04-17-2019, 02:13 PM | #1 |
S14 Spindle / hub assembly (Driftworks) Question
Hey everyone, I'm running into some issues and need input. I have purchased Driftworks drop knuckles and 5 Lug hubs from 240sxconversions (fronts) and I am having a heck of a time with getting the hubs on to the spindle... Every video I've watched it seems the hub should just slide on to the spindle but mine go on about half way and stop.. Without pressing the hubs on to the spindles they wont go on.. I don't want to mess anything up and was hoping someone could measure the STOCK spindle with a micrometer/caliper and tell me what diameter they get, is it 34mm? What should the inner dia. of the bearing be on the hubs? Anyone else run into something similar to this? THANKS IN ADVANCE.
04-17-2019, 08:21 PM | #3 | |
04-19-2019, 01:13 PM | #5 |
On most aftermarket parts the tolerances are never perfect. With some of the gktech units we had to sand the spindle a bit or measure out and decide if the tolerance was close enough to see if pressing it on would work without destroying the race.
04-19-2019, 04:09 PM | #6 |
Trader Rating: (68)
Feedback Score: 68 reviews
I have the Driftworks "Grip" Knuckles on my s14 and had zero issues installing my hubs onto the knuckles. Like tacotacotaco mentioned though, tolerences are different when it comes to aftermarket parts. If I were you Id do what he said and just sand the spindles down a bit until the hubs slide on fairly easily.
Have you measured the I.D. of the hubs to see exactly how much of an interference you have? |
04-19-2019, 04:14 PM | #7 |
THX for the feedback I WANT TO GET MY CAR BACK!!! Been on blocks for almost 2 years (for other reasons..)
First set of hubs were measuring around 33.83ish ID or so.. .Got my latest and they are right on 34.00.. They go down about 1/4" of the way and get wedged and I have to carefully remove them without popping the rear race out of the hub.. How would I go about sanding the spindle evently? Or do I just get 1000 grit and do the best I can? Should I have the spindles machined ?? I just want to do it right but at the same time get my car back on the road.. THX!!! |
05-07-2019, 01:25 PM | #10 |
Spindle tolerances are 0.0005", i.e. the spindle should only be 0.0005"-0.001" smaller than the bearing ID. It's a near perfect sliding fit, not interference/press.
Things this precise are generally ground for surface finish and precision. Aftermarket stuff that has critical dimensions like a spindle should always be measured to be trusted. Their ability to hold tolerances like that is highly variable. As you can see, that spindle probably also has a taper on it as well. It also means you should be measuring these things with a micrometer and telescoping gauges, not a caliper. I mean a caliper gets you pretty close, but if you want to know 0.0005" increments, they aren't the right tool. And sanding can work, but it may take you an eternity to remove even 0.0005" with high grit sand paper. If you have the ability to chuck it in a lathe with live centers, your life will be made much easier if you go the sanding route and will do it guaranteed evenly. Just keep a micrometer by you and measure constantly. |
05-07-2019, 02:16 PM | #11 |
Thanks Gills.. Very informative post but now I am once again at a standstill. I was going to attempt sanding the spindles but now with my OCD not sure of this decision to do so.. My fear is not being able to sand it down evenly and no access to lathe or machine shop that I would trust with these knuckles.. WTF DW!! Lol
05-07-2019, 02:42 PM | #12 | |
But, for machine shop details, when I say "live center," it means they will hold and support the upright with the small spotted hole at the nose of the spindle and then there should also be one on the back side of the spindle that's perfectly inline with the centerline of it. Those are tooling marks the manufacturer used to machine the spindle. |
05-07-2019, 03:02 PM | #13 |
I appreciate the feedback gills.
A colleague in thread #8 measured the spindle at 33.96 , any chance you can take a reading as well to confirm the ball-park I am aiming for please? Thank you!!! |
05-07-2019, 03:42 PM | #14 | |
What I do have are a few hubs and I can measure them. Won't be until tomorrow. |
