FS: C5Z06 2002 Silver, 149k miles, with NEW ENGINE & CLUTCH
Chassis has 149k
Engine / Clutch and flywheel has less than 1000miles (2 oil changes for break in) Around 420whp with stock headers. Engine build goal was to have reliability at high RPM operation and good mid range TQ. Pass CA emission and clean title registered in CA. Exterior: 7/10 Interior: 8/10 Engine: 10/10 C5 Z06 Blue printed engine rebuilt with all receipts Engine machine and build Improved racing Oil pan baffles Lower pan gasket New Flywheel bolts Monster stage 2 clutch kit with light weight flywheel New power steering hose New serpentine belt Pro balancer Coolant temp sensor Knock sensor Knock sensor harness Engine oil pressure sensor Engine oil sensor connector Crank position sensor connector New denso spark plugs Spark plug heat shields GMPP spark plug wires New 160 thermostat Exhaust studs Exhaust nuts Port and polished 799 heads Valve springs Performance seats, seals, dual springs, retainers Valve cover gasket Fuel filter Stainless steel braided teflon racing fuel line and swivel hose ends Comp cam Flipped intake mod with K&N intake Setrab 625 oil cooler with lingenfelter performance sandwich plate Dewitt radiator Borla stinger exhaust And many more... Hotckis sway bars Drm aluminum steering rack bushing DRM spec Bilstein shocks C4 ZR1 17x19.5, 17x11 NT555 G2 275/40/17F 315/35/17R ARP wheel studs Carbotech xp10, xp8 pads Front brake cooling duct(3") spindle mounted (great for brake cooling) Lowered on stock bolts Corner balanced w 170lbs driver & 1/4 tank of gas Sparco Evo driver seat Mti racing seat rail Hardbar harness bar Cam lock 6pt harness Vette works harness bottom Anchor Momo sprint 350mm wheel Nrg hub & adapter 12" Kicker subwoofer 5ch kenwood amp Kenwood single din head unit Aluminum interior door sill C5Z C6 shift knob swede shift boot Aftermarket aluminum pedals and foot rest passenger side mounted fire extinguisher Fixed headlight Aci rear spoiler Front tow hook Rear tow hitch receiver 1-1/4” (for towing tire trailer) Trackspec Hood vents Had this car since 2013 and garage kept it. Clean title in hand, registered in CA till sep 2019 and will pass CA smog. All service record in hand during my ownership, including new engine build receipt. The car rips and handles awesome. New engine has less than 1000 street miles. asking $17,500 OBO Text @ 818-3O7-3850 Andrew for more info! more info below!: https://www.corvetteforum.com/forums...nd-clutch.html |
Corvette C5 Z06 2002 Silver, 149k miles, with NEW ENGINE & CLUTCH
Around 420whp with stock headers. Engine build goal was to have reliability at high RPM operation and good mid range TQ. Chassis has 149k Pass CA emission and clean title registered in CA. Located in 91011. Exterior: 7/10 Interior: 8/10 Engine: 10/10 C5 Z06 Blue printed engine rebuilt with all receipts Engine machine and build Improved racing Oil pan baffles Lower pan gasket New Flywheel bolts Monster stage 2 clutch kit with light weight flywheel New power steering hose New serpentine belt Pro balancer Coolant temp sensor Knock sensor Knock sensor harness Engine oil pressure sensor Engine oil sensor connector Crank position sensor connector New denso spark plugs Spark plug heat shields GMPP spark plug wires New 160 thermostat Exhaust studs Exhaust nuts Port and polished 799 heads Valve springs Performance seats, seals, dual springs, retainers Valve cover gasket Fuel filter Stainless steel braided teflon racing fuel line and swivel hose ends Comp cam Flipped intake mod with K&N intake Setrab 625 oil cooler with lingenfelter performance sandwich plate Dewitt radiator Borla stinger exhaust And many more... Hotckis sway bars Drm aluminum steering rack bushing DRM spec Bilstein shocks C4 ZR1 17x19.5, 17x11 wheels NT555 G2 275/40/17F 315/35/17R ARP extended wheel studs Carbotech xp10, xp8 pads Quantum Front brake cooling duct(3") spindle mounted (great for brake cooling) Lowered on stock bolts Corner balanced w 170lbs driver & 1/4 tank of gas @ Westend Sparco Evo driver seat Mti racing seat rail Hardbar harness bar Cam lock 6pt harness Vette works harness bottom Anchor Momo sprint 350mm wheel NRG hub & adapter 12" Kicker subwoofer 5ch kenwood amp Kenwood single din head unit Aluminum interior door sill C5Z C6 shift knob swede shift boot Aftermarket aluminum pedals and foot rest passenger side mounted fire extinguisher Fixed headlight Aci rear spoiler Front tow hook Rear tow hitch receiver 1-1/4” (for towing tire trailer) Trackspec Hood vents Had this car since 2013 and garage kept it. Clean title in hand, registered in CA till sep 2019 and will pass CA smog. All service record in hand during my ownership, including new engine build receipt. The car rips and handles awesome. New engine has less than 1000 street miles. asking $17,500 OBO Text @ 818-3O7-3850 Andrew for more info! More pics on: https://www.corvetteforum.com/forums...nd-clutch.html More pics on: https://www.corvetteforum.com/forums...nd-clutch.html More pics on: https://www.corvetteforum.com/forums...nd-clutch.html More pics on: https://www.corvetteforum.com/forums...nd-clutch.html More pics on: https://www.corvetteforum.com/forums...nd-clutch.html More pics on: https://www.corvetteforum.com/forums...nd-clutch.html More pics on: https://www.corvetteforum.com/forums...nd-clutch.html Last edited by rkd350z; 07-06-2019 at 03:41 PM.. |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
Merged your two threads.
Your images aren't showing up because your google images are probably private.
![]() Best way to do business with me? Make your best offer FIRST. |
