Old 11-11-2018, 03:06 PM   #1
tacotacotaco
tacotacotaco's Avatar
tacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfection
Send a message via AIM to tacotacotaco
S14 HKS HIPERMAX COILOVERS/ Revel by Tanabe Coilovers
HKS HIPERMAX IV SP $SOLD
1k Miles used for break in and review
The highest and newest line of coilovers for the s14 by HKS
The HKS HiperMAX GT coilover was designed for the enthusiast that wants to upgrade the handling of their car while being able to lower it for style while not losing out to much on daily driving comfort. The Hipermax GT features a 6kg front 5kg rear spring rate. The has an adjustable front pillow ball mount up front to allow for camber adjustment while the rear features a hardened rubber upper mount to help keep road noise and other sounds that come with lower quality coilover systems. The GT even though it has a focus on comfort will still perform on the track. Not recommend for cars that will be tracked for competition use as there are better options when building a dedicated track car.
HiperMAX IV the new damper from HKS returns to the core of tuning, the street. Featuring an advanced shock absorption system, the MAX IV captures the bumps on the road to give a supple yet stable ride. MAX IV aims for a high level balance of comfort with sporty handling.
It’s perfect for daily street drive with style and performance. You and your passenger can have a comfortable ride even with a low-down.
Single Tube Damper Design
Mono tube dampers allow for more accurate and stable control and adjustment of dampening. Lower ride height and centre of gravity gives a more stable ride.
Dust Boot
Protect the shaft from the flying stones.
PNE Coating
Using this special surface coating provides 5 times better durability over standard galvanising. This prevents build-up around the threads of the adjustment areas allowing for easier height adjustment.
M Shaft
With the new design of cylinder shaft since the HIPERMAX M-1, MAX IV increased the cylinder shaft size to have a firm damping even at a little stroke range because of the optimized oil pressure characteristic. We mainly adopted this to the rear damper that can have a better driving experience.
New Design Needle
Newly designed needle has been used to revise the very low speed and middle and high speed dampening which is key to a comfort ride.
Reduction of Unsprung Weight
In order to reduce unsprung weight, bracket, ride height adjusters and lock nuts are made from aluminium. (Not for all vehicles)
30 Step Damping Force Adjustment
30 levels of dampening adjustment allow fine tune adjustment for street or circuit.
Lowering (Front): -47mm (From 0 to -81mm)
Spring Length (Rear): 250mm
Damping Force (Rear): 839m/sec (Rebound) & 382m/sec (Compression)
Spring Length (Front): 220mm(Barrel)
Damping Force (Front): 211m/sec (Rebound) & 137m/sec (Compression)
Front Upper Mount: Rubber
Spring Rate (Front): 59N/mm (6kgf/mm)
Lowering (Rear): -45mm (From 0 to -80mm)
Rear Upper Mount: Rubber
Spring Rate (Rear): 49N/mm (5kgf/mm
https://www.hksusa.com/products/80250/AN002/3028
Revel Coilovers by Tanabe
Monotube 1k miles on the set $Sold
The 32 way adjustable Revel Touring Sports Damper is the ideal solution for the most comfortable ride in a coilover kit while achieving an extremely low ride height and utilizing the perfect balance of dampening forces and spring rates to deliver smooth performance when it is needed.
Pillowball upper mounts give the driver greater driving feedback when compared to OEM rubber upper mounts. A spherical bearing is used in place of a rubber bushing and an adjustable camber plate is utilized on certain applications which aid in achieving improved tire traction and alignment.
Teflon thrust washers reduce friction during steering movement and eliminates spring binding and movement. Also eliminating unwanted noise and maintaining proper adjustment of the height adjustment.
Larger piston valves and oil capacity allows for a faster reacting dampening force and efficiency through all temperature ranges. High strength and rigidity brackets ensure the driver has the utmost confidence for all driving types
Both sets sold please lock!
tacotacotaco is offline   Reply With Quote
Old 11-12-2018, 04:27 PM   #2
tacotacotaco
shipping is available pm for quote.
Old 11-28-2018, 02:22 PM   #3
tacotacotaco
Bump it up still available.
Old 12-15-2018, 06:46 PM   #4
tacotacotaco
Bump for price change
Old 12-16-2018, 12:36 AM   #5
damebash
damebash is an unknown quantity at this point
Are prices OBO?
damebash is offline   Reply With Quote
Old 12-17-2018, 10:12 AM   #6
tacotacotaco
Originally Posted by damebash View Post
Are prices OBO?
Feel free to DM an offer
Old 12-28-2018, 01:56 PM   #7
tacotacotaco
$650 for the revels. Bump it up
Old 01-02-2019, 01:55 PM   #8
tacotacotaco
New years bump!
Old 01-10-2019, 03:07 PM   #9
tacotacotaco
Motivated to sell shoot a pm
Old 01-21-2019, 10:38 AM   #10
Galaxy _S14
Galaxy _S14's Avatar
Galaxy _S14 is an unknown quantity at this point
Still have the tanabe revel? Pm me
Sent from my Nexus 6P using Tapatalk
Galaxy _S14 is offline   Reply With Quote
Old 01-21-2019, 12:05 PM   #11
tacotacotaco
Your inbox is full
Old 01-21-2019, 12:18 PM   #12
tacotacotaco
Revels are SOLD. HKS are still up for grabs. Make an offer will do trades
Old 01-23-2019, 12:12 PM   #13
tacotacotaco
Buyer MIA revels back up for sale.
Old 01-29-2019, 03:06 PM   #14
tacotacotaco
All PMS answered still up.
Old 01-30-2019, 08:53 PM   #15
tacotacotaco
Sold please lock!
