#21631 |
Does anyone here know how to tell if you have a real Nismo shift knob, i see so many fake ones on ebay and the shift knob came with the car.
Nismo knob in question https://conceptzperformance.com/nism...sal_p_2799.php |
#21632 | |
#21633 |
Anyone here a paint expert? I have single step paint on my car (I assume) and my bumper has o semi-deep scratch that I have to bog and paint.
The question is that can I put clear coat over the corrected area? I bought matching paint in a spray bottle that has some kind of clear coat in it, but should I or could I put clear coat over the painted scratch in order to blend it better? |
#21634 | |
#21635 |
![]() Exhaust fell off on my s14 KA24DE (1995). Like, bolts from the
midpipe->manifold snapped clean off. Probably from scraping. Suggestions for header/catback setups? I don't know what gets along well with what, and what bolts up nicely to a stock chassis. Looking for something rather inexpensive, as I'll be doing a swap by this time next year. Thanks in advance. Sidenote: Was looking at ISR tubular 4-2-1 and the 3" straight blast pipes, seems to be about a $350-$410 setup altogether, just not sure if it all fits up nicely. Anything around that price would work, just need somethin that fkn fits! |
#21636 | ||
GM2 (SW/AW)
Honestly? I would just get a damn $188 ebay setup if you're going to swap. (I understand this is a 4", there are 3") https://www.ebay.com/itm/4-MUFFLER-T...5aPffu&vxp=mtr The ISR setup would fit just the same. I've used both etc. I have seen absolutely no difference between the 2.
KA-T for life! Current for sale advertisement ![]() |
#21637 |
![]() Join Date: Jan 2013
Whenever I start my car, this wire to the fusebox in the engine bay gets really hot. Smells like its burning if the car runs for too long. This just happened all of sudden.
Also my car cluster lights stay on even when I turn off the car. Replaced ignition switch but that didnt help. Checked my harness under the fender and its fine. I keep hearing a relay click so I am thinking it is the Ignition Relay under the dash? Could this correlate with the wire getting hot all of a sudden? ![]() |
#21638 | |
#21639 | |
AFC #1
![]() Join Date: Oct 2003
#21640 |
Does anyone know which wire this yellow/green is? For some reason it has a splitter connector to a brown wire that is 10cm long and goes nowhere?
![]() ![]() It's from an S14a with SR20DET that is european, every ecm wiring diagram shows different, so anyone have any idea? |
#21641 | |
#21642 | |
![]() EDIT: turns out the yellow/green wire is NATS Immobilizer, I just don't know why it is splitted Last edited by VTEC_lol; 02-26-2018 at 03:14 PM.. |
#21643 |
![]() Join Date: Nov 2008
Are S14 headlight brackets the same on both sides? i.e., Can I just buy 2 of these? Asking because this one says "RH" but I didn't see an "LH" anywhere on the site:
https://frsport.com/Right-Headlamp-B..._p_368851.html
#21644 | |
![]() Join Date: Mar 2009
#21645 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
Where are you guys getting rear overfenders? And what kind? I'm looking for +30mm coupe rear overs, and just about everything seems out of stock. FrSport has Dmax, but I dont like the rivet recess they have built in.
#21646 | |
As lame as it sounds, local facebook car groups have a decent marketplace too nowadays. Not sure of brands without some sort of rivet recess tho.
cONtRol FReAkS |
#21647 | |
Rivet, fill and mold in. Smooth looking ride done right
#21648 |
I have no problem with it at all, OP mentioned not liking the recesses.
cONtRol FReAkS |
#21649 |
Are intakes even remotely worth it on a KA24E? Reason I ask, intakes are 'free' in my autocross class and the stock rubber booth at the TB is ripped and apparently an OEM replacement is worth 70$.
#21651 | |
AFC #1
Side to side or up and down? or Float?
#21652 |
![]() Join Date: Feb 2012
Trader Rating: (31)
Anyone with a hatch have both the miracle x bar and Cusco triangle brace? Curious to see if it's worth it as I already have the x brace
Sent from my SM-G955U using Tapatalk |
#21654 |
Trader Rating: (31)
Yeah. Id figure I'd ask, as I tried picturing any more benefit that the x bar doesn't help with. Plus I forgot to mention I have the do-luck floor bar and a trunk bar, so maybe it'd be overkill haha
#21655 |
#21656 | ||
Bracing triangulates all the rest of the good parts like coil overs, adjustable arms, antisway bars, and new bushings. Squaring the chassis is ALWAYS a good thing, and rigidity in corners is what makes you faster or able to hold a slide longer, or even easier
#21657 |
I bought I strut brace for my S14 but it doesn't fit because it hits this line (not sure what it is, some kind of liquid tank for AC or something?)
![]() Anyone have any suggestions what can I do about this? I loosened the bracket and slid it down but it's not low enough... |
#21658 | |
AFC #1
#21659 | |
#21660 | |
