Old 08-09-2019, 09:43 AM   #1
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
S14 SE with KA Full Part Out - PBM, Koyo, Mishimoto,
(415) 724-0675 - Call or Text
Located in Rohnert Park, CA
VQ35DE SWAP PARTS
VQ35 S13 Cold Air Intake - $125
VQ35 ACT Lightweight Flywheel - $300
VQ35 ACT 6 Puck Unsprung Race Clutch (2 events) - $400
SR20 ENGINE
S13 SR20 Engine Harness - $125
SR20 Ignitor - $70
S13 Stock Air Intake Tube - $50
S13 SR20 Intake Manifold - $40
SR20 Ignitor - $60
S13 SR20 Clutch Fan - $100
S14 SR20 Stock Cams - $50
SR20 Stock Clutch - $40
SR20 Flywheel - $30
SR20 Alternator Bracket - $40
SR20 Alternator - $50
S13 SR20 Upper Water Neck - $20
KA ENGINE
KA Silicone Upper Radiator hose with temp sensor port - $35
KA Intake Filter and maf adapter- $20
KA Engine mount brackets and stock motor mounts - $50
S13 KA24DE Power Steering Lines - $100
S13 KA24DE Intake Tube - $40
S13 KA Coil and Bracket - $30
JZ ENGINE
1JZ-GTE VVTi ETCSi Stock Ignition Coils - $75
1JZ-GTE VVTi ETCSi Stock Exhaust Manifold - $50
BRAKES
S13 Stock Rear Brake Calipers - $50
S14 Stock Rear Brake Calipers - $50
S13 Agency power braided brake lines (front and rear) - $80
SUSPENSION
S13 **REBUILT** steering rack (one event on it) - $400
S13 Tension Rod Brackets - $100
S13 Lower Tie Bar - $30
S13 Stance gr+ pro coilovers - $800
S13 Suspension Techniques Rear sway bar - $100
S14 Rear Coilovers (unknown brand, not blown) - $80
S14 **BRAND NEW** Suspension Techniques Front Sway Bar (never mounted) - $150
S14 Raceland Coilovers - $200
S14 Tension Rod Brackets - $100
DRIVETRAIN
S14 Rear Subframe with Energy Suspension bushings - $350
S14 Open Differential - $150
S14 Axles - $150
S13 Peak Performance Transmission Mount - $35
S13 Front Crossmember - $150
S13 Rear Subframe - $125
S13 Axles - $150
Clutch Master Cylinder - $20
Clutch Slave Cylinder - $20
Braided Clutch Line - $40
EXTERIOR
S13 Pig Nose Front Bumper - $100
S13 Bumper Support (pop up headlights) - $60
S13 Power Side Mirrors - $60
S13 Passenger Door (manual windows, no glass, regulator, door panel etc.) - $80
S13 Driver and Passenger Doors (set, power windows, no glass or regulators etc.) - $150
S13 Hatchback Stock Tail Light Set - $50
S13 Hatchback Tail Light Metal Trim Panel - $50
S14 Bumper Mounting Bracket - $50
S14 Trunk - $70
S14 Passenger Door - $80
S14 Zenki Tail Lights - $50
INTERIOR
S14 Driver Seat - $100
S13 Ebrake Handle - $40
S13 Ebrake Cables - $50
S13 Power Door Panels - $70
S13 Hatchback Privacy Cover - $70
S13 Power Window Regulators - $120 for the pair (motors included)
S13 Climate Control - $50
S13 Passenger Side Window Switch - $40
S13 5 speed shifter trim (no boot) - $60
S13 Black Kick panels - $50
S13 Bottom mount seat bracket - $40
(2) Simpson 5pt Race Harnesses - $90
Driven Suede Steering Wheel - $60
MISCELLANEOUS
S13 Engine Bay Wiring Harness with 2 Fuse Boxes - $175
S13 Radiator Brackets - $25
S13 Hood Latch - $35
S13 Hood Latch Cable - $30
S13 TCU Box - $25
S13 Storm Fenders Braces - $25
S14 Hood Hinges - $40
Universal Ebay Blow Off Valve (new) - $25
Aftermarket Remote Oil Filter Mount - $20
RX7
FD OEM Speaker Mounts (driver and passenger) - $50
FD Clock Spring - $175
13B Ignitor - $40
FD Stock Front Lower Control Arms - $175
FD Adjustable Rear Trailing Arms - $100
FD Aftermarket Adjustable Rear Toe Rods - $100
FD Stock Rear Lower Control Arms - $175
FD Stock Rear Upper Control Arms - $175
FD Rear Washer Res and Pump - $40
FD Stock Jack Tools - $40
FD Evap Canister - $25
DJPimpFlex is offline   Reply With Quote
Old 08-12-2019, 11:27 AM   #2
DJPimpFlex
DJPimpFlex's Avatar
Bump - list updated
Old 08-12-2019, 09:32 PM   #3
rfs324
rfs324 is an unknown quantity at this point
are the ikeya tie rods new or used?
rfs324 is offline   Reply With Quote
Old 08-12-2019, 10:38 PM   #4
DJPimpFlex
DJPimpFlex's Avatar
Used
Sent from my Pixel 3 XL using Tapatalk
Old 08-20-2019, 12:28 PM   #5
DJPimpFlex
DJPimpFlex's Avatar
Bump...............List updated
Old 08-22-2019, 11:48 AM   #6
DJPimpFlex
DJPimpFlex's Avatar
Bump bump!!!!!!!!!!!!!
Old 08-22-2019, 11:51 AM   #7
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Man I sold my open diff for way too cheap after seeing this....
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 08-22-2019, 04:07 PM   #8
Infamousdirt
Infamousdirt's Avatar
Infamousdirt is an unknown quantity at this point
Are you willing to sell the S13 SR throttle body?
Infamousdirt is offline   Reply With Quote
Old 08-22-2019, 04:30 PM   #9
DJPimpFlex
DJPimpFlex's Avatar
I don't have a throttle body, just the intake manifold
Old 08-22-2019, 05:35 PM   #10
nicoshiro79
nicoshiro79 is an unknown quantity at this point
gas tank shipped to 96744?
nicoshiro79 is offline   Reply With Quote
Old 08-22-2019, 06:00 PM   #11
DJPimpFlex
DJPimpFlex's Avatar
Sorry no shipping on that item
Old 08-23-2019, 10:08 AM   #12
DJPimpFlex
DJPimpFlex's Avatar
Bump bump......................
Old 08-29-2019, 10:05 AM   #13
DJPimpFlex
DJPimpFlex's Avatar
Bump - List updated
Old 08-29-2019, 02:49 PM   #14
A6775
A6775 is an unknown quantity at this point
What year is that manual ka ECU?
A6775 is offline   Reply With Quote
Old 08-30-2019, 01:42 PM   #15
junkyiv
junkyiv's Avatar
junkyiv is just really nicejunkyiv is just really nicejunkyiv is just really nicejunkyiv is just really nicejunkyiv is just really nicejunkyiv is just really nicejunkyiv is just really nicejunkyiv is just really nicejunkyiv is just really nice
Free Bump, I want that hood.....just too far away!
junkyiv is offline   Reply With Quote
Old 08-31-2019, 05:04 PM   #16
S13SilviaGirl
UGH Really?
S13SilviaGirl's Avatar
S13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfection
Color and pics of the s14 pass door pls
My Review Thread
Originally Posted by DTCSuperstar
I surf Zilvia naked in my home...
S13SilviaGirl is offline   Reply With Quote
Old 09-01-2019, 11:49 AM   #17
DJPimpFlex
DJPimpFlex's Avatar
Sold that sorry
Old 09-03-2019, 10:00 PM   #18
S13SilviaGirl
UGH Really?
Originally Posted by DJPimpFlex View Post
Sold that sorry
Do you still have the s14 5 speed drive shaft?
My Review Thread
Old 09-03-2019, 10:06 PM   #19
DJPimpFlex
DJPimpFlex's Avatar
Gone sorry
Old 09-05-2019, 08:01 PM   #20
OMFGeofffff
OMFGeofffff's Avatar
OMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really niceOMFGeofffff is just really nice
What kinda condition is the SR harness in?
OMFGeofffff is offline   Reply With Quote
Old 09-06-2019, 09:40 PM   #21
DJPimpFlex
DJPimpFlex's Avatar
Complete and 100% uncut
Old 09-20-2019, 09:02 PM   #22
Rickpr
Rickpr is an unknown quantity at this point
Have a AC Condenser available?
Rickpr is offline   Reply With Quote
Old 09-22-2019, 12:15 PM   #23
Ripzsaur
Ripzsaur's Avatar
Ripzsaur is an unknown quantity at this point
Would you ship the trans? 27360
Ripzsaur is offline   Reply With Quote
Old 09-22-2019, 12:20 PM   #24
DJPimpFlex
DJPimpFlex's Avatar
No sorry
Old 09-22-2019, 10:52 PM   #25
tootall4la
tootall4la's Avatar
tootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to all
Quarter panels
tootall4la is offline   Reply With Quote
Old 09-24-2019, 11:35 AM   #26
DJPimpFlex
DJPimpFlex's Avatar
Bump bump list updated.
Old 10-02-2019, 10:25 AM   #27
DJPimpFlex
DJPimpFlex's Avatar
Bump - list updated
Old 10-05-2019, 08:13 AM   #28
JRC
JRC is an unknown quantity at this point
happen to have a s14 sunroof tray and glass?
JRC is offline   Reply With Quote
Old 10-05-2019, 08:33 AM   #29
DJPimpFlex
DJPimpFlex's Avatar
I Don't sorry
Old 10-10-2019, 01:04 PM   #30
DJPimpFlex
DJPimpFlex's Avatar
