![]() Join Date: Aug 2011
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
Z32 oil press switch work on Sr20?
Anyone know if the z32 oil press switch will work on Sr20 considering swapping over to the two pin connecter?
Will it thread on block and fit? |
Yes, the Kouki SR20 also uses the same Z32 oil pressure switch to drive the oil pressure gauge. The Z32 has 2 pins, one is a switch for the dummy light in the gauge cluster, the other pin is a variable output for a pressure gauge. I don't remember which is which off hand, but I know I called out the pins in a triple din install thread.
