Old 06-26-2017, 07:06 AM   #61
obscene
obscene is an unknown quantity at this point
Ugh still no spark. A friend and I went through nearly all the troubleshooting steps in the FSM before bailing in favor of late night Chinese food.
What I've confirmed:
- Everything is getting power that should
- Everything is grounded that should
- All sensors passed their tests
obscene is offline   Reply With Quote
Old 07-27-2017, 07:14 AM   #62
obscene
some updates:
http://www.youtube.com/watch?v=szvnzKQ4kw8
http://www.youtube.com/watch?v=iN3yhrdBw0A
Old 07-31-2017, 10:47 AM   #63
obscene
here goes nothing
http://www.youtube.com/watch?v=rYv26zhVDF0
Old 08-07-2017, 08:04 AM   #64
obscene
So my car still doesn't run, but that doesn't stop others from shredding. Here's my vid from last weekend's Pocono Bash event:
http://www.youtube.com/watch?v=URurAJ05l3g
Thanks for watching!
Old 08-22-2017, 01:47 AM   #65
Climb385
Climb385 is an unknown quantity at this point
Any update? Get her running yet!!?
Climb385 is offline   Reply With Quote
Old 08-22-2017, 12:26 PM   #66
obscene
I reached back out to Martin from RS Enthalpy for help a few weeks ago, and he invited me to ship him the ECU for testing. Well turns out that my ECU wasn't working properly even though it was able to power some functions of the car and display fault codes. He's going to try and repair it, so I'll either be good to go with the original or have to buy a new ECU.
Either way, I'm relieved to finally have nailed down the issue.
Old 09-01-2017, 02:17 PM   #67
obscene
IT'S ALIVE!!!!!1
http://www.youtube.com/watch?v=iWkSTu3T3Pk
Old 09-14-2017, 08:44 AM   #68
obscene
Timing is everything!
So after the initial rush of having the car start, I had time to analyze why it sounded like shit. Turns out the distributor was one tooth off. It's neat how that works.
Soon my friends!
http://www.youtube.com/watch?v=behPKDRmqmQ
Old 11-14-2017, 09:29 AM   #69
obscene
almost there!
http://www.youtube.com/watch?v=0jr_Z6e1CU4
Old 11-19-2017, 03:43 PM   #70
obscene
Finally!
http://www.youtube.com/watch?v=t5QCOzZ3bwI
Old 11-24-2017, 04:05 PM   #71
obscene
It's a Thanksgiving miracle! Moving the MAF fixed everything.
http://www.youtube.com/watch?v=L64j4RW9A-M
Old 12-01-2017, 07:06 AM   #72
obscene
http://www.youtube.com/watch?v=tCu55QXZKAg
good times
Old 12-18-2017, 10:15 AM   #73
obscene
more updates. the season is done, so now I have a nice long winter to get the car just right.
http://www.youtube.com/watch?v=E-natsTrw_k
Old 01-08-2018, 07:41 AM   #74
obscene
slowly but surely, this hunk of junk is becoming drive-able.
http://www.youtube.com/watch?v=tSjcrMWLICY
Old 01-15-2018, 06:54 AM   #75
obscene
So I'm still working out a couple bugs with the car breaking up at WOT. I've closed the spark plug gap down to .025 from .035 which helped, and I've also re-set the ignition timing closer to the 20dbtc mark which also helped.
All in all the car feels significantly better throughout the rev range as long as I'm not pressing the gas pedal all the way down. I haven't had the chance yet to get it on a long enough stretch of road to test holding boost so that's my next move.
I'm also thinking it might just be time to bite the bullet and find a dyno tuner that can make real-time adjustments or at least point out what I've done wrong.
Old 01-15-2018, 08:15 AM   #76
Super_OK_S13
Super_OK_S13's Avatar
Super_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud of
i PM'd you. i think you might need a different standalone/Tune or Tuner. do you have a wideband o2 sensor to monitor AFR's? thats the most important other than oil pressure and water temp...
Super_OK_S13 is offline   Reply With Quote
Old 01-15-2018, 08:36 AM   #77
obscene
thanks again for the message!
no wideband yet, but it's certainly on the shopping list.
Old 01-22-2018, 08:39 AM   #78
obscene
Almost a year ago today I spotted this piece of junk outside a local service station with chopped wires, no drivetrain, and rust for days. It's fought me every step along the way to this first fill up, but at least now I know the gas gauge works
Old 01-26-2018, 03:21 PM   #79
obscene
http://www.youtube.com/watch?v=iU9zUO9zHww
Old 02-26-2018, 07:05 AM   #80
obscene
So I haven't updated in a while, but one major change has taken place recently:
Although the KA24DET was finally running ok, I eventually lost the motivation to keep investing more and more time and money into sorting out the little things. The drivetrain is sold, and I'm taking a short break to re-evaluate power plant options.
Old 02-26-2018, 08:45 AM   #81
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Although the KA24DET was finally running ok...
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 02-28-2018, 09:22 AM   #82
obscene
The (bald) eagle has landed
up next:
1. edit video
2. buy heavier duty engine stand
Old 03-01-2018, 06:22 PM   #83
PoorMans180SX
PoorMans180SX's Avatar
Goes from running driving car to engine he needs to dump several thousand more dollars in just to fit in the car...
Should have just run it and got some seat time. You're going to have a ton of chassis sorting issues when you first start out driving, and now you're just delaying them so you can put a 250hp V8 in it...
build, drift, kat, s13, video
