Old 10-08-2018, 05:45 PM   #1
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
1990 Nissan 240SX Hatch | SR20DET | GTX2867r
SOLD
Up for sale, the last 7+ years of me wasting money. The car is heavily modified. Power windows, speedo, tach, lights, wipers, etc all work. It does not have speakers, heat or AC. The car is VERY solid over all, runs well, pulls hard, idles, etc.
Bare bones wiring, done from the ground up, tucked inside and out. Front wheel wells are tubbed, stitch welded, seam sealed, under coated etc. Wheel arches modified/reinforced for major clearance. No harness in the wheel wells. Brake lines, clutch, PS, Vac, etc all tucked.
The chassis has ~150k on it, but at this point every single 'wear item' was replaced anyways. there isn't much or the original car left outside of the shell. I am the third owner, got it bone stock in FL. Not a spec of rust anywhere. The engine and most parts have 2500 miles on them. It's been a long slow project and once it was 'done' I hardly drove it. Those 2500 miles took me 4 years.
Running 17 PSI on the Tial WG, that's the most it has ever seen. I never beat on the car, never drifted, never even hit rev limiter. Just casually cruised the thing on nice days. That's why I am hesitant to let it go. I know the setup is super solid and I never got a chance to really enjoy it.
I am sure I’m missing stuff. I’ve owned the car for many years and have forgotten some of what’s been done. It will come with every single S chassis related part I own, as I think it is time to move on. I’m not one to cut corners, there are a ton of little things on this build that I custom made/machined/fabbed etc. I strive to do things as best as possible, if you appreciate that type of thing maybe this is for you.
I'd consider trades, but not some drift car. Clean, stock/tastefully modded, simple reliable. Maybe trucks feel free to offer, I won't be a dickhead about it.
ENGINE
SR20DET [redtop] Enthalpy tuned. All machining done by Mazworx [hot tank, dec, hone, sand blast, freeze plugs, etc] Built with new head bolts, bearing bolts, timing chain tensioner, oil pump, gaskets, etc.
o CP Pistons 86.5mm
o Eagle Rods
o ACL bearings
o S14 Oil Pickup
o New oil pump/front cover
o Greddy oil pan
o Tomei Oil block [filter relocation]
o Supertech valve guides, seals [Mazworx]
o Valve job – fit/lap valves, measure and shim [Mazworx]
OEM exhaust manifold: w/ Vband for EWG, machined flange mating surface on manifold and turbos to ensure flatness. Upgraded to M10 Studs for turbo flange. [to not blow out gaskets]
Garret GTX2867R
Tial MVS
SARD 850cc
NISMO FPR
OEM Supra TT Denso fuel pump
Z32 MAFS
J30 Ignitor
Billet CAS cover [polished]
Polished water necks, billet pulleys
Custom AN lines for turbo coolant/oil
Custom upper water neck w/ AN fitting welded on
Custom downpipe with flex section and resonator [one piece like PBM] less gaskets to leak
3” exhaust w/ resonator, dual 4” blast pipes
Custom Mid Mount intercooler, using PBM piping. Headlights can go up/down [not wired but motors still there]
Blitz BOV
Koyo Radiator
Suspension
Fortune Auto 500 Coilovers
ISR tension, toe, caster arms
Circuit sports RUCA
PBM Solid Subframe bushings
Full Energy suspension control arm bushings
Energy suspension steering rack bushings
Custom ‘Nismo power brace’
Garage Zeal motor mounts, powder coated black
Fresh reman steering rack
OEM NISSAN strut bar
Brakes
30mm aluminum 300ZX brakes - rebuilt and powdercoated black
New 17/16 master
Stainless braided lines at each caliper
300ZX ebrake cables + custom mount bracket
Drivetrain
1 piece Al driveshaft [painted gold cuz its fucking baller]
B&M short shifter
Clutch: ACT 4 puck unsprung w/ HD pressure plate. It locks up hard.
Electrical
AEM UEGO AFR Gauge
APEXI boost gauge [PSI]
STRI water temp, oil temp, oil press gauges in custom panel
Wiring specialties pro engine harness.
100% full custom chassis wiring, fuse panel, etc.
Dual efans on dakota digital controller
AGM battery, relocated to cabin behind passenger seat
Quest alternator
Circuit breaker in center console
Interior
Most of a OEM interior and parts are MINT. flawless dash, centerstack trim, console, door cards. Headliner died black
Gucci Shit
Super rare Enkei Wheels: 17x10-5, 17x9+20
PS pump relocated on custom bracket setup like Taarks.
All new custom PS lines, reservoir relocated/tucked.
Kouki 180SX Tails
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 10-13-2018, 11:09 AM   #2
brokeboi01
brokeboi01's Avatar
brokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enoughbrokeboi01 will become famous soon enough
This thing is stupid clean. Glws
brokeboi01 is offline   Reply With Quote
Old 10-15-2018, 03:40 PM   #3
AwhiteS13
AwhiteS13's Avatar
AwhiteS13 is an unknown quantity at this point
I might be missing it but what kind of engine management?
AwhiteS13 is offline   Reply With Quote
Old 10-18-2018, 08:50 PM   #4
BRAIN_Z33
BRAIN_Z33's Avatar
BRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfection
Damn nice car. Glws
BRAIN_Z33 is offline   Reply With Quote
Old 10-24-2018, 05:08 AM   #5
KoukiMonsta
Originally Posted by BRAIN_Z33 View Post
Damn nice car. Glws
Thanks Guys
Enthalpy, looks like I missed that, thanks for pointing it out.
@UpshiftEngineering
Old 11-15-2018, 12:24 PM   #6
KoukiMonsta
New pair of tires on the rear and a fresh alignment, fresh rubber all around now.
Took it for a cruise in the hills last weekend and hot damn it tracks well now. Almost want to keep it, need to buy a house tho
@UpshiftEngineering
Old 11-17-2018, 06:16 PM   #7
s13Patrick
s13Patrick's Avatar
s13Patrick is an unknown quantity at this point
bump. im in winston too and ive never seen it before. but this is stupid clean.
s13Patrick is offline   Reply With Quote
Old 11-26-2018, 01:44 PM   #8
KoukiMonsta
thanks man. I literally NEVER drive the car.
sometimes when its super nice out I head north for some twisties.
get old, life gets in the way, car collects dust.
@UpshiftEngineering
Old 11-26-2018, 03:48 PM   #9
Green Arrow
Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow Green Arrow
Wow, well done!
Green Arrow is offline   Reply With Quote
Old 11-26-2018, 06:15 PM   #10
dyrmz134
dyrmz134 is an unknown quantity at this point
ALSO live in Winston, ALSO never seen this car, ALSO...I want
dyrmz134 is offline   Reply With Quote
Old 01-19-2019, 06:35 PM   #11
KoukiMonsta
Added a quick video clip to the top of the OP. Gotta makes sure the car still works every once in a while
@UpshiftEngineering
Old 01-20-2019, 07:53 AM   #12
Bunn
Bunn's Avatar
Bunn is an unknown quantity at this point
Winston salem over here too !!
Bunn is offline   Reply With Quote
Old 03-16-2019, 04:22 AM   #13
KoukiMonsta
Bring up my post
@UpshiftEngineering
Old 03-16-2019, 11:51 AM   #14
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
Yo this is really nice.
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
Old 03-18-2019, 09:45 AM   #15
Liabilities
Liabilities is an unknown quantity at this point
Great car, free bump. That clean for that price nice deal for who ever gets it
Liabilities is offline   Reply With Quote
Old 03-19-2019, 02:28 PM   #16
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
12.5k for a car with no radio, no ac, no heat , stock seats, stock paint, pig nose
I must be missing something
greenwood is offline   Reply With Quote
Old 03-19-2019, 02:35 PM   #17
Liabilities
Missed that no heat part XD oops. Other stuff im use to no ac/ easy to fix radio paint seats
Old 03-19-2019, 03:27 PM   #18
RedSnow
RedSnow's Avatar
RedSnow is an unknown quantity at this point
he clearly emphasized the built on other aspects of the car. (Hint: a solid and clean running SR and chassis that still looks beautiful)
12.5 asking price seems fair to me. If you are looking for your typical clapped out stock sr with wires everywhere and ebay body parts you can definitely get one for cheaper if that is how you role...
RedSnow is offline   Reply With Quote
Old 04-03-2019, 07:54 AM   #19
KoukiMonsta
It's OK if people don't like it, I built it for me.
Going to give this thing some love and try to drive it a bunch this summer. Unless someone decides they need it!
@UpshiftEngineering
Old 04-03-2019, 11:55 AM   #20
RB25GUY
RB25GUY's Avatar
RB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to all
Too clean man! Honestly some people just dont recognize quality work cars spotless.. priced high but importers are selling rusty CA18 180sx for the same price GLWS
Originally Posted by smellslikecurry View Post
Its not like you're putting a safc in a fucking Tesla.
RB25GUY is offline   Reply With Quote
Old 04-18-2019, 11:03 AM   #21
KoukiMonsta
bring up my post
@UpshiftEngineering
Old 05-01-2019, 03:43 PM   #22
Silviastunter
Silviastunter is an unknown quantity at this point
Bump for clean car
Silviastunter is offline   Reply With Quote
Old 06-02-2019, 06:21 AM   #23
KoukiMonsta
Monthly bump. Help me fund adult life purchases.
@UpshiftEngineering
Old 06-02-2019, 10:14 PM   #24
Persona
Persona's Avatar
Persona is an unknown quantity at this point
NOOOOOO. Bump for an old homie, wish I could buy this but I don’t need. 5th car lol.
Persona is offline   Reply With Quote
Old 06-03-2019, 01:07 PM   #25
kanyedian
kanyedian's Avatar
kanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nice
Wow super clean engine bay, man. Props and free
kanyedian is offline   Reply With Quote
Old 06-06-2019, 08:47 AM   #26
KoukiMonsta
I've come to terms with the thing collecting dust lol. you drive yours ever?
@UpshiftEngineering
Old 06-09-2019, 12:17 AM   #27
Kirbyz
Kirbyz is an unknown quantity at this point
10k cash offer I'll drive it there and back.
Kirbyz is offline   Reply With Quote
Old 06-17-2019, 05:13 AM   #28
KoukiMonsta
Thumbs down
drive it to hawaii? come n' get it
@UpshiftEngineering
Old 06-17-2019, 05:35 PM   #29
Kirbyz
402-615-8274 I just sold my s2000 and got cash for a new toy I'm serious.
Old 06-23-2019, 05:04 AM   #30
Kingtal0n
Kingtal0n's Avatar
the engine alone is worth what hes asking for the whole car
the ad should say "built SR20 from maxworx for sale: 12k"
PS Car included free if you want
tinyurl.com/4l80er
