#21902 |
![]() Join Date: Nov 2015
![]() ![]() Feedback Score: 6 reviews
This is a relay setup question,
would it be better to run one relay to turn on two fans simultaneously or two relays, each getting the same inputs, to run one fan each?
Skurr ![]() |
#21904 |
I was thinking of running both on a thermostatic switch, if not that then off the of ECU fan control pin. Let me know if anyone can see any foreseeable issues with that.
Skurr ![]() |
#21905 | |
My temp runs exactly lower center, idle, traffic, back roads, freeway. no problems.
#21906 |
![]() Join Date: Oct 2013
Quick question guys, I removed the bumper and bumper support on my silvia and I am currently installing the fmic. I plan to run an aftermarket vertex front bumper and I was just curious if anyone has been able to maintain the stock jdm bumper support? Specifically if it clears the ic, and can be used with the aftermarket aero. thanks.
#21907 |
![]() Join Date: Sep 2004
Trader Rating: (24)
You can fit the big fmic with the support if you clearance the support (depends on the fmic but I've always had to cut them). This goes for JDM or USDM bumper supports.
#21908 |
![]() Join Date: Jun 2010
Just make sure amperage rating for the relay meets that of the fans.
For example: Two fans wired to one relay: 2 15A fans = 1 30A relay One relay for each for: 2 15A fans = 2 15A relays Last edited by derass; 06-18-2018 at 08:22 PM.. |
#21909 |
![]() Join Date: Mar 2009
IMO no reason to not run one relay for each fan. Worst case scenario you have a relay go bad one day you aren't dead in the water with no cooling and could wire the fan to the other relay to get home or run home with the one remaining fan etc.
#21911 |
#21913 |
![]() Join Date: Aug 2013
Garrett T3 5 Bolt exhaust discharge flanges the same as T25/28 ones? I know the 4 bolt is larger...
Will this bolt up to the T28 exhaust housing? (I am external, so I don't care about the flapper). https://www.atpturbo.com/mm5/merchan...egory_Code=FLS ![]()
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | ![]() |
#21914 |
![]() Join Date: Sep 2011
anyone selling some PS13 Silvia Bumper turn signals? (amber/clear) left and right? also willing to ship to FPO AP 96351?
B6125-44F00 (LEFT) B6120-44F00 (RIGHT) |
#21915 |
would the car overheat if you blocked them? im just asking because one of my lines has a kink in it and i have the hose at my grandmas house but was wondering if that was the cause of overheating on the highway
#21916 |
It's possible, those hoses are designed to flow from the water inlet behind the thermostat, through the core, and to the head coolant passage. I would not block them.
#21917 |
what would cause there to be no throttle response after a hard 1-3 pull (sr20) btw after coasting with WOT (no power) the power just slowly came back
#21919 |
#21920 |
Does anyone know if the Greddy oil relocation kits are interchangeable between S14 and S13 SR20 engines? I see FRSport list two types, what are the differences?
Skurr ![]() |
#21921 |
Summit Racing for longer hoses, adapters, connectors, and DIY the stuff that does not fit to make it work correctly.
#21922 |
![]() Join Date: Mar 2008
Hoping someone has an Apexi noir or a hks hi power laying around...
What's the length of the typical resonator box on the aftermarket s14 exhausts? Gonna add something similar to my resonator-less HKS sport. Here's an s14 apexi noir midpipe as an example: ![]() Thx! |
#21924 |
Just hit up Summit for a black Moroso Spiro Flow muffler. You'll like the way your car sounds after using it for a resonator, and it's only some 4" in diameter
#21925 |
Can someone please clarify if only the sunroof equipped cars have the drain tubes going down the sides of the interior? And how many drain tubes are there for sunroof equipped S14s?
Skurr ![]() |
#21926 | |
Good idea. Never understood why the Hi-Power has a mid-muffler, but the Sport doesn't. Should make for the ultimate, quiet street exhaust. Last edited by derass; 06-26-2018 at 07:13 PM.. |
#21928 | ||
I've never seen those types of mufflers before. Seems like a good way to quiet things down without sacrificing too much flow. Thanks for this, I may just give it a try. Quote:
Yeah it's weird. HKS probably didn't think a resonator was necessary. It is pretty quiet for what it is..ONE muffler, but it's still a little too loud for me and there's is a bit of drone on the highway. |
#21929 |
This place is a safe haven for my stupid questions and I’m thankful for that. Anyway I recently picked up a set of G7s with federals for what I assume is dumb cheap. I’m just wondering what these usually go for on the market? Not planning to resell, just curious. Haven’t seen many of these up for sale.
![]() Sent from my iPhone using Tapatalk |
#21930 | |
Google “panasport c5c zilvia” and you can see all the sets that have sold here recently |
