Old 04-10-2019, 11:39 AM   #1
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
SR de vs. det flex plate. Are they same??
Hi all,
I'm planning on swapping to a different transmission.
For this swap, i need to utilize a stock sr20det flex plate for the starter.
Is sr20de flex plate same as det? especially the ring gear count and space in between.
instagram : battery1882
www.sterculture.com
battery1882 is offline   Reply With Quote
Old 04-10-2019, 11:59 AM   #2
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Are you referring to the dust shield between the tranny and the block??
If so, they should be. They both use the same tranny
Old 04-10-2019, 03:13 PM   #3
battery1882
Hi ralliart,
No I'm referring to Automatic trans flexplate (what flywheel would be to manual trans).
Maybe drag guys can chime in and help?
www.sterculture.com
Old 04-10-2019, 05:00 PM   #4
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
sr20det automatic and manual use the same flexplate
cured13 is offline   Reply With Quote
Old 04-10-2019, 06:21 PM   #5
battery1882
thank you but you didn't answer my question.
Automatic uses flexplate
manual uses flywheel.
question. is sr20de flexplate same as sr20det flexplate. both would be automatic obviously.
www.sterculture.com
Old 04-10-2019, 07:38 PM   #6
RalliartRsX
Trader Rating: (32)
Oh I see.
Yes should be the same. They both should use the same tranny
If my memory serves me correctly, the only time the flex plate changed was on the FWD models as they went to a different tooth count for OBD2 (which wouldn't apply to this case)
Old 04-11-2019, 08:30 AM   #7
battery1882
Oh I see.
ah hah... I was actaully looking at fwd flexplates as they are much easier to source. essentially, all I just need from it is to start the car.
www.sterculture.com
