
Old 09-23-2019, 12:17 AM   #10
Presto
Presto's Avatar
I’m gonna do a wet compression test and if it turns out the piston rings are bad should I look for new engine or pay for rebuild
Old 09-23-2019, 01:59 AM   #11
Presto
Presto's Avatar
I looked at reviews for the compression test kit I used and it has 3 stars most reviews saying that the gauge reads low, some actually said the gauge maxed out at 120 psi
Old 09-23-2019, 05:53 AM   #12
S14rebuild
Spam bot.....
Old 09-23-2019, 09:51 AM   #13
jedi03
lol, get autozone engine and new wiring harness!
